Author Topic: I have a serious problem  (Read 3639 times)
Offline alosec
« on: Wed, 14 August 2013, 00:41:26 »
I game with my keyboard turned diagonally so that the right side of the board is near the bottom of the mousepad. This is sub-optimal for typing. How do I find a balance between both without having to pick up my keyboard each time I want to type?
Re: I have a serious problem
« Reply #1 on: Wed, 14 August 2013, 00:44:06 »
Put it on a lazy susan.
« Reply #2 on: Wed, 14 August 2013, 00:55:40 »
Get a swivel chair?
« Reply #3 on: Wed, 14 August 2013, 02:33:37 »
You need to get a Burt Barachnoid cyst.
You know that thing where you have a midget in a briefcase on retractable wheels carry a tiny portable workstation made of balsa wood and kalamata olives, that turns to face the sound recordings of panda bears making love under a cherry jello waterfall?
31618-0
Offline MKULTRA
  • telling it how it is
« Reply #4 on: Wed, 14 August 2013, 03:02:40 »
You know what you need?
Another keyboard.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #5 on: Wed, 14 August 2013, 03:04:07 »
Another keyboard.
^ Gotta go with this suggestion.
Offline iri
« Reply #6 on: Wed, 14 August 2013, 03:05:41 »
Another keyboard.
which is implied in every post in geekhack.
-Ray Bradbury
« Reply #7 on: Wed, 14 August 2013, 03:43:48 »
Dude, Ergodox... you can spin the right and left side any way you likely..
.................... COMFORT...........
Offline Grim Fandango
« Reply #8 on: Wed, 14 August 2013, 04:16:33 »
I do the same thing. In the competitive gaming scene for FPS , a lot of people do this. I think part of it is that in those games, most people use something like teamspeak to communicate. But I also play a lot of games where I type quite a lot , be it ingame with friends or with other people while gaming. One example is DOTA. In those cases, I just set up my keyboard a little differently. As long as I can put my fingers on the homerow I can type comfortably, even when the keyboard is at an angle.
Offline MKULTRA
« Reply #9 on: Wed, 14 August 2013, 04:24:31 »
Putting the keyboard at an angle is typically done in the FPS scene because it is more comfortable and easier to reach Ctrl while leaving your fingers on WASD.  Try it.
Offline Xenderwind
« Reply #10 on: Wed, 14 August 2013, 04:29:58 »
gradually decrease your angle over time?
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline daerid
    • Rossipedia
« Reply #11 on: Wed, 14 August 2013, 09:48:02 »
This is one of the big reasons I remap caps lock to control. Hitting control with your left pinky where it normally is located is just...painful.
Offline MKULTRA
« Reply #12 on: Wed, 14 August 2013, 10:24:04 »
Yeah unfortunately this isn't an option at most LAN's.  Usually you can't even edit the drivers for your mouse/keyboard.  Unless you have it hardware mapped most pro's are stuck!
Offline Turbo Slaab
« Reply #13 on: Wed, 14 August 2013, 10:50:00 »
Fps's aren't chat rooms.
Looking for CC's!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #14 on: Wed, 14 August 2013, 10:52:34 »
Exactly. I tilt my board when gaming as well. A slight angle is more ergonomic for me when gaming. Just turn the keyboard back when you're done and want to type again.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Thimplum
  • Master of all Ponies
« Reply #15 on: Wed, 14 August 2013, 15:15:40 »
I have a serious [first world] problem.
TP4 FOR ADMIN 2013
