Author Topic: These or Klaxons  (Read 6898 times)
Offline HoosTrax
These or Klaxons
« on: Mon, 24 June 2013, 21:28:27 »
I just saw these at feng's shop, must be new:
So I'm debating between buying those or waiting for a Klaxon set to pop up. I'm slightly leaning towards these as I tend to wear out keys and I hate smooth key tops, as much as I love the clean legends on doubleshots (Klaxon is doubleshot ABS right?). Thoughts?
Offline calavera
Re: These or Klaxons
« Reply #1 on: Mon, 24 June 2013, 21:31:00 »
Offline Jocelyn
  • 조셀린
« Reply #2 on: Mon, 24 June 2013, 21:31:39 »
These are Imsto Thick PBT caps. If you're worried about "wearing caps", then definitely grab these, but the font is kinda meh imo :p
PS - Yes, Klaxon = signature plastics ABS DS.
« Last Edit: Mon, 24 June 2013, 21:33:30 by Jocelyn »
Offline HoosTrax
« Reply #3 on: Wed, 26 June 2013, 13:16:07 »
The Imsto thick PBTs have a nice coarse texture to them I hope?
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4 on: Wed, 26 June 2013, 13:26:42 »
I have the klaxon set with RoW alphas and RoG mods and I think it looks a lot better than that imsto set. But that's just my opinion.
Offline Danule
« Reply #5 on: Wed, 26 June 2013, 13:29:16 »
I have the thick PBT's on my Filco and I am loving them.  They make the keyboard feel more solid and they look great.
45g Brown Brown Blue
« Reply #6 on: Wed, 26 June 2013, 13:32:31 »
I find ABS caps to be smooth while PBT caps are a little sandy/coarse. Because of this preference, I'm selling my Imsto caps.
Offline Lupizza
  • Kung av Sverige!
« Reply #7 on: Fri, 28 June 2013, 13:57:44 »
Can someone please explain what a klaxon is? I've heard it many times now on GH but I don't find anything when I google it :/
Left geekhack 2013-08-24, because of rude and arbitrary moderators.
Offline r3dx
« Reply #8 on: Fri, 28 June 2013, 14:06:20 »
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
« Reply #9 on: Sat, 29 June 2013, 16:17:16 »
the reason they make the board feel solid has nothing to do with them being thick..
It has to do with their profile.. the shorter stem and lower profile makes for less torque against the housing, thus reducing friction, and your finger is also closer to the housing, less wobbling.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #10 on: Sat, 29 June 2013, 16:44:41 »
Klaxon is king!!!
Offline Danule
« Reply #11 on: Sat, 29 June 2013, 17:33:57 »
Cool.
Offline reiuorw
« Reply #12 on: Sat, 29 June 2013, 20:33:08 »
I prefer Klaxon. But I think those pbt keycaps are better for you. Because you hate smooth key tops
Offline HoosTrax
« Reply #13 on: Sat, 29 June 2013, 21:42:56 »
Doubleshot goodness won out in the end alas; I bought the Terran kitty's Klaxons :p.
Offline HoosTrax
« Reply #14 on: Wed, 03 July 2013, 16:37:37 »
In retrospect, this color scheme probably would have looked better with red mods, instead of all RoG...
Or with a white case. Or an urban camo case (get on it Filco).
(thanks to ApocalypseMaow for the quick shipping!)
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #15 on: Wed, 03 July 2013, 17:14:08 »
You should vinyl dye your case. I believe there exists white vinyl dye. Not sure how it would work on a black case tho. I dyed mine burgundy over a grey branded case.
RoG mods looks good with RoW alphas
  • Kitteh Overlord
  • Say WHAAT...
« Reply #16 on: Wed, 03 July 2013, 20:31:49 »
What kind of numpad is that?
Offline r3dx
« Reply #17 on: Wed, 03 July 2013, 20:36:00 »
^^ this ^^
LZ-GH
Offline HoosTrax
« Reply #18 on: Wed, 03 July 2013, 20:40:41 »
Leopold 210TP with mx blues
qtan has them on his ebay store
Oooh nice! I think I would have to sand off the rubberized coating on the QFR before considering that though. I wonder if the blank cases that CM sells on their webstore has the rubber coating, or not.
« Last Edit: Wed, 03 July 2013, 20:43:53 by HoosTrax »
  • Kitteh Overlord
  • Say WHAAT...
« Reply #19 on: Wed, 03 July 2013, 21:25:45 »
Thanks for helping me spend money...  ;D
