Author Topic: [Mechanical] Quietest Switch/O-Rings Combo?  (Read 12360 times)
Offline Stevenator21
« on: Sat, 24 August 2013, 09:49:04 »
Hello people of Geek Hack,
I am in the market to get a mechanical keyboard. From all my reading, I thought brown would suit me best. I ordered a Das Keyboard with Cherry MX Brown Switches on eBay for $80. Apparently it is too loud for my parents (They can hear it in the hall way and the room next to my desktop) so I need to get something quieter. I don't want to spend a lot, and I found a really nice keyboard, the CM Storm QuickFire TK and QuickFire Rapid that seems it will suit my needs.
I heard Red was the quietest switch out of all of them, and don't know about o-rings.
My 2 questions are:
A) What is the quietest Combo of switch and o-ring that I can get under $90 with the CM Storm QuickFire TK or Rapid?
B) How much quieter will that be than stock browns?
« Last Edit: Sat, 24 August 2013, 10:01:53 by Stevenator21 »
Ducky Shine 3 TKL w/ Browns + White LEDs
Offline mauri
Re: [Mechanical] Quietest Switch/O-Rings Combo?
« Reply #1 on: Sat, 24 August 2013, 09:52:26 »
Well, reds aren't exactly quiet switches, unless you're a fakir of touch typing
I AM BABAR KING OF THE ELEPHANTS
« Reply #2 on: Sat, 24 August 2013, 10:15:26 »
You can learn not to bottom out when you type which should help. Also if you have linear switches and don't bottom out that will reduce the noise. If you're really set on one of the boards you listed and want to use o-rings or soft landing pads, I wrote a review on them so you can check out my thoughts there.
The quietest stock mechanical switches I've ever tried are Dampened Cream Alps, which are hard to find, and Matias Quiet switches which are easy to find.
The quietest modded mechanical switch I've ever used is Jailhouse Blues.
Oh and welcome to GH :D
« Reply #3 on: Sat, 24 August 2013, 10:21:00 »
Oh thanks!
I would love to get the other switches but the problem is I only want to spend $90 Overall
Offline Photoelectric
« Reply #4 on: Sat, 24 August 2013, 10:21:44 »
MX Blacks with o-rings, followed by Jailhouse Blues with a lighter spring.  I have 2 keyboards with those switches now--the quietest switches I've experienced to date.  My lubed vintage Black keyboard with o-rings is quieter than most rubber domes I've tried.
« Reply #5 on: Sat, 24 August 2013, 10:42:36 »
Are blacks quieter than reds?
Offline JPG
  • Model F is my new passion!
« Reply #6 on: Sat, 24 August 2013, 10:46:13 »
I really suggest trying to add o-rings first. They cost near nothing and they will significantly lower the sound. Anyway, as long as the switch is not clicky, the only sound come from bottoming on the plate. So even if stiffer switches can make it a little harder to bottom out, if you do bottom out the sound will be the same.
So just get some o-rings and you will see the sound reduction is quite evident, and will probably be enough.
« Reply #7 on: Sat, 24 August 2013, 11:04:16 »
In terms of sound, they're the same to me.
« Reply #8 on: Sat, 24 August 2013, 11:07:14 »
Reds are considered louder than Blacks generally because they are so easy to bottom out (very light springs).  Blacks have heavier springs and are more cushiony.   But perhaps if you use low profile keycaps (like Cherry profile) and add thin silicone o-rings, Reds will be quiet too.
« Reply #9 on: Sat, 24 August 2013, 11:09:04 »
Hm that is true, it is way easier to not bottom out on Blacks...you can totally learn to not do so on Reds though. Might take some time to learn though.
« Reply #10 on: Sat, 24 August 2013, 11:16:55 »
What I am planning on doing is ordering either the QuickFire Rapid or TK and O-rings, then if my mom tells me to be quieter ie. during the night I can try not to bottom out. Are Reds okay for typing, I do a lot more typing than gaming.
« Reply #11 on: Sat, 24 August 2013, 11:20:09 »
It's going to be a personal decision for you which switch you find more comfortable, but I'd personally recommend Browns.  They are light and comfortable (for me anyway).  O-rings will help, though I've found that keycaps (material, thickness, and shape) play a significant role in amplifying and changing the sound and even the feel of typing.  So you could eventually experiment with different keycaps too (from various group buys here and on the classifieds): thick PBT Cherry profile, for example.
