Author Topic: Where to buy cables for Filco?  (Read 4358 times)
Offline thrashwolf
  • Freelance Illustrator / Designer
    • My Work
« on: Tue, 25 June 2013, 23:34:04 »
Hey guys, so i just had a hand at making a detachable USB cable mod for my filco, Thankfully i didnt use my stock cable, but at the same time the cable i used didnt work. Im just wondering if theres a place that i can order cables to make my Filco detachable, without me having to go through the hassle ?
also looking for a Tenkeypad ( filco ) USB cable as well ( unrelated incident - cat ate the connector / most of the cable)
let me know !
thanks in advance
TW
Novatouch TKL /w MT3 /DEV/TTY keycaps
Filco & Ducky TKL with browns
Offline calavera
Re: Where to buy cables for Filco?
« Reply #1 on: Tue, 25 June 2013, 23:35:23 »
You could buy custom sleeved ones from mimic cables.
Offline thrashwolf
    • My Work
« Reply #2 on: Tue, 25 June 2013, 23:39:56 »
all the custom cable stores set up by users are shut right now, which is annoying since i wanted to give this KB away ( once finished with modding ) as a present
otherwise i'd be more than happy to support people that run their own businesses :)
« Reply #3 on: Tue, 25 June 2013, 23:53:57 »
Offline thrashwolf
    • My Work
« Reply #4 on: Wed, 26 June 2013, 00:19:04 »
yes they do, and im probably going to get one from there - but right now what i need a cable that goes from the Internal Filco connector - to a Mini USB Female. and as far as i know they only have mini USB male to USB male.
thank you for the link though!
L
Offline khaangaaroo
« Reply #5 on: Wed, 26 June 2013, 01:01:14 »
Maybe this will help? http://geekhack.org/index.php?topic=23608.0
I shipped out my Filco, so I can't confirm what parts look like what.
Offline thrashwolf
    • My Work
« Reply #6 on: Wed, 26 June 2013, 02:46:02 »
hey there! sorry i dont think my cable is very salvagable for my TKP, and i just want a hassle free solution that doesnt need me to solder stuff together hahaha
maybe i should just be patient with the cable stores the fine people of filco have put up
thanks anyways
Offline Grim Fandango
« Reply #7 on: Wed, 26 June 2013, 02:55:36 »
Pexon is another option, and probably cheaper to ship if you are in Europe , can vouch for his cables
http://www.pexonpcs.bigcartel.com/
« Reply #8 on: Wed, 26 June 2013, 03:54:00 »
This is so BS,  You guys complain on the OT forum over someone skimping on a couple dollars on you guys... then you go blow it on fancy USB cables...
:D
Offline thrashwolf
    • My Work
« Reply #9 on: Wed, 26 June 2013, 10:14:08 »
:D
damn straight. fancy USB cables are the best.
Offline insilica
  • Keyboard Geeza
« Reply #10 on: Wed, 26 June 2013, 10:20:34 »
:D
Don't you want some fancy USB cables / connector cables for your ergoDOX tp4?  :rolleyes:
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
« Reply #11 on: Wed, 26 June 2013, 11:05:22 »
Mimic, Pexon, Nubbinator, and Whiskerbox all make cables. I'm not sure if Whiskerbox is still actively doing it though. The TechKeys cables are Mimic cables.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #12 on: Wed, 26 June 2013, 11:12:54 »
I'm happy to help out  ;)
« Reply #13 on: Wed, 26 June 2013, 11:26:05 »
:D
I may consider thicker cables for anything that's analogue.. but with digital things... It's a total waste...
Offline PointyFox
« Reply #14 on: Wed, 26 June 2013, 11:42:33 »
Make your own cable.  It's cheap and easy as evidenced by all these custom cable shops popping up.
« Reply #15 on: Wed, 26 June 2013, 14:18:23 »
If you want to make it yourself, here's the part number for the housing and here's a pinout.
I'd do one for you, but I don't have a crimper or the crimps necessary for the housing.
