Author Topic: What did you do today?  (Read 2602435 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: What did you do today?
« Reply #7000 on: Sat, 23 April 2016, 16:25:33 »
Not today, but I did set up a Pi-hole this week (https://pi-hole.net/) for tinkering with/enjoying. I loathe the state of advertising online.
How is your framerate while gaming or streaming? Pretty much the same?
« Reply #7001 on: Sat, 23 April 2016, 18:30:53 »
Learned that tp4 joined GH before me.
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #7002 on: Sat, 23 April 2016, 19:31:00 »
Haven't tested it yet, honestly. Got the configuration all done. Need to redo a bit of my network setup to put it in place and such. I'll let you know (if I remember) once I have it actually set up and running.
Have you heard... things?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7003 on: Sat, 23 April 2016, 19:33:15 »
Haha, no this is the first I've heard of Pi-hole so I'm mostly just curious
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #7004 on: Sat, 23 April 2016, 19:36:12 »
I had it up and running for a few hours the other day with a couple of my machines pointed at it. Didn't notice any issues. Had to take it down because it's just not set up in an ideal place (kitchen table) and I have to reconfigure my router for it.
Either way, while it was up and running (for like 30 minutes) it gobbled up 8% of all my traffic as ads. Pretty shocking.
« Reply #7005 on: Sat, 23 April 2016, 19:45:45 »
Well......... I move 40 terabytes a month.. so... ads are the least of my worries.
The problem with adblocking for me is that blocking them screw up some webpages..
Does pi-hole fix that?
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #7006 on: Sat, 23 April 2016, 19:52:16 »
Honestly, if your site is broken because of ads... well, I don't give a ****.
I use Focus on my phone and have noticed that some pages don't load right anymore. I would imagine it'll do the same basic thing on Pi-hole since it's redirecting ad-network content to a blank page stored on my Raspberry Pi. Did you read how it works?
Offline funderburker
« Reply #7007 on: Sun, 24 April 2016, 07:44:48 »
Finally made photos of my HHKB. And did some work-related stuff because I'm a bit behind project schedule (as usual).
Keyboard design by Skepur
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7008 on: Sun, 24 April 2016, 19:08:52 »
Cut some 6061 T6 with my table saw. First aluminum with it,  now to get it down to Rainbow for Cerakote tomorrow.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7009 on: Sun, 24 April 2016, 19:16:28 »
Holy flying bits of aluminum batman! That is awesome :)
« Reply #7010 on: Sun, 24 April 2016, 20:20:42 »
Are you using a special aluminum blade ?.. or just a wood blade.. I had alot of trouble machining aluminum on the lathe using bits meant for steel, the breaker shape and relief angles were off.
Offline Melvang
« Reply #7011 on: Sun, 24 April 2016, 20:28:29 »
I am using a blade from Diablo designed for laminates, melamine, and aluminum.  It has a triple chip grind.  Essentially, every other tooth has the outside corners taken off.
Totally to got to post a pic.
135377-0
« Last Edit: Sun, 24 April 2016, 20:32:54 by Melvang »
Offline kiwi99
  • that's a gnarly dookie
« Reply #7012 on: Sun, 24 April 2016, 22:08:08 »
bought some fabric, going to try to make a keyboard sleeve or two for myself..
« Reply #7013 on: Sun, 24 April 2016, 22:23:13 »
I haz a sewing machine..
Don't know how to use it...
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7014 on: Sun, 24 April 2016, 22:25:31 »
pffft, you don't want to admit it.
Fact: women love guys that can sew :cool:
« Reply #7015 on: Sun, 24 April 2016, 22:26:00 »
Just wired up a DIN5 cable to my leeku pcb. Now if my led's would come in I can finish this thing.
Offline alienman82
« Reply #7016 on: Sun, 24 April 2016, 22:55:22 »
removed.
« Last Edit: Thu, 01 March 2018, 15:26:17 by alienman82 »
« Reply #7017 on: Mon, 25 April 2016, 00:02:46 »
I can haz sewing machine too!
I can sewz.  And did yesterday, actually, although it did take nearly en hour to get it properly threaded :))
Offline Melvang
« Reply #7018 on: Mon, 25 April 2016, 00:26:28 »
Cut some more aluminum.  Not much difference between cutting .062" vs .160" really.  Just more shavings from the thicker stuff.
New day but I paid my shop about a grand for work on my car, took 4 pieces of aluminum to the paint shop, put gas in both cars, struck out an an e-waste shop looking for keyboards unless you could a scissor switch compact layout, made in Czech Republic cherry that I didn't buy, and went to Pizza Ranch, they were doing a fund raiser for my kiddos day care
« Last Edit: Mon, 25 April 2016, 22:40:37 by Melvang »
« Reply #7019 on: Thu, 28 April 2016, 23:16:45 »
I spilled a soda near my camera, which splashed on the lens and surrounding components.  Originally thought I cleaned it up well enough, but when I went to check it today it was all gummed up and I had a hard time even getting the lens off.  So I did a little minor surgery and cleaned her up.  Only shot the tiny spring across the room once, and somehow defied the laws of life and found it within a few seconds of looking.  :eek:
Minolta XG-M by HoffmanMyster, on Flickr
Note: this is not my primary (digital) camera  ;)
Offline alienman82
« Reply #7020 on: Thu, 28 April 2016, 23:24:45 »
removed.
