Author Topic: Cm storm quickfire rapid  (Read 1641 times)
Offline Narcix
« on: Sat, 15 June 2013, 10:35:20 »
Hello! I'd like to buy a mechanical keyboard for a friends of mine, who is used to ****ty membranes. Urgh. I though that the quickfire rapid (with blues or browns), would be nice, but i cant find it in any italian online shop. Anyone can tell me where i can find it in uk ones for less than 100€, shipping included?
Thanks in advance
Keycool 87 Grey PBT with mx blues
Offline Narcix
Re: Cm storm quickfire rapid
« Reply #2 on: Sat, 15 June 2013, 10:39:26 »
Yes, we have it :)
But it is only avaiable with blacks here..... :(
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 15 June 2013, 11:01:38 »
Seems brown is hard to get in EU? Some of German shops have in red switch for around €80 like this one. Or if you would rather have in US ANSI you can buy it from EU CMstore it looks like.
If you are set on brown or blue switch, you might consider a Ducky instead. Should be within the budget and easier to get in any switch type it seems.
« Last Edit: Sat, 15 June 2013, 11:03:34 by IvanIvanovich »
Offline Narcix
« Reply #4 on: Sat, 15 June 2013, 11:13:22 »
Any advice on where to buy them?
Offline Narcix
« Reply #5 on: Sat, 15 June 2013, 11:28:32 »
found the white ducky g2 pro for 99£, but i dont know if the vendor ships in italy :(
« Reply #6 on: Sat, 15 June 2013, 11:31:17 »
Yes, I know. It is hard to find shop that states they will send to Italy. I find a few that say they send outside their country to some other country but no Italy... or they don't have the cheaper models only the more expensive like Shine 2. Seems there is some that have the CM TK in browns though like that jacob place I linked before. Maybe that one is another choice?
Offline jabar
« Reply #7 on: Sat, 15 June 2013, 13:41:39 »
Maybe getting a Cherry keyboard from Germany would be easier?
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
