Author Topic: Has anyone ever used Liquid electrical tape  (Read 2672 times)
« on: Wed, 14 August 2013, 15:24:32 »
How is this stuff.. safe? deteriorates. durable?
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: Has anyone ever used Liquid electrical tape
« Reply #1 on: Wed, 14 August 2013, 15:48:23 »
I've used it. It's messy, and a pain in the ass (you have to reapply where it slides off during its drying). Only use it where you absolutely have to.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
« Reply #2 on: Wed, 14 August 2013, 19:23:29 »
gotcha thx.
Offline rknize
    • metaruss
« Reply #3 on: Wed, 14 August 2013, 22:12:33 »
I use it when I need to water proof a wire splice.  Slather it on, cover it with heat shrink tubing, and shrink it before it cures.
Russ
Offline The_Ed
« Reply #4 on: Thu, 15 August 2013, 00:44:45 »
I never thought about doing that... That would would make it so that it couldn't slide off the wires while it dries, with the added benefit of water resistance (but I wouldn't go so far as saying it waterproofs). But you usually use liquid electrical tape when you can't get shrink tubing on without cutting the wires (ex: splicing into an existing circuit).
R.I.P.ster
« Reply #5 on: Thu, 15 August 2013, 01:46:06 »
If I wrap it and then shrink, will the liquid dry properly?
Offline The_Ed
« Reply #6 on: Thu, 15 August 2013, 01:56:19 »
Who knows, it could be like the thick concrete of dams that never completely cures all the way through. As long as whatever contacts the air is dried what does it matter?
R.I.P.ster
« Reply #7 on: Thu, 15 August 2013, 02:05:51 »
ah. LOL, i thought the stuff conducts until dry
Offline The_Ed
« Reply #8 on: Thu, 15 August 2013, 02:14:41 »
You are splicing wires together that must conduct electricity, so if liquid is contacting them but trapped within a heat shrink bubble what does it matter?
Personally I stopped using the stuff and have gone back to just regular heat shrink.
R.I.P.ster
Offline rknize
    • metaruss
« Reply #9 on: Thu, 15 August 2013, 09:40:29 »
I've had to take a few apart.  They seem to cure fine.  I would never use the stuff as intended.  Even with a few coats, it's not very durable.
Russ