« Last Edit: Thu, 01 March 2018, 15:22:59 by alienman82 »
Offline waitinginexile
  • Nathan O.
« Reply #7021 on: Fri, 29 April 2016, 18:46:21 »
Yikes, that's rough. At least it wasn't your primary
i am zeal-less i am feel-less
« Reply #7022 on: Sun, 01 May 2016, 19:08:44 »
Today I slept for 14 hours, which is only 5 hours less than the total amount of sleep I've gotten this entire week since last Sunday.
Feel good. Body's a little confused though.
« Reply #7023 on: Mon, 02 May 2016, 09:15:16 »
Thankfully!  It is my go-to film camera, but of course I only use it intermittently.
Wisconsin, eh??  :D  Whereabouts?
« Reply #7024 on: Mon, 02 May 2016, 11:16:46 »
Gonna need Beehatch to confirm this...
Is it only that they like ghey men who can sew them dresses,  or are they enamored by straight-men or any man who can sew..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7025 on: Mon, 02 May 2016, 12:42:28 »
idk man, in my family both men and women pick up arms and sewing needles. Women I've dated in the past seemed to be cool with that
« Reply #7026 on: Mon, 02 May 2016, 16:04:16 »
Where are the females..
Offline kiwi99
« Reply #7027 on: Mon, 02 May 2016, 23:50:54 »
disassembled my AEK and Clueboard.. gonna get some projects going  :thumb:
« Reply #7028 on: Tue, 03 May 2016, 01:46:42 »
Finally got my Widdlekitty Esc/Fn pack & Superlux HD562 headphones. I'm at work so will update this post later with some latvian potato photos.
EDIT: Mixed up my threads. Will repost this in "Mail today" thread. Sorrz.
« Last Edit: Tue, 03 May 2016, 01:53:09 by funderburker »
« Reply #7029 on: Tue, 03 May 2016, 01:52:24 »
if there is not one potato in your pictures, im going to be very disappointed.
Offline Waateva
« Reply #7030 on: Tue, 03 May 2016, 09:12:03 »
My friend's parents are both from Latvia and he doesn't even like potatoes, worst Latvian ever.
« Reply #7031 on: Tue, 03 May 2016, 10:18:08 »
He really is then. We have a shaming list for those kinds of people.
« Reply #7032 on: Tue, 03 May 2016, 10:22:05 »
Was he disowned? My parents disowned me for hating Mexican food.
« Reply #7033 on: Tue, 03 May 2016, 10:30:47 »
I've never met a Mexican who doesn't like Mexican food.
Offline Waateva
« Reply #7034 on: Tue, 03 May 2016, 10:32:05 »
Good, I'll let him know his fellow countrymen wish to shame him as well.
He hasn't been...yet.  Maybe they're in for the long con?
« Reply #7035 on: Tue, 03 May 2016, 10:42:20 »
I'm glad I'm your first. Was I gentle? Did I make you feel special? Pretty?
« Reply #7036 on: Tue, 03 May 2016, 10:44:58 »
It was like eating a hard shell taco: gross.
« Reply #7037 on: Tue, 03 May 2016, 10:45:25 »
Rude OnO
Offline iri
« Reply #7038 on: Tue, 03 May 2016, 11:27:41 »
I've never met a human who doesn't like Mexican food.
-Ray Bradbury
« Reply #7039 on: Tue, 03 May 2016, 11:36:27 »
TIL tortas are not Mexican.
« Reply #7040 on: Tue, 03 May 2016, 11:37:47 »
Me too man. Me too.
« Reply #7041 on: Tue, 03 May 2016, 11:51:38 »
Me too man. Me too.
Wait. WTFreak. They're not?
Offline Waateva
« Reply #7042 on: Tue, 03 May 2016, 11:55:13 »
Me too man. Me too.
Torta has a lot of different variations amongst different ethnicities.  Some are sweet, some are flatter, some are just treated like bread, some are treated like open face sandwiches, etc.
From Wikipedia: Torta, a Spanish word with a huge array of regional culinary meanings, from its traditional meaning of flatbread to cake
« Reply #7043 on: Tue, 03 May 2016, 11:55:22 »
I dunno OnO
« Reply #7044 on: Tue, 03 May 2016, 11:56:27 »
I had a tuna wrap just now..
Pretty good..  I got the whole wheat wrap, so hopefully no diabetus..
Offline totoloco
« Reply #7045 on: Tue, 03 May 2016, 12:17:28 »
Worked most of the day, then started a new painting  :D
Offline kiwi99
« Reply #7046 on: Wed, 04 May 2016, 17:22:30 »
Just got back from my spontaneous camping trip :)
where we camped
« Reply #7047 on: Wed, 04 May 2016, 17:33:56 »
where we camped
Awesome! That place looks great. Seems like everyone I know is going camping recently - gettin' me all excited!
Offline Melvang
« Reply #7048 on: Wed, 04 May 2016, 22:23:14 »
Ordered the Obstructures A2 wallet in titanium.
« Reply #7049 on: Thu, 05 May 2016, 15:37:12 »
First day with RF10AE plates on vehicle.  Already had one coworker ask what they mean.  Spent 20 minutes explaining this keyboard nonsense to him.  xD
