Author Topic: Looking to buy an endgame keyboard.  (Read 6836 times)
Offline xanoku
« on: Fri, 26 July 2013, 18:00:02 »
Hey, geekhack bros.
I'm looking into buying a mechanical keyboard with either Blues or Greens. I don't really care if it's full size or TKL.
I'd like for it to:
- have media keys (either dedicated or with a Fn layer)
- be extremely well built ( preferably with a thick backplate)
- be under 250$
- not waste space (ex: macro keys, huge bezels, space for branding)
- preferably be logo-free ( I can deal with some small minimal logos but not something distracting )
And, the most important part: I would LOVE for it to either come with or be compatible with black PBT keycaps with black dye sub legends (so black on black)
Any help will be appreciated, and thanks in advance for your time.
Offline Thimplum
  • Master of all Ponies
Re: Looking to buy an endgame keyboard.
« Reply #1 on: Fri, 26 July 2013, 18:13:13 »
QFR and Choc Mini come to mind.
Good luck!
TP4 FOR ADMIN 2013
Offline jabar
« Reply #2 on: Fri, 26 July 2013, 18:26:31 »
Choc Mini will take work to get full aftermarket dyesubbed compatibility. The QFR will be a lot easier and still has media integration.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Thimplum
« Reply #3 on: Fri, 26 July 2013, 18:37:37 »
I they both have media support.
TP4 FOR ADMIN 2013
Offline Xenderwind
« Reply #4 on: Fri, 26 July 2013, 18:42:05 »
He never said that the choc mini didn't.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline calavera
« Reply #5 on: Fri, 26 July 2013, 18:44:21 »
You can't replace the spacebar on a choc mini, keep that in mind.
Offline PointyFox
« Reply #6 on: Fri, 26 July 2013, 18:59:17 »
Poker 2 or QFR.
Offline xanoku
« Reply #7 on: Fri, 26 July 2013, 19:15:04 »
Are there any other options? Maybe something less common?
QFRs seem to be such run-of-the-mill keyboards, and I don't think a black on black keycap set would look good given the LED placement on the keys. A dedicated caps/scroll/num lock light area would be preferable.
Offline PointyFox
« Reply #8 on: Fri, 26 July 2013, 19:17:12 »
Filco Multicam then.
Offline xanoku
« Reply #9 on: Fri, 26 July 2013, 19:22:24 »
None of the Filcos offer what I want in a keyboard, namely in the way of media keys and such.
And If I were to get one, It wouldn't be a mutlicam. Not a military*** at all.
Offline Thimplum
« Reply #10 on: Fri, 26 July 2013, 19:28:45 »
Hmm...
You may have a hard time finding this stuff in a good mechanical keyboard.
Media keys are a rare find on mechanical keyboard.
TP4 FOR ADMIN 2013
Offline xanoku
« Reply #11 on: Fri, 26 July 2013, 19:33:04 »
I don't even need the full "media keys", really I'd be happy with just volume keys.
I was looking at the Ducky 9087G2 Pro, but it doesn't come with black on black keycaps. If it did, it'd probably be the perfect keyboard.
Offline jameslr
« Reply #12 on: Fri, 26 July 2013, 19:35:02 »
Wasd V2 sounds like a winner.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline keymaster
  • Topre Revolution Theorist
« Reply #13 on: Fri, 26 July 2013, 19:35:27 »
You'll most likely have to get aftermarket black-on-black PBT dyesubs on top of a MX keyboard.
Offline Thimplum
« Reply #14 on: Fri, 26 July 2013, 19:40:47 »
What do you mean by black on black? Wouldn't that be blank?
TP4 FOR ADMIN 2013
Offline xanoku
« Reply #15 on: Fri, 26 July 2013, 19:43:47 »
This keyboard actually sounds fantastic. Is there anything wrong with it? Surely there must be a catch.
Are the keys all standard size?
Offline jameslr
« Reply #16 on: Fri, 26 July 2013, 19:44:51 »
Yep, completely standard MX keys. You can check their compatibility charts. Would a black dye sub even show up on a black cap?? You'll probably have to get laser etched caps if you want legends otherwise just go blank. You can't see the damned things anyway with all black :D Ducky sells a set of laser etched PBT Black on Black (if you can find them in stock at MK)
Edit: I see the ones put out by Vortex are dyesub black on black, but they're crazy hard to read: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=287 I suppose it's all for looks anyway
« Last Edit: Fri, 26 July 2013, 19:49:43 by jameslr »
Offline xanoku
« Reply #17 on: Fri, 26 July 2013, 19:52:27 »
I'm not sure. It would have to be a very slightly different shade of black.
I don't want blank, though. I want them to be JUST OH SO BARELY visible.
So from far, and in the dark they look blank, but if I ever happen to be looking for a key that I don't use often I could still find it.
Plus, blank is annoying when doing long strings of key combinations (vim user) without typing words between them.
I think this is the best way to do it. I don't think I'd like lasered keys, though. I don't like the roughness on your fingertips that it leaves.
