Author Topic: De-lid your Routers  (Read 9620 times)
De-lid your Routers
« on: Sat, 24 August 2013, 01:13:51 »
N66u
Wifi Radio temperatures
Without de-lid
2.4ghz radio - 65 Celcius
5ghz radio - 60 Celcius
De-lidded + old 120mm fan + coat hanger wire + .3 amp 5v nokia cellphone charger ac-brick (powers the fan)
2.4ghz radio - 37 Celcius
5ghz radio -  30 Celcius
Saw those numbers come in, I'm Sooo Happpy
32946-0
Offline singaporean123
  • I like keycaps and I cannot lie
Re: De-lid your Routers
« Reply #1 on: Sat, 24 August 2013, 01:15:13 »
are you serious?
my n56u heats up pretty hot too, wondering if i should do the same.
will the dust etc be caught in the routers?
« Reply #2 on: Sat, 24 August 2013, 01:17:13 »
are you serious?
there's gonna be dust overtime for sure.
but look at how small the surface area is
Once a month, for 3 seconds with the vacuum
My numbers are "Load" temperatures.
I maxed it out with 20,000 connections via torrents @ 100Mbit on the wifi
You can use the USB port on the router to power the fan if you like as well. but, I didn't have any resistors of the right value.
Offline Topre
« Reply #3 on: Sat, 24 August 2013, 02:52:53 »
are you serious?
Vacuums should not be used on electronics in case of static. Compressed air works better and more safely.
You should be able to hook up the fan directly to the USB port (5V) without any issues or resistors. Computer fans can are usually powered with 12V (PSU).
Offline PointyFox
« Reply #4 on: Sat, 24 August 2013, 03:21:37 »
Really?  I'm indifferent to warm routers, except for on cold days when they make nice hand warmers.
« Reply #5 on: Sat, 24 August 2013, 03:53:38 »
watch out u don't want to get hand cancer
Offline bobjane
« Reply #6 on: Sat, 24 August 2013, 08:38:41 »
The capacitors were on their way out so I replaced all the stock junk with good quality ones.
Also decided to do something about the overheating:
- Heatsinks on all the ICs/chips (still waiting on some heatsinks).
- Added some air intake holes to the bottom cover.
- Mount a 120mm fan on top (waiting on fan adapter).
As for powering the fan, I don't think the USB port on a modem/router would be set up to output any power. Mine will be powered by the computer's USB.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Sat, 24 August 2013, 09:03:18 »
|: umm...
« Reply #8 on: Sat, 24 August 2013, 10:24:30 »
The reason I did not drill a hole in my cover plate is because each time I'd need to clean it, I'd have to take the plate off.
Also, you should put some silicone on the ic pins on yours because if dust gets trapped in there, and then you run into a humid day.. ZAP..
I put silicone on all the exposed tiny pins.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #9 on: Sat, 24 August 2013, 10:52:25 »
I leave my routers running in the midst of a four-foot tall pile of dusty computer parts. They still work!
« Reply #10 on: Sat, 24 August 2013, 11:06:46 »
I like my packets with no mistakes....
Offline bobjane
« Reply #11 on: Sat, 24 August 2013, 22:50:32 »
Those pins ARE awfully close together. Might have to pick up some silicone.
|: umm...
I'm sorry, was that too geeky for a keyboard forum?
« Reply #12 on: Sun, 25 August 2013, 00:05:28 »
|: umm...
I recommend cutting those side grills off. and just have 2 big vents on the side.
Offline PointyFox
« Reply #13 on: Sun, 25 August 2013, 00:21:53 »
Use liquid nitrogen?
« Reply #14 on: Sun, 25 August 2013, 04:11:29 »
that's temporary overclock. and it doesn't seem these new routers can overclock either.
Offline ComradeSniper
  • HHKB Pro
« Reply #15 on: Sun, 25 August 2013, 11:20:03 »
What is the advantage of this aside from a longer lasting router?
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #16 on: Sun, 25 August 2013, 11:34:36 »
heatsinking key parts (target analog devices, as those degrade most quickly and ICs, because they're almost always running at _exactly_ their tmax) is more important than delidding. every router has venting for convection cooling, but no one wants to spent the 3 cents per heatsink on the proper heatsinking. oh no my margins would go from 100% to 99.8% waaaaaaaaaa :|
this is why the airport extremes work better than most other routers by the way. first of all, the thing is properly heatsinked. second of all, slightly fewer firmware bugs (and bugs that are coincident with bugs in apple products acting as clients, which almost everyone owns).
Offline mkawa
« Reply #17 on: Sun, 25 August 2013, 11:35:46 »
fewer errors and better reception (the analog parts are all for RF and the digital parts are cheap ICs that make mistakes, LOTS OF MISTAKES when running that hot.
« Reply #18 on: Sun, 25 August 2013, 11:55:23 »
Stop diss'n ma router Kawa
This thing was only $90 after coupon,  It's never hurt nobody..
Offline mkawa
« Reply #19 on: Sun, 25 August 2013, 12:01:13 »
i was literally buying a new 90$ router like every year before i just gave in and bought an AEBS. it's twice as much, but it will last five times as long, so overall it's a win
Offline Tym
« Reply #20 on: Sun, 25 August 2013, 12:03:45 »
Using the router I got free from my service provider  :cool:
Offline Photoelectric
« Reply #21 on: Sun, 25 August 2013, 12:06:36 »
Okay, now I'm curious...  My router doesn't seem to run that hot to touch, but it's definitely very warm, and if you think giving it a good clean and perhaps keep open would help, I'm down with doing those things.
