Author Topic: Torn between this two TKL....  (Read 3323 times)
Offline sor
« on: Fri, 23 August 2013, 11:37:07 »
Hello! this is my first thread in the forum, I live in malaysia i can get the QFR for rm265(can claim warranty 1 year, but the QFR rubber coating on its body disturb me) and the Keycool shipped from china around rm210(and i can spend some on keycaps, but later on there would be warranty problem)
so im kinda torn between this two, which one u guys thinks better? also my previous board is rk9000 mx red.
Thanks
ESPORTS!
Offline Tony
Re: Torn between this two TKL....
« Reply #1 on: Fri, 23 August 2013, 11:44:22 »
Either would be fine. I would choose Keycool because of the price difference.
Offline MTManiac
« Reply #2 on: Fri, 23 August 2013, 11:48:28 »
Thanks
The rubber coating on the QFR can be removed fairly easily, it's just time consuming.
The Keycool reviews I have seen usually recommend it as a good board.
I don't think you'll be disappointed with either one.
Offline Xenderwind
« Reply #3 on: Fri, 23 August 2013, 11:49:53 »
I wouldn't pay $80 for a  QFR.  So between the two I'd go for the keycool since its cheaper.  As for the warranty I think you'd still have to pay shipping to RMA it so it might not even be worth it.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #4 on: Fri, 23 August 2013, 11:57:16 »
I always recommend a QFR to people who are new to the hobby. I just think it's a great beginners board. That being said, $80 is a bit steep.
Offline sor
« Reply #5 on: Fri, 23 August 2013, 13:20:42 »
Thanks
i imagine if the peel starts at where we lay our hands the most that would be iritating, my only verdict to get the keyboard cause of its 1year warranty
i owned the 6gv2 red, bwu, rk9000 red, and now i wana try qfr
would u think the keyboard would last me atleast 1 year without any problem, cause i will travel with it
actually my tkl option is ducky and filco both out of stock localy
ESPORTS!
« Reply #6 on: Fri, 23 August 2013, 13:43:37 »
Tear a TKL in half, what do you have... an Ergodox.
-simply the greatest
Offline sor
« Reply #7 on: Fri, 23 August 2013, 14:05:15 »
no not yet, haha
ESPORTS!
Offline Xenderwind
« Reply #8 on: Fri, 23 August 2013, 14:12:29 »
I would assume the keyboard would last you a year even if you travel a lot, as long as you aren't rough with it.  You will most likely get bored of the board before it breaks.
Offline sor
« Reply #9 on: Fri, 23 August 2013, 14:33:31 »
well i guess that good to hear  ;D
ESPORTS!
« Reply #10 on: Sat, 24 August 2013, 03:21:44 »
You can replace the case top on a QFR.  I think the black ones do not have the rubber coating.
Offline Xenderwind
« Reply #11 on: Sat, 24 August 2013, 03:24:41 »
Nope, they do indeed have the rubber coating.  May be thinner though, according to photoelectric's posts.
Offline sor
« Reply #12 on: Sat, 24 August 2013, 04:28:40 »
idk how hard to sandpaper it till the rubber coat evenly remove... buy maybe im getting the keycool, according to rowdy the built quality almost the same and the tyyping experience too compare to qfr just lacks the warranty tho(as long as the board last atleast 1 year..) :-X
ESPORTS!