« Reply #12 on: Sat, 24 August 2013, 11:47:09 »
I have used browns and love them but they are too loud.
« Reply #13 on: Sat, 24 August 2013, 12:00:42 »
So what would be the best combo of keycaps and o-rings to make reds as silent as possible?
Offline jameslr
« Reply #14 on: Sat, 24 August 2013, 12:09:55 »
I think your parents need to get some white noise like a fan or something.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #15 on: Sat, 24 August 2013, 12:32:58 »
When the AC came on they couldnt hear it but sometimes its dead silent in the house.
« Reply #16 on: Sat, 24 August 2013, 12:59:00 »
Are the 40A-L O-Rings from WASD quiet?
Offline jameslr
« Reply #17 on: Sat, 24 August 2013, 13:00:04 »
Yeah that's where a nice even sounding oscillating fan would help with that drastically. I'm assuming their main complaint is when they're trying to sleep and all they hear is the uneven sound of you clacking away on your keyboard. I used to sleep in dead silence before I had kids. Now it drives me nuts if there isn't a fan going to isolate the normal odd noises you hear in complete silence.
« Reply #18 on: Sat, 24 August 2013, 13:00:59 »
O-rings will definitely help.  Do you bottom out most of the time when typing?  If so, I think you may find Blacks with o-rings to be the right weight and quiet.  Linear switches are an adjustment after rubber domes and Browns, as there's no bump, which can be disorienting.  But they are quieter than tactile switches.
Offline jameslr
« Reply #19 on: Sat, 24 August 2013, 13:04:25 »
You can get an O-Ring test kit from wasd for around $6 I think. Not sure on the shipping, but it might be good to just buy one of their test kits before you haul off and buy a full set of o-rings. I'd recommend getting that and just trying it out.
Here's a link to their switch sampler kit. It will help in making the decision (if you need to switch to linear versus tactile).
http://www.wasdkeyboards.com/index.php/wasd-sampler-kit.html
« Last Edit: Sat, 24 August 2013, 13:06:57 by jameslr »
Offline davkol
  •  Post Editing Timeout
« Reply #20 on: Sat, 24 August 2013, 13:58:23 »
You can't get much quieter than with browns, unfortunately.  Thick or non-ABS keycaps, lubing the switches and dampeners (I recommend soft-landing pads sold by EliteKeyboards) would help, but it's never going to be anywhere near scissor switches with a skin (see TypeMatrix or those skins for Apple Macbook/Aluminium keyboard).
« Reply #21 on: Sat, 24 August 2013, 14:29:56 »
Well I would think Reds would be more quiet because there is no click and the O-Rings help with the bottoming out sound.
Offline JPG
« Reply #22 on: Sat, 24 August 2013, 14:37:45 »
There is no click on browns. There is a small tactile bump, but it does no sound. The only sound will come from the bottom out, so basically the key hit the plate and there's sound. So brown and red will be the same. If you want to lessen the sound, you need to absorb the impact when you bottom out. So you are best with 0-rings. Also, if you get thicker keycaps, the sound will be less strong also, so it helps, but really, before changing the switch type, you are better adding O-rings because unless you have clicky switches (blue/green/white) then the switch itself does no sound.
You can get some O-rings for like 2$ on amazon (size 008). The softer the more it will absorb the sound, but II use 70A and it does a great job and has a nice feeling. You can also go more classic and get 50A, more soft.
« Reply #23 on: Sat, 24 August 2013, 15:54:08 »
There's significant noise when the switches rebound.  It adds to the overall clanky noise.  I would argue that the rebound sound is louder than bottoming out if you have o-rings installed.  The rebound sound is a function of keycaps: material, shape, thickness, and how solidly they fit onto switch stems.  Try to push a key down all way, then pause and quickly release it.
« Reply #24 on: Sat, 24 August 2013, 16:44:49 »
That would make a lot of sense. I still have the brown keyboard I need to return so I can try that out. Are there some keycaps that are better at noise reducing that others?
Online tp4tissue
« Reply #25 on: Sat, 24 August 2013, 17:06:43 »
NO.. way to reduce rebound noise on Cherry MX
I've been using thick orings for a while..
and i'm starting to think that for  the more "Novice" users,  perhaps sound dampening o-rings would be bad,
Because as they are not yet adept at good typing rhythm, the lack of the bottom out audio noise may be confusing to them.
