Author Topic: instead of us flipping SP spacebars.....  (Read 5359 times)
Offline zoolzoo
« on: Sat, 24 August 2013, 11:42:38 »
Why don't we just ask them to round off that edge? How hard is it for them to change the mold?
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline esoomenona
  • Gnillort?
Re: instead of us flipping SP spacebars.....
« Reply #1 on: Sat, 24 August 2013, 11:47:51 »
They'd either have to make a new mold, or they'd have to fill part of that mold. Most likely the former. And if they did, they'd have to made new molds for every cap on the bottom two rows, because they all have the same angle.
« Reply #2 on: Sat, 24 August 2013, 11:49:24 »
about $3000 hard.
The SP keycaps are intended for a somewhat steeper angle than most of the keyboards we use (presumably they are more common on POS keyboards, or whatever SP's main customers are) so it' snot too bad if you have your KB up at a steep angle. Additionally, changing the spacebar (pretty much at all) would require a new mould to be made. I think things like adding posts for a more "universal" fit is something that they can modify their existing moulds with, but chanigng he profile of the spacebar entirely would almost surely require a whole new mould.
Offline zoolzoo
« Reply #3 on: Sat, 24 August 2013, 11:52:37 »
They wouldnt HAVE to change the other molds. But point taken.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Sat, 24 August 2013, 11:54:15 »
Why don't you just order DSA spacebars from them? They don't have the same sharpness. In fact, we should start offering DSA spacebars with all GBs, for those who cut themselves on the DCS knifebar.
Offline zoolzoo
« Reply #5 on: Sat, 24 August 2013, 11:59:39 »
Thats actually a good idea. I just need to figure out which color matches wyse alpha keys. :\
Offline esoomenona
  • Gnillort?
« Reply #6 on: Sat, 24 August 2013, 12:08:55 »
Search for the WYSE moogle or WYSE tsangan IC or GBs. One or more of them had color codes.
Offline zoolzoo
« Reply #7 on: Sat, 24 August 2013, 12:44:40 »
thanks moose!
Offline tricheboars
  • Keyboards are Important!
« Reply #8 on: Sat, 24 August 2013, 15:56:46 »
i always rock a backwards space unless i am using my SA R4 set.  but on the boards that have the backward space i wouldn't want the mods swapped. i like the look of the odd comfy spacebar by itself.
« Reply #9 on: Sat, 24 August 2013, 16:30:29 »
DSA is good,  but not REVERSE OEM profile good.
the OEM bar is Taller, making it awesome, because on standard staggered qwerty, you need a higher thumb key
« Reply #10 on: Sat, 24 August 2013, 16:55:03 »
I use my DSA spacebar flipped.
just kidding, though interestingly enough, the DSA spacebar won't work with my spacebar stabilizer. I'll have to swap it out for a cherry one sometime. This shows that the spacing is either very slightly different, or the margins aren't good enough on my stabilizer wire.
Ultimately, getting better molds for SP would be probably the best solution, but it's also the most expensive.
Offline tricheboars
« Reply #11 on: Sat, 24 August 2013, 23:27:30 »
Cherry stabs 4 lyfe
Offline ComradeSniper
  • HHKB Pro
« Reply #13 on: Sun, 25 August 2013, 00:40:49 »
People always let me know that there's something wrong with my spacebar whenever I break out the Poker at school or work.
Flipped spacebar is so comfy though, even on non SP caps I still flip it.
« Reply #14 on: Sun, 25 August 2013, 09:41:40 »
or you could get an EK spacebar and truly enjoy life.  The thing is the most beast amazing spacebar ever.
Offline Latin00032
« Reply #15 on: Sun, 25 August 2013, 11:29:52 »
What makes it so great?
Offline zoolzoo
« Reply #16 on: Sun, 25 August 2013, 11:49:09 »
looks like a black abs space bar to me, heheh
Offline Moosecraft
  • HHKB Pro
« Reply #17 on: Sun, 25 August 2013, 12:27:23 »
But it's not 7x..
Offline longweight
  • philanthropist
« Reply #18 on: Sun, 25 August 2013, 12:29:16 »
I've never had a problem with the spacebars... what is it that angers people?
Offline Moosecraft
  • HHKB Pro
« Reply #19 on: Sun, 25 August 2013, 12:30:34 »
I've never experienced pain from SP spacebars either but I position my hands a bit weird when I type.
Offline zoolzoo
« Reply #20 on: Sun, 25 August 2013, 13:31:06 »
Its mostly only an issue when gaming actually, when my thumb is resting on the space bar almost constantly. It rests right on the sharp angle at the bottom of the key.
Offline Moosecraft
  • HHKB Pro
« Reply #21 on: Sun, 25 August 2013, 14:34:06 »
Well during gaming too :P
Offline zoolzoo
« Reply #22 on: Sun, 25 August 2013, 16:29:59 »
I just threw my trusty IMSTO space on there. It matches the grey WYSE mods, problem solved. :}
Offline cassist
« Reply #23 on: Mon, 26 August 2013, 10:06:46 »
The solution is simple guys: hit space with your index finger ;)
plu ml87, poker2
« Reply #24 on: Mon, 26 August 2013, 10:31:14 »
It is a great all around universal, black, spacebar.  I use it on my custom keyboard and it is just chunky and awesome.  I'd probably use something nicer if I ever found it, but I love the shape.
