Author Topic: Topre vibrating feeling  (Read 2172 times)
Offline DrinkTea
« on: Mon, 29 July 2013, 03:00:08 »
I have a realforce 55g weighted 87u and in some of the keys, particularly around my left pinkie, I kind of feel a vibrating feeling when I let up on the key. Is this normal? It's very faint but kind of odd.
Offline czarek
  • Keep the momentum going!
    • FalbaTech
Re: Topre vibrating feeling
« Reply #1 on: Mon, 29 July 2013, 04:03:21 »
This is plate reverberating. I had similar feeling about the 45G Realforce. It's a part of oneness with a cup rubber ;)
« Reply #2 on: Mon, 29 July 2013, 04:14:14 »
it's $300 dollars "Vanity" item.
$300 gets you many many useful daily consumables.
But as far as vanity goes, $300 is still us poor people level. :D
It's delusional to expect much more.
« Reply #3 on: Mon, 29 July 2013, 06:56:16 »
One time on my laptop it started feeling like that when I touched the metal on the palm rest but it was after I plugged this printer into a usb port so I think it was some sort of electric shock.
That'd be cool if someone made a keyboard with a small motor that vibrated on key presses.
Offline Danule
« Reply #4 on: Mon, 29 July 2013, 08:47:45 »
might need some lube on that switch?
45g Brown Brown Blue
« Reply #5 on: Mon, 29 July 2013, 09:57:27 »
Probably just a bit of natural reverb. Any construction nearby? Music festivals?
« Reply #6 on: Mon, 29 July 2013, 10:18:46 »
^^ :eek: you guys lube your topre's !! :eek:
Offline Danule
« Reply #7 on: Mon, 29 July 2013, 10:21:33 »
I haven't needed to... I'm not sure I was just throwing out ideas.
Offline insilica
  • Keyboard Geeza
« Reply #8 on: Mon, 29 July 2013, 10:24:30 »
What's there to lube :rolleyes: ?
 :cool:
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
« Reply #9 on: Mon, 29 July 2013, 10:28:39 »
^^ :o you guys lube your topre's !! :o
What's there to lube ::) ?
 8)
All I know is doing a google image search on 'topre lube' was not helpful.
Offline Danule
« Reply #10 on: Mon, 29 July 2013, 10:43:18 »
 :cool:
not sure if your trolling, but there is the plunger?
« Last Edit: Mon, 29 July 2013, 10:46:08 by Danule »
Offline DrinkTea
« Reply #11 on: Mon, 29 July 2013, 11:23:11 »
One of the plungers actually was lubed (the control key, which I noticed when I swapped that and capslock). I didn't know they did this. It could provide some help. Perhaps it would slow the speed the switch snaps back at?
And maybe it's just a problem with my hand. After all almost all of the other keys feel fine.
