Author Topic: Zodiac Keycaps  (Read 5202 times)
Offline frew
    • blog
Zodiac Keycaps
« on: Tue, 18 June 2013, 17:27:16 »
I think it would be really cool to replace F1-F12 with the signs of the zodiac.  I didn't realize what I was getting into and emailed SP about it and discovered how expensive it would be to get these on my own.  So would anyone else be interested in this?  The symbols are
If your browser doesn't render these correctly for whatever reason, check them out on wikipedia: http://en.wikipedia.org/wiki/Astrological_symbols#Signs_of_the_zodiac
Since they are so simple it might be cool to get them doubleshot, but that might be too expensive since I didn't even get the price to make a new mold from SP...
Re: Zodiac Keycaps
« Reply #1 on: Tue, 18 June 2013, 17:29:07 »
I wouldn't be interested in these myself but I do think it's a very cool idea.
Re: Zodiac Keycaps
« Reply #2 on: Tue, 18 June 2013, 17:38:50 »
Even WASD seems to be $10 for a single custom printed keycap.  Although it drops to $3.50 each for 10, but I guess that is probably for 10 of the same design.
Offline frew
    • blog
Re: Zodiac Keycaps
« Reply #4 on: Wed, 19 June 2013, 08:56:25 »
Oh wow that's way cheaper.  For SP it's 10x as much.  I may actually do this then, though laser etching is considerable less pretty than dye sub or double shot.
Offline SeriouSSpotS
  • 60% is love, 60% is life
Re: Zodiac Keycaps
« Reply #5 on: Wed, 19 June 2013, 09:09:37 »
These are kind of cool
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Zodiac Keycaps
« Reply #6 on: Wed, 19 June 2013, 09:16:42 »
The reason is, you're probably asking SP to make custom doubleshots, which is $45 per mold IIRC, and then they have a pricing tier starting at $20 each for five, down to $.41 each for 1000.
WASD will do you a small run, but the laser is a much different quality than you can get with doubleshots.
WASD:
SP Doubleshot:
You might be able to get someone to help you do a GB for these if you want to get the SP ones at a decent price.
Offline frew
    • blog
Re: Zodiac Keycaps
« Reply #7 on: Wed, 19 June 2013, 12:34:06 »
Yeah, I totally want to do that.  What's the protocol on getting that started?  Do we need X people first?  So far the interest has been less than I'd hoped.
Offline HongKongFui
  • No, you couldn't
Re: Zodiac Keycaps
« Reply #8 on: Wed, 19 June 2013, 13:13:11 »
start an interest check in the interest check section...