Once they hit 120+, then it doesn't matter because at that point, the person's clearly typing faster than he's able to listen to the switch response.
But before that happens.. the switch's audio response will let you know where the key intonations are, and help you minimize hand lifts.
« Reply #26 on: Sat, 24 August 2013, 17:10:14 »
Depends on switch, but I find that Ducky Shine (and equivalently CM Storm Trigger and similar) caps are quite soft and absorb impact / vibrations very well vs. harder caps.
Online tp4tissue
« Reply #27 on: Sat, 24 August 2013, 17:12:21 »
mmmm.............do you gotz decibel spl meter on your phone?  Measure for us Kay ?
Offline chill1217
« Reply #28 on: Sat, 24 August 2013, 17:46:34 »
i think a matias quiet pro would be best for your situation
on this page there's a sound comparison to cherry switches you can listen to
http://www.matias.ca/quietpro/pc/
there's an ebay post selling pretty cheap ones right now
http://www.ebay.com/itm/Matias-Quiet-Pro-Mechanical-Keyboard-FK302QPC-for-Windows-PC-/181196121455?pt=PCA_Mice_Trackballs&hash=item2a3021656f
« Reply #29 on: Sat, 24 August 2013, 18:12:03 »
Wow did not see that thanks so much!! It says it has a custom switch.... Do you know if it feels good? What Cherry MX switch would it be compared too? Also can you replace the keycaps?
« Reply #30 on: Sat, 24 August 2013, 18:13:58 »
I'm pretty sure non-clicky Cherry switches with o-rings or landing pads will be as quiet.
Offline chill1217
« Reply #31 on: Sat, 24 August 2013, 18:37:10 »
i believe they are modified ALPS switches and other ALPS will fit onto them.  there have been a couple reviews floating around that say that they feel really good.  i think it feels more like topre than cherry mx switches.
here's are some reviews
http://geekhack.org/index.php?topic=41986.0
http://geekhack.org/index.php?topic=42148.0
http://geekhack.org/index.php?topic=38891.0
http://www.engadget.com/2012/10/11/matias-quiet-pro-keyboard-review/
« Last Edit: Sat, 24 August 2013, 18:40:44 by chill1217 »
« Reply #32 on: Sat, 24 August 2013, 19:14:26 »
Oh that's interesting. Will defenitly keep that in mind. The Matias would be cheaper.
2 questions....
A) Do you think that the $60 is kind of suspicious for a $150 keyboard?
B) Would the feeling be better on one or another?
« Reply #33 on: Sat, 24 August 2013, 19:21:19 »
Oopsies replied to my own... Cant delete on my phone
« Last Edit: Sat, 24 August 2013, 19:25:21 by Stevenator21 »
« Reply #34 on: Sat, 24 August 2013, 20:47:44 »
So it ends up it has $22 shipping.
« Reply #35 on: Sat, 24 August 2013, 21:34:28 »
I say this in my first response but I'll just repeat myself. The Matias Quiet switches are the second quietest switch I've tried. Quieter than a MX switch with o-rings. The soft-landing pads don't really quiet switches as much as o-rings.
Matias Quiets feel like a better version of MX Browns in my opinion. Browns can feel gritty and the tactile bump feels a bit lacking or non-existent. The Quiets have a touch more tactility and they have the actuation right at the top instead of in the middle like MX switches will so if you learn how to type on Alps switches, you'll never bottom out and it should be very quiet.
« Reply #36 on: Sat, 24 August 2013, 22:13:22 »
Yeah, I would love to own a Matias Quiet Pro. It seems like an awesome keyboard to have.
Here is the situation now:
I go with either
a) CM Storm QFR w/Reds for $70 (Maybe $60 if I can buy it cheaper used on these forums) + O-Rings ($17.99 from WASD possibly less if I find for cheaper or buy from someone) = $88 + Ability to change key caps + Smaller sizer which I love
b) Matias Quiet Pro for $65 on eBay + $22 shipping (No need for O-rings and can't change keycaps) = $87
With what CPTBadAss mentioned above, the Matias Quiet Pro would be quieter and possibly feel better than the Reds (I do mostly all typing).
At this point should I go for the Matias or go with the CM Storm QFR and try to get the price down?
PS. I really appreciate all the help in all of the previous posts.
