Author Topic: Looking for a mechanical keyboard with these properties..  (Read 2114 times)
Offline Emospence
« on: Thu, 22 August 2013, 01:25:22 »
-Full size
-PBT or double shot ABS key caps
-Comes with blue and brown switches
-Costar stabilizers
-If possible, relatively no frills
Is there any mech kb on the market at the moment that has all these properties in stock?
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Re: Looking for a mechanical keyboard with these properties..
« Reply #1 on: Thu, 22 August 2013, 01:45:11 »
-Full size
-Costar stabilizers
Ergodox..
it's got ALL of that..
But you do have to do the costar stabilizers yourself.  I will fully instruct anyone that needs to do this.. should You choose to go with the Ergodox
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 22 August 2013, 10:26:59 »
I would suggest to buy some costar made keyboard like CM XT, Rosewill 9000, Filco... and an aftermarket set of keycaps.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Thu, 22 August 2013, 11:10:47 »
^  Yeah basically what he said, there isn't any stock Costar made keyboard out there that comes with PBT or ABS double shot.
Though it wouldn't be hard to find a keyboard that fit all your requirement except keycaps have to be aftermarket.
Oh another option is to buy the barebone WASD V2 keyboard.
« Reply #4 on: Thu, 22 August 2013, 21:33:11 »
KeyCool comes with PBT keycaps - mine is 87, is there full size version?
« Reply #5 on: Fri, 23 August 2013, 09:45:50 »
Good call, I forgot about the Keycool 108 with white PBT keycap. Has everything you want cost about $120. Actually you are probably in a good position to get it cheaper from China.
