Author Topic: Is it possible to bypass winzip self extractor password?  (Read 5100 times)
Offline llovro
« on: Fri, 09 August 2013, 04:42:06 »
https://mega.co.nz/#!ORdDHYbQ!cDjn-Cvkc52NS9_5p--OF0-VrzVMUrCTnyQxrdXKBhU
It's .exe file so I can't put it in any of those password bypassers...
Offline Jack
Re: Is it possible to bypass winzip self extractor password?
« Reply #1 on: Fri, 09 August 2013, 05:00:22 »
No luck with that, but maybe I found the files. The names seem to match.
https://photo.qip.ru/users/zimgaz12/96536165/?sort=rating&page=1
v@old-rusty ~/Downloads > unzip Ddpassw1.exe
Archive:  Ddpassw1.exe
[Ddpassw1.exe] 011-Bumper.gif password:
   skipping: 011-Bumper.gif          incorrect password
   skipping: 002-Specs.gif           incorrect password
   skipping: 003-Full-exploded.gif   incorrect password
   skipping: 004-Procedure.gif       incorrect password
   skipping: 005-Material-list.gif   incorrect password
   skipping: 006-Material-list.gif   incorrect password
   skipping: 007-Material-list.gif   incorrect password
   skipping: 008-Additional-parts-list.gif  incorrect password
   skipping: 009-Frame-build-sequence.gif  incorrect password
   skipping: 010-Frame-overview.gif  incorrect password
   skipping: 001-Cover.gif           incorrect password
   skipping: 012-Base-rail.gif       incorrect password
   skipping: 013-Top-rail.gif        incorrect password
   skipping: 014-Bulkhead-lhs.gif    incorrect password
   skipping: 015-Bulkhead-base.gif   incorrect password
   skipping: 016-Bulkhead-rhs.gif    incorrect password
   skipping: 017-Mid-cross-tube.gif  incorrect password
   skipping: 018-Motor-hoop.gif      incorrect password
   skipping: 019-Motor-cross-tube.gif  incorrect password
   skipping: 020-Motor-mount.gif     incorrect password
   skipping: 021-Roll-bar.gif        incorrect password
   skipping: 022-Roll-bar-cross.gif  incorrect password
   skipping: 023-Steering-shaft.gif  incorrect password
   skipping: 024-Steering-strut.gif  incorrect password
   skipping: 025-Steering-strut-rhs.gif  incorrect password
Offline llovro
« Reply #2 on: Fri, 09 August 2013, 05:36:45 »
Awesome!
Where did you find this?
Thanks alot. Now I'm going to try to download this... My russian is very poor so It's going to take a while :D
EDIT: Downloaded the files :D
In the original site (where you buy the plans) it says that there are some DXF files included for laser cutting but they're not here D:
Oh well... Atleast I got this for free :D
« Last Edit: Fri, 09 August 2013, 05:52:19 by llovro »
Offline Jack
« Reply #3 on: Fri, 09 August 2013, 14:39:32 »
I tried using fcrackzip but it didn't like it because it was a self-extractor rather than just a regular zip, so then I just Googled one of the filenames in quotes and I found that page.
« Reply #4 on: Fri, 09 August 2013, 16:59:24 »
every password protected zip I've come-across on the internet, NOT related to work, has been a virus.
Offline BucklingSpring
« Reply #5 on: Sat, 10 August 2013, 13:27:32 »
why would someone pwed a virus? kind of defeat its purpose. No?
Boards I own, click ->
Offline SidusNare
  • Do, or do not; there is no try.
« Reply #6 on: Tue, 13 August 2013, 12:39:36 »
might try john the ripper is you have a linux machine with cuda support, john recently gained support for cudo, if you have a modern Nvidia card you can run cracks in parallel at the number of cuda cores you have, which can be upwards of 400 on some.
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