« Reply #37 on: Sat, 24 August 2013, 22:31:28 »
This one is going to come down to whether or not you want MX Reds or Matias Quiet switches. Definitely a personal preference thing here. If I were making this decision, I'd get the Matias Quiet board. But I'm a *huge* Alps and Matias fanboy.
« Reply #38 on: Sat, 24 August 2013, 22:35:08 »
Would the best way be to order them both see which I like better and return the other?
« Reply #39 on: Sat, 24 August 2013, 22:37:22 »
Maybe haha. Maybe you want to try the WASD sampler pack first? That way you'll know if you like or dislike MX Reds without having to pay all the money?
I don't know where you live but if you're near a Microcenter or NCIX, I'd recommend you go there and try boards there.
Offline chill1217
« Reply #40 on: Sat, 24 August 2013, 22:54:42 »
here's a sound comparison vid i found:
the qfr with reds would probably be your ideal if it is "quiet enough".  TKL and custom keycaps are huge advantages.  i would love participating in a lot of the group buys here but i have topre and almost never touch my quickfire pro with browns :(
however, if a quiet keyboard is such a high priority, then matias is a good choice.  the ebay listing is also "best offer", so you could try negotiating for like $70/$75 shipped.  if you want a smaller form factor, maybe wait out for a deal on matias quiet pro mini or try to find a used one.
keep in mind if you buy both and plan to return one, you would likely have to pay return shipping which would be ~$12
also just throwing this out there, you may want to consider the microsoft sidewinder x4.  it might be blasphemy recommending a rubber dome keyboard, but it is quiet and goes for like $35-$40 on sale
« Reply #41 on: Sat, 24 August 2013, 23:05:27 »
Don't forget you can also get 50A black rubber o-rings from Amazon for $8.25 (free shipping if you have Prime).  They are my favorite for general noise dampening.
« Reply #42 on: Sun, 25 August 2013, 07:07:11 »
I actually happen to live 20 minutes from a Microcenter, maybe I will pop in today.
It turns out before this whole adventure I did order a Microsoft Sidewinder x4 keyboard. The space bar was broken and got stuck so I had to return it. That's what got me thinking, "I could get a mech keyboard".
Did not notice it was best offer! Will defenitly take that into consideration.
That would take $10 off of the CM QFR w/Reds making it $80.
Do any of you know how much I could buy a QFR w/Reds off of someone here?
EDIT: Found someone and asked them if they would sell it for $60 shipped and they said yes.
« Last Edit: Sun, 25 August 2013, 07:32:41 by Stevenator21 »
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #43 on: Sun, 25 August 2013, 09:51:19 »
I go with either
You don't seem to care about the difference in size/width of the board, so in your place I would get the Quiet Pro. That is a great price and I would only be suspicious if the seller had a lower rating.
I got my Mini Quiet Pro a couple weeks ago and would choose it over a brown switch (actually any Cherry switch) in a heartbeat. Its about twice as loud as a typical laptop keyboard, if that helps you decide.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
« Reply #44 on: Sun, 25 August 2013, 10:05:42 »
I would prefer the smaller size a ton but $86 is an amazing price for the keyboard. I think I might go to microcenter today because I like the thought of a linear switch. It does seem kinda suspicious but the seller has a good rating.
Offline JPG
« Reply #45 on: Sun, 25 August 2013, 10:56:29 »
For the o-rings, look at this:
70A (stiffer, that's what I use and I love em ~2$): http://www.amazon.com/dp/B000FMWLR8/ref=biss_dp_t_asn
50A (more popular, never tried them, they cost more on amazon ~8$): http://www.amazon.com/dp/B0051XWXCE/ref=biss_dp_t_asn
You can also look at IMSTO's vendor forum, he has some for sale at like 4$ a bag, so if you want the soft ones, the ones IMSTO sells would probably be the best choice.
« Reply #46 on: Sun, 25 August 2013, 11:47:20 »
So are the WASD keykaps a waste of money for $20?
« Reply #47 on: Sun, 25 August 2013, 11:59:33 »
Unless you want very customized legends--yes.
« Reply #48 on: Sun, 25 August 2013, 12:02:42 »
Alright so now it seems like it will really come down to feel. I love the though of linear switches, are going to microcenter soon and will report back on those.
The Matias seems good with the tactile, how would you compare the feeling to browns?
« Reply #49 on: Sun, 25 August 2013, 13:41:02 »
EDIT I am at micro center and have tried the reds. Do not like them very much....... Will go for the Matias!
