Author Topic: Cleaning my keyboard  (Read 2326 times)
Offline Flossed
  • Hai
« on: Fri, 02 August 2013, 18:27:43 »
I've recently spilled soda on my Ducky Shine II. I unplugged it, cleaned it as best I could. I let it dry and plugged it back in.  It worked for a good hour before it disconnected. It comes back once a while, then disconnects. On the other hand, when I just leave it, it is fine. It seems like its fine if I don't use it. =/  I took it apart again and the back of the PCB is sticky. How can I clean it? Thanks a lot!
Re: Cleaning my keyboard
« Reply #1 on: Fri, 02 August 2013, 18:30:04 »
Isopropyl alcohol might work
Offline Flossed
  • Hai
« Reply #2 on: Fri, 02 August 2013, 18:44:29 »
I've got 50%. Is that good?
« Reply #3 on: Fri, 02 August 2013, 19:03:37 »
You want closer to 90-99%
Offline Tarzan
  • formerly known as Greystoke
« Reply #4 on: Fri, 02 August 2013, 19:08:26 »
50% is also 50% water.  Cleaning electronic parts with water isn't recommended.
Offline RyanM
« Reply #5 on: Sat, 03 August 2013, 01:57:57 »
I've used 90% Isopropyl before and it went well. The 50% or 70% probably isn't a good idea for the PCB. I have a can of 1,1,1-Trichloroethane solvent from an old job where I worked on motherboards and the like often. It's illegal now so I feel bad when I use it as a last resort (for the ozone) but damn it works -- a little too well sometimes. It also rids the room of oxygen quickly.
Offline PointyFox
« Reply #6 on: Sat, 03 August 2013, 02:03:15 »
Heptane, xylene, MEK, MIBK?
« Reply #7 on: Sat, 03 August 2013, 02:39:48 »
Do all the switches still work?  If not, they will be difficult to replace.
In that case you might save yourself some time and just get a new keyboard.
Online tp4tissue
« Reply #8 on: Sat, 03 August 2013, 02:53:00 »
Um...
In the liquid likely hasn't dried and is causing a short.
leaving the case open and lean it against the wall somewhere..
if all the switches are non-sticky, then the board should be fine once dried.
STOP USING IT.
Offline Ekruceal
« Reply #9 on: Sat, 03 August 2013, 06:10:30 »
STOP USING IT.
This.
Wait until it's completely dry, then clean what's left of the soda off, as needed, with a small amount 90%+ isopropyl alcohol.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #10 on: Sat, 03 August 2013, 10:01:07 »
I agree, washing it with rubbing alcohol would be a good idea. I've fixed other electronics that were victims of Coke spills by doing the same thing.
Offline Rule16
  • R.I.P. SmallFry
« Reply #11 on: Sat, 03 August 2013, 23:34:40 »
This one time, a bird **** on one of my keyboards while all the keycaps were off, and I spent the next hour cleaning out every switch on the right half of the keyboard with a sowing needle, que tips, and 99% Isopropyl alcohol.
TLDR: 99% Isopropyl alcohol.
True story btw.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline jonathanyu
« Reply #12 on: Sun, 04 August 2013, 01:10:08 »
True story btw.
wow......  :eek:  if a bird **** on my keyboard, i am definitely going to get another one
Offline Grim Fandango
« Reply #13 on: Sun, 04 August 2013, 03:08:35 »
In situations like this you are better off leaving the board for a full day or something to make sure that it is really dry. You can deal with stickiness, but you might not be able to deal with further damage you are doing by using it before it dried.
Offline Rule16
  • R.I.P. SmallFry
« Reply #14 on: Sun, 04 August 2013, 15:55:32 »
True story btw.
It was vintage, what can you do. It's spotless now, and as clean as it was, NIB, before it got shat on.
Dvorak Only Zone