Side-printed black on black would be even cooler.
By the way, I know that WASD keycaps ( the 80$ ones ) are very low quality. I hope the WASD v2 will be well made. Is it made by Costar?
Offline BrokenGame
« Reply #18 on: Fri, 26 July 2013, 19:55:56 »
Well, if you were looking for a Ducky 9087G2 Pro, just buy one. Then, for the media keys, use Autohotkey and for the Black on black keycaps, take those:http://www.ebay.com/itm/Vortex-105-PBT-black-on-black-sub-dye-key-caps-for-Cherry-MX-switches-keyboards-/290920986173?pt=PCA_Mice_Trackballs&hash=item43bc3df63d
Offline jameslr
« Reply #19 on: Fri, 26 July 2013, 19:57:34 »
I assume so if they're the same as V1's. Looks like you might be in luck with the Vortex set of keycaps then. It retails for $41 at MK, but they're out of stock. Maybe you can get them on the bay. Side printed would be a pretty tall order I think. That's probably pretty rare. You'd likely have to get them custom printed somewhere and that would probably cost a fortune.
Offline jameslr
« Reply #20 on: Fri, 26 July 2013, 20:00:04 »
The Wasd V2 is supposed to ship in less than a week, so if you get your preorder in you could have your board by the first week of august, and if you order the caps from the seller on ebay you could have a complete board at the same time (caps and all). Sounds like you found your endgame board.
Offline Thimplum
« Reply #21 on: Fri, 26 July 2013, 20:02:31 »
Ah! Good choice.
TP4 FOR ADMIN 2013
Offline bazemk1979
« Reply #22 on: Fri, 26 July 2013, 20:04:14 »
u have pm op
Offline Thimplum
« Reply #23 on: Fri, 26 July 2013, 20:05:46 »
u have pm op
Huh... does anyone here know what the p in pm means?
JK ;)
TP4 FOR ADMIN 2013
Offline CommunistWitchDr
  • >implying keyboards
« Reply #24 on: Fri, 26 July 2013, 20:27:15 »
Just a warning, there is no endgame. You're ours forever.
Offline PointyFox
« Reply #25 on: Fri, 26 July 2013, 20:28:47 »
The multicam has media keys.
Offline BrokenGame
« Reply #26 on: Fri, 26 July 2013, 20:57:10 »
True that --'
Offline xanoku
« Reply #27 on: Fri, 26 July 2013, 21:37:48 »
True that --'
I figured as much. I'm probably not going to order the WASD v2 until someone reviews it and can say if the quality's any good. I don't want to spend 100$ on something cheap. I've already done that with lots of computer parts and things, and I don't want to go through it again.
I guess 2 or so weeks isn't too long to wait.
Offline PointyFox
« Reply #28 on: Fri, 26 July 2013, 21:42:07 »
Offline jabar
« Reply #29 on: Fri, 26 July 2013, 23:44:28 »
you can't have everything. no keyboard has every option you want. take what you can, get a separate keycap set if you wish.
Phantom 7bit
« Reply #30 on: Sat, 27 July 2013, 01:38:15 »
Have you considered the dyesub ducky/ I think it meets all your requirements:
Grey keycaps and cherry Greens
http://www.mechanicalkeyboards.com/shop/index.php?l=product_detail&p=467
Beige keycaps and blues
http://www.mechanicalkeyboards.com/shop/index.php?l=product_detail&p=469
Offline Thimplum
« Reply #31 on: Sat, 27 July 2013, 08:54:18 »
I think that he want black on black pbt.
TP4 FOR ADMIN 2013
Offline xanoku
« Reply #32 on: Sun, 28 July 2013, 13:52:07 »
Yeah, I looked at it. It has branding on the Super Key, and it has those ugly shortcut keys that will be impossible to find labeled replacements for.
Also,
Yeah.
« Reply #33 on: Sun, 28 July 2013, 15:46:03 »
Everypost before "this" one is a lie
ERGODOX is not a lie.
« Reply #34 on: Sun, 28 July 2013, 16:05:54 »
If you're willing to adapt to the layout this could actually be a good choice. If you end up liking it having an ergo board or two could get you out of the buying keyboards cycle. Though if you wait for the ErgoGP you can get somewhat improved ergonomics and a lot more fancy things (e.g. lights). Plus not having stupid things like a cut up usb cable on the inside for the connector.
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #35 on: Sun, 28 July 2013, 16:41:09 »
I don't think black on black keycaps even exist.. or if they do, they are extremely rare. I would probably just go with engraved keycaps and make the size small.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
« Reply #36 on: Sun, 28 July 2013, 17:18:36 »
They exist ducky and I think there are others that have made them
Example
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=69
Offline Thimplum
« Reply #38 on: Tue, 30 July 2013, 10:27:03 »
He's back.
TP4 FOR ADMIN 2013
Offline TrueOP
« Reply #39 on: Wed, 31 July 2013, 13:55:12 »
are these dye or filled
They look engraved.
Noppoo Choc Mini