It's a Belkin Wireless G and it has some ventilation holes on one side and stands on its side to provide better air movement along the sides.
Or is this more beneficial for older and larger routers?
« Last Edit: Sun, 25 August 2013, 12:10:30 by Photoelectric »
« Reply #22 on: Sun, 25 August 2013, 12:17:46 »
what? ever year? that makes not sense, did they burn out, upgrade-itch?
You can't expect routers to last 5 years though... faster more powerful ones come out so quickly. I'd say 2 years tops..
« Reply #23 on: Sun, 25 August 2013, 12:20:50 »
Every electronic equipment that "heats up" benefits from active fan-cooling.
as far as cleaning goes, you wouldn't need to clean, because there was no way it could've gotten dirty, since it's convection cooled with no dust blowing at it.
« Reply #24 on: Sun, 25 August 2013, 12:22:38 »
It depends--processors can run quite hot when overclocked, but it won't result in any errors unless overclock is unstable (they have to get VERY hot for that to happen).
« Reply #25 on: Sun, 25 August 2013, 12:28:44 »
There's a tolerance for errors in software.
At spec, below thermal envelope, the processor MEETS the tolerance.
That doesn't change the fact that with better cooling, the processor wouldn't be outputting better numbers.
« Reply #26 on: Sun, 25 August 2013, 12:32:04 »
I'd like to see some actual data on this.  My router runs 24-7 and with wireless access as well, and it's never restarted or done anything odd.  I'm pretty sure it runs quite warm, and I don't think running it at 5C above ambient temperature would make me notice any difference.  If it ran at like 70-80C and I'd see it restart or make me lose connection, I'd understand.  But you can't just say that every router would benefit from this "just because in theory".  Some things are worth doing to be thorough and some are not really.
And yes, people overclock their processors and can run 24-7 at 70-80C on Ivy Bridge processors with zero noticeable errors (there exist many vigorous tests for stability).  That's just an example where something running "hot" vs. not hot at all (like at 45C) is not going to affect stability but will perhaps affect long-term durability (though most will upgrade before they will notice any negative effects).
« Last Edit: Sun, 25 August 2013, 12:34:15 by Photoelectric »
« Reply #27 on: Sun, 25 August 2013, 12:59:19 »
The stability you're talking about is a relative figure based on acceptable tolerance.
That doesn't mean the device is not doing better given LOWER temperatures.
For example, we see mission critical setups in the labs being "under-clocked",  why? because they need very high precision and better stability..
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #28 on: Sun, 25 August 2013, 13:00:06 »
I think most of it comes down to the quality of components. Some really just are very bad, and they are not really rated for running warm for extended periods. It's probably less the cpu, network and radio chips, but the caps, vrms and other components that are more prone to heat failure. Though some of the chips used really do suck quite badly too.
I used to run a home made modem router with x86 amd geode. It didn't have any cooling, not even heat sinks. Also the crazy design put the CF card the OS ran from right on top of the cpu literally and no ill effects. That thing ran and ran and even at high load rarely hit 30c. It's kind of too bad there isn't more home level stuff that used those as they are quite good for such roles. I only stopped using it since I outgrew my adsl pci card when higher speeds became available I didn't want to be stuck on measly 6mbps when I can have 15. I thought about getting a new adsl card, but they were just too expensive for higher capability. I wish someone would come out with a pci-e adsl/vdsl card so up to date motherboards could be used with cheap ddr3. I also liked being able to migrate wifi from g to n with very little cost in swapping in a mini pci card hitting apt and back up with little fuss.
« Reply #29 on: Sun, 25 August 2013, 13:10:36 »
No, it all depends on whether a product operates within specified tolerances.  Active cooling will lower the temperature, but if that product (processor, VRMs, RAM, storage, etc.) is already operating within the allowed temperature range for proper operation--cooling is adequate.  You seem like a person I've seen who installed a full custom cooling loop onto his i3 in a large case for his HTPC project...
I have no doubt some routers actually overheat, but you can't generalize that every router / component needs fans plastered all over it.
Offline Lanx
« Reply #30 on: Sun, 25 August 2013, 13:31:11 »
i wall mount my routers ( i have the comcast modem, i bought my own, the wifi and my gigbit green router) i find it a lot easier to have them out of the way in this manner, and i can dust them really fast with the turbo vacuum.
« Reply #31 on: Sun, 25 August 2013, 13:34:37 »
what's a gigabit green router..
is that a second router ontop of your wifi router?
Offline ften
« Reply #32 on: Mon, 26 August 2013, 23:54:22 »
My N66U runs pretty hot too but I would never have thought about de-lidding it, I like my routers toasty  :p
Do you use a custom firmware on your N66U?
« Last Edit: Mon, 26 August 2013, 23:56:16 by ften »
« Reply #33 on: Tue, 27 August 2013, 00:07:17 »
tomato
Offline bobjane
« Reply #34 on: Mon, 02 September 2013, 02:52:37 »
Here's a router where I didn't want to void the warranty.
These things get a lot hotter than 5C above ambient. The first one I posted ran fine for years until the caps went but it was almost too hot to touch, and that's through 3cm of air and then 5mm of plastic. The components were probably getting close to 100C in summer.
« Reply #35 on: Tue, 03 September 2013, 12:43:23 »
nice rig...
Warranty is for chumps though..
If you're using a cheap router like me.. there's really no point to ever claim a warranty..
Bust that bad boy open and get Serious Cool.
We pretty much know for a fact that routers are dying from heat.. So if you've tested for DOA + infant-death for a good 2-3 weaks,  you're in the clear for custom cooling
