Author Topic: White spots on keycap, should I make a return from the shop?  (Read 3202 times)
Offline gunbuster363
« on: Mon, 19 August 2013, 05:05:28 »
I just bought this cm quickfire xt keyboard from the local store last saturday.
Just then I found that there are white spots on the back of the keycaps. Almost every keycaps have it.
I googled this issue and people suggested they are molding point and it is normal...... http://www.overclock.net/t/1376319/new-filco-keycap-issue
I stole their image because they are exactly the same problem.
Should I demand the shop a return/exchange?
Offline kaiserreich
  • HHKB Elite
Re: White spots on keycap, should I make a return from the shop?
« Reply #1 on: Mon, 19 August 2013, 05:08:32 »
Do you type with keyboard upside down?  :p
Almost every keyboard has it.
If you hate it, maybe you can get a Topre. They have the molding marks underneath the keycap
« Reply #2 on: Mon, 19 August 2013, 05:17:35 »
Sprue marks - perfectly normal.  Most visible on boards with backlighting if you turn the board around with the backlighting on.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #3 on: Mon, 19 August 2013, 05:25:49 »
QFT. It's sprues. Present on every single keyboard I've ever owned except those I've taken sandpaper or a file to in a fit of 'must be perfect.'
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #4 on: Mon, 19 August 2013, 05:31:25 »
that's normal.
But, you should return the board anyway because backlit boards are stupid..
The paint on the keys will wear off eventually,  and you will NOT be able to find replacement backlit caps..
IF you say, "well I will not care about backlit eventually".... then you can skip ahead today and stop caring.. and get yourself some more useful gear.
« Reply #5 on: Mon, 19 August 2013, 05:35:11 »
I just noticed - I even have sprue marks on the backs of the keycaps on my Model M.
You can get at least half a dozen sets of backlight friendly keycaps now, as well as completely transparent.
« Reply #6 on: Mon, 19 August 2013, 05:47:50 »
Thanks guys, I think it is okay. However I have another problem with this keyboard. I will make a new post.
« Reply #7 on: Mon, 19 August 2013, 14:07:48 »
that's normal.
the XT is not backlit.
