Author Topic: PC Specs thread!  (Read 113711 times)
Offline AndyCapets
  • I have a French ANSI keyboard, kiss me now.
    • YouTube!
PC Specs thread!
« on: Tue, 03 September 2013, 06:42:00 »
It's been a while since there hasn't been a thread like this, how about making a new one ?
You can post a picture of your rig if you want :D
I'll start:
MSI Z87 MPower MAX
i5-4670k @stock 3.4ghz
CM Hyper 212 Evo w/ 2 x Thermalright TY-147
Kingston HyperX Beast 2x4gb 1866MHZ CL9
Seagate Barracuda 1TB 7200RPM
Gainward Phantom GTX 770 2GB
Lepa G750W PSU
Corsair Carbide 500R Artic White w/ 2 x Noctuas NF-S12A
I don't I like broccoli.
Offline Tym
Offline AndyCapets
    • YouTube!
Re: PC Specs thread!
« Reply #2 on: Tue, 03 September 2013, 07:40:13 »
http://geekhack.org/index.php?topic=36067.0
http://geekhack.org/index.php?topic=33167.0
First one is pretty dead, second one is desk tour, I only want PC specs, but well whatever.
Offline vun
  • Just one more thing
« Reply #3 on: Tue, 03 September 2013, 07:45:07 »
If the first one is dead then you revive it as this is not really a time-sensitive topic.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Tue, 03 September 2013, 08:13:49 »
Last post was less than a month ago.
You should definitely post in that thread, and post more pictures. I'd like to see that case from other angles.
« Reply #5 on: Tue, 03 September 2013, 12:25:15 »
I'll start:
MSI Z87 MPower MAX
Lepa G750W PSU
bad choices righ der'
Gtx770 is really slow for what they're charging
750 watt on that rig, you're losing power efficiency because your peak load probably is less than 450watt.
and your overclock is laughable..
Complete waste of k-series cpu + good oc-capable motherboard
« Reply #6 on: Tue, 03 September 2013, 12:48:51 »
An example of a well thought out Gaming PC
7970 $250 on sale - $50 worth of games = ~$200
performs around 95% as fast as a 770 for HALF its price.
4670k is good, but it needs to be at 4.8ghz, which is its standard overclock
delid, and you're good on nearly any aftermarket air-cooler, to reach 4.8.
600 watt psu, because haswell doesn't eat much power
Offline badcop
  • thorpe thocking master race
« Reply #7 on: Tue, 03 September 2013, 12:51:25 »
TP what are you running these days?
Offline Tym
« Reply #8 on: Tue, 03 September 2013, 12:53:54 »
On open case, very expensive SLi gfx card, power'd by ErgoDox
« Reply #9 on: Tue, 03 September 2013, 13:02:42 »
Here's my rig
Code: [Select]
i7 2600k
Corsair H100 push/pull
4x4GB Corsair Vengeance
2x EVGA 560ti 448 Classified
1tb Caviar Black
500gb Caviar Black
Corsair HX1050
Corsair 800D
All fans are Corsair AF or SP
The cable extensions are Bitfenix Alchemy
Offline badcop
« Reply #10 on: Tue, 03 September 2013, 13:07:17 »
Here's my rig
Code: [Select]
i7 2600k
1tb Caviar Black
500gb Caviar Black
Corsair HX1050
Corsair 800D
that looks really good.  would you mind posting your cable management?  I'm looking into to getting those extensions but i dont have any more room on the back side of my 650 D.
« Reply #11 on: Tue, 03 September 2013, 13:09:58 »
I don't have any pics of my cable management, sorry. Put it this way.. The side panel isn't flat anymore.. :))
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #12 on: Tue, 03 September 2013, 13:11:09 »
i7 2700k
Asuz Max 4 genez
8gb Dominator ram @ 1600
128gb SSD
6950(had xfire)--switching to 2 580
ax1200 PS(overkill)
Full custom water loop
Corsair 600d(going to order the Caselabs S5 this week)
-Enzo Ferrari
Offline badcop
« Reply #13 on: Tue, 03 September 2013, 13:13:36 »
lol good.  i'm not the only one.  i'm almost to the point where I sit on mine to get it closed.
Offline esoomenona
  • Gnillort?
