Author Topic: QFR Stealth vs Rapid  (Read 4503 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Thu, 22 August 2013, 14:13:31 »
i am sure this has been covered somewhere, but is the stealth that much of an improvement over the rapid?
i see the stealth has a metal plate supposedly to add more weight, but the manuf site says they both still weigh in at 940 grams.....
i see there and here a lot of problems with switches dying on these things, more so for the older rapids and a few on the stealths...........?
there both abs, so what am i missing for paying the increased price for a stealth? we all swap the caps anyway......
thinking about indulging on a mx red-- does the stealth have a red back plate/pcb as the rapid?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Re: QFR Stealth vs Rapid
« Reply #1 on: Thu, 22 August 2013, 14:14:57 »
they're identical with the exception of the keycaps and 'metal-backplate-color".
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Thu, 22 August 2013, 14:16:28 »
I have one of each (QFR with blues, QFS with greens). As far as I know, the only real difference is in the side printed caps on the Stealth.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Thu, 22 August 2013, 14:20:02 »
no issues with the switches acting up................?
Offline phx
« Reply #4 on: Thu, 22 August 2013, 14:32:26 »
the switches in general are all very durable and can last forever. a broken switch is very rare, and can be easily fixed through soldering.
Offline FuriousGeorge
« Reply #5 on: Thu, 22 August 2013, 14:43:21 »
I'm not sure if they are completely identical. Doesn't the stealth have an option for key repeat that the qfr doesn't?
Offline Jixr
« Reply #6 on: Thu, 22 August 2013, 14:46:40 »
I can't confirm this, but I was told from another user on here that the QFR and the QFS use different PCB's
I have both, and aside from the astetics, they are the same.
( though there is a common bad soldering job on one of the switches, mine needed to be resoldered to fix )
but I don't think its a very common issue that it needs to be taken apart to be fixed.
Offline Carter
  • CM Storm Rep
  • * Commercial Vendor
« Reply #7 on: Thu, 22 August 2013, 15:31:52 »
QFR:
6KRO over USB
No Adjustable Repeat Rate
Stealth:
12KRO over USB
Side printed keycaps
As for issues: QFR suffered one bad batch that affected the Left Alt cluster. The very first batch of Stealth (Brown) suffered a slight imperfection around the backspace cluster. All issues have been resolved and an entirely new PCB has been implemented in both.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Thu, 22 August 2013, 16:08:45 »
QFR:
6KRO over USB
Stealth:
12KRO over USB
[/quote
QFR:
6KRO over USB
Stealth:
12KRO over USB
that will work.........
thanks
Offline Hypersphere
« Reply #9 on: Thu, 22 August 2013, 16:29:49 »
Looks like the vendor chimed in with the differences between the two models. I have a QFS with greens, and I really like the board in general and the green switches in particular. I regard it as a quality product, just as suitable for the office as for gaming.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Thu, 22 August 2013, 16:44:32 »
yeah...........that's being on top of it and watching the ball :thumb:
after reading numerous reviews on newegg, seeing 1 or 2 pop up here........, this is for sure the place to find out and how bout the rep getting the facts straight- word to the mutha ship
awesome site
thanks guys :cool:
Offline UniClown
« Reply #11 on: Thu, 22 August 2013, 17:12:58 »
CM is a genius for charging people like $50 more for poor quality side printed caps on the same keyboard.
« Reply #12 on: Thu, 22 August 2013, 17:43:02 »
I suspect you're just trolling, but when I checked CM's web site they were the same price or $5 difference depending on the switches. The caps they use aren't the best, but if compromises need to be made to keep costs down, that's where I prefer they do it. Most people won't care, and those that do are probably already planning on replacing them.
Offline gnubag
« Reply #13 on: Thu, 22 August 2013, 17:50:43 »
well the qfr goes on sale for like $45 (us) and $35 (can)
and at stores the qfr is still cheaper than the stealth.
Offline Hypersphere
« Reply #14 on: Thu, 22 August 2013, 18:05:46 »
I tend to agree. Enthusiasts want to change their keycaps. Moreover, assuming that "stealth" or "ninja" are minority options, it would cost more per unit to produce keyboards with side-printed keycaps. I am not wild about the font that CM used, and if I stay with the stealth look, I might switch the caps from those I took off my Filco MJ2 Ninja TKL board until I can afford a good dye-sub PBT set.
I paid a premium price for my QFS in order to get Cherry mx green switches, but it was worth it, both for the board and for the switches. The keyboard is premium quality and the green switches are a joy for typing. My typing speed and accuracy are better on the QFS than any other board I have used except my IBM Model M and IBM SSK.
  • ʘ_ಠ
« Reply #15 on: Thu, 22 August 2013, 18:05:55 »
QFS is the newer model, and so more in demand and hence less discounted. Shouldn't come as a shock to anyone. What is more important to me is that I got a great quality board for much less than the other comparable quality brand alternatives.
Totally agree about the QFS being suitable to the office--I am using mine at work, in fact. I love the smooth feel of the caps.
