Author Topic: Leopold FC700R plate or pcb mounted?  (Read 3049 times)
Offline Jokrik
« on: Thu, 01 August 2013, 23:56:29 »
Hi all,
straight to the point i've some green switches (Plate mounted) on the way , and I'm thinking to desolder a filco and change the switches
however I came accross a leopold FC700R white which is more affordable
but I'm unable to find information wether its using a plate mounted or pcb mounted switch
can anyone confirm me?
Offline Photoelectric
Re: Leopold FC700R plate or pcb mounted?
« Reply #1 on: Thu, 01 August 2013, 23:59:41 »
Pretty sure it's plate-mounted.
Offline jameslr
« Reply #2 on: Fri, 02 August 2013, 00:00:44 »
Per this review - it appears to be plate mounted: Leopold FC700R Review
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #3 on: Fri, 02 August 2013, 00:01:47 »
absolutely plate mounted switch  ;D
Offline Jokrik
« Reply #4 on: Fri, 02 August 2013, 00:03:44 »
Thx guys!!
lol hello om Hendy! :)
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Fri, 02 August 2013, 02:25:51 »
As a general rule of thumb, no recent TKL are PCB-mounted.