« Reply #14 on: Tue, 03 September 2013, 13:30:47 »
Front -
Back -
Offline oscillik
    • music podcasts
« Reply #15 on: Tue, 03 September 2013, 13:46:31 »
sorry for bad picture (can't get the whole case in shot properly)
Corsair Obsidian 900D
H110 all in one cooler (push/pull config)
Intel Core i7-3970x
Corsair Dominator GT 32GB RAM
Corsair Neutron GTX 240MB SSD
various hard disks of different sizes
EVGA GTX Titan
all fans are Noctua 140mm, except those on the back of the drive cages which are 120mm Noctuas
I do plan on putting a proper watercooling loop in here, but I found this site so....yeah....
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline vun
« Reply #16 on: Tue, 03 September 2013, 13:49:53 »
Just putting this out there; did everyone miss the part about there already being a thread for this? The thread isn't even 2 pages, it's not that much to read...
Offline oscillik
    • music podcasts
« Reply #17 on: Tue, 03 September 2013, 13:58:22 »
ahh, sorry :(
wonder if a mod can merge?
Offline Tym
« Reply #18 on: Tue, 03 September 2013, 14:04:26 »
No point, just repost your stuff over there
Offline concept73
« Reply #19 on: Mon, 09 September 2013, 09:04:38 »
Pics up later:
Case labs S3
i7 2600k
Asrock b75m
Sapphire 7970
CM 850w hybrid
120GB kingston ssd
2tb WD HDD
8GB Corsair LP
Full custom waterloop with ek blocks.
Second build.
Parvum custom case
Max V Gene
I5 3570k
Corsair 16GB lp
Palit 3GB 580
1TB wd HDD
Poker 2 with reds
Soon to be a JD40 with reds
Offline damorgue
    • Personal portfolio
« Reply #20 on: Mon, 09 September 2013, 09:36:00 »
Palit 3GB 580
Is this rig new, and if so, where did you get a 580 3GB?
I have been searching for one to upgrade my 1.5GB for a while now but they are freaking rare around here and quite sought after. There are almost no cards which are better for certain applications other than the Titan.
I would kill maim someone for a 580 3GB.
I would kill for a Titan.
Offline concept73
« Reply #21 on: Mon, 09 September 2013, 10:05:43 »
Palit 3GB 580
I bought it for my brothers rig about a year ago, but since he loves his netbook it barly got used, so its been used for about 100-150 hours total
i used it to test it for 5 mins and still works perfectly, so its currently sat connected to my "second rig" which i need a power supply and its a complete system :)
But yeah i looked at benchmarks and its on par with my 3GB 7970 and waterblocks for it are cheap as chips!
Poker 2 with reds
« Reply #22 on: Mon, 09 September 2013, 10:11:34 »
doesn't matter..
I don't care what people keep telling me, 5ghz sandybridge is not enough..
I'm going to drive my ass up to microcenter this black friday and GO Haswell, and get a 3rd 7970 for 3x cfx.
Offline concept73
« Reply #23 on: Mon, 09 September 2013, 10:24:13 »
doesn't matter..
BUT HASWEL IS CRAP AND JUST GETS SO HOT!
Poker 2 with reds
Offline damorgue
« Reply #24 on: Mon, 09 September 2013, 13:48:36 »
Insane that it beats the entire 6-series and up to 780. I recon it is one of few cards where the 3GB version costs more than double that of the 1.5GB. So sad decided to get the 1.5GB back then.
« Reply #25 on: Mon, 09 September 2013, 16:45:09 »
Too lazy to post pics.
i5-2500k @ 4.4
Hyper 212+
ASRock Z68 Extreme3
8GB G.Skill
XFX 6870
Seasonic 620w PSU
1TB WD black drive (bought during height of inflation, so $160ish)
HAF 912
Optical Drive
Some fans and a fan controller
Bought with peripherals (QFR, deathadder (now dead), 21 inch acer monitor, QCK mini, headset) cost me $1600ish.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #26 on: Mon, 09 September 2013, 19:52:26 »
HERE ARE THE SPECS OF THE LAPTOP I'M ON RIGHT NOW:
COMPUTER: COMPAQ LTE ELITE 4/40 CX
PROCESSOR: INTEL i486, 40MHZ
MEMORY: 20MB
DISK DRIVES: 384MB HARD DISK AND 1.44MB FLOPPY (FLOPPY DRIVE'S BROKE)
OPERATING SYSTEM: WINDOWS 95
GRAPHICS: VGA
MONITOR: 7" LCD
I PUT A WIRELESS CARD IN A PCMCIA SLOT SO I CAN ACCESS THE INTERNET THROUGH MSIE5.5.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #27 on: Mon, 09 September 2013, 20:04:21 »
Is it a DX2/40?  I have a Toshiba T1950CT somewhere with that processor, but it has a mildly accelerated video card.
Overton130, Box Pale Blues.
Offline Tarzan
  • formerly known as Greystoke
« Reply #28 on: Mon, 09 September 2013, 20:37:18 »
I've got a DX2-66 in storage, I think I modded it to DX2-100*.  Has 640Mb of disc storage, but that needed two hard drives.   :eek:
(*DX4-100? Something like that.)
« Reply #29 on: Tue, 10 September 2013, 16:13:10 »
Nothing crazy, goal was to build it for 1k or less almost 2 years ago. Maybe time to upgrade some things:
Corsair 500R
i5 2500k oc to 3.9GHz
16GB DDR3
MSI GTX560ti Twin Frozr II 2Gb
Western Digital Black 1Tb
x2 240Gb Corsair Force SSD
Soundblaster X-FI Titanium
« Reply #30 on: Tue, 10 September 2013, 19:31:28 »
nope, it's just a straight 486. a little slow, but it runs good and reliably.
i recently got ahold of an upgraded compaq laptop with a 512mb hard disk, 9" screen, and a 75mhz 486/dx2...now i just gotta get a memory card reader so i can transfer network drivers onto it since its floppy drive is broke too.
Offline Altis
« Reply #31 on: Tue, 10 September 2013, 22:04:46 »
Intel Q6600 2.4 GHz Quad-Core (2007)
Radeon HD6850
4 GB DDR2 RAM.....
Come to think of it, my keyboards cost more than my computer.
Just as well!  Still runs modern games like a champ (granted that's mostly due to the video card).  Reinstalling Windows 7 every 6-12 months helps, too.
I want to upgrade motherboard/ram/cpu, but the need isn't there until it starts performing poorly..... hmm... I really just want USB 3.
Offline keymaster
  • Topre Revolution Theorist
« Reply #32 on: Tue, 10 September 2013, 22:36:04 »
The graphics card has an aftermarket cooler installed which keeps the temperatures 30C+ cooler than with the stock fans. I built this PC back in early 2011 and I'm wholly satisfied with it. I'm not much of a gamer, but I'm able to play SC2 and Path of Exile on max settings with smooth visuals -- which is all I wanted.
That being said, this PC should last me at least 4-5 more years. My next computer purchase will most likely be a slim All-in-One PC since I'm not a fan of how huge this NZXT Phantom case is.
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #33 on: Wed, 11 September 2013, 08:03:19 »
Gigabyte GA-78LMT-USB3 (cheap m-atx mother board)
AMD FX 4100 at 3.6GHz boosts to 3.8 (stock)
8GB of 1333MHz Kingston black edition RAM
AMD HD7770 1GB
500GB WD blue HDD
OCZ 600W power supply
Poor mans gaming PC :p. It is good enough for me right now.
Offline concept73
« Reply #34 on: Wed, 11 September 2013, 09:28:23 »
AMD HD7770 1GB
500GB WD blue HDD
If it works for you then its good enough :)
i have a nice computer but not great keyboards and keycaps compared to most people in this forum ;)
Poker 2 with reds
Offline baldgye
  • Will Smith Disciple
« Reply #35 on: Wed, 11 September 2013, 09:38:41 »
My PC is nothing special but it plays the **** I play @ 1920x1200 at pretty high spec's;
Processor - Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz (8 CPUs), ~4.0GHz
Memory - 6144MB RAM
Hard Drive - 160GB SDD // 1TB // 2x500GB
Motherboard - ASUS P5N-E SLI
Operating System - Windows 7 Home Premium 64-bit
Video Card - AMD Radeon HD 6970
Keyboard - Filco Majestouch-2, NKR, Cherry MX Blue + Clack
Mouse - Steelseries Sensei (RAW Rubber)
Mouse Surface - Razer Team Liquid Mat
Mouse Bungee - Official Mouse Bungee (Yellow)
Computer Case - Antec sucka
Offline Tarzan
« Reply #36 on: Wed, 11 September 2013, 09:41:24 »
Just out of curiousity, what are people using to connect multiple hard drives?
I've got an Asus motherboard with 8 SATA ports, but two are those weird Marvell ports, and two are SATAII, leaving only four SATAIII ports.  I've got two SSDs and four 2TB HDDs, plus the optical drive, so even though there are plenty of places to mount the drives in the case, I run out of connectors on the mobo.
Anyone use RAID controller cards, or external storage arrays?
Offline PadawanGeek
« Reply #37 on: Sat, 14 September 2013, 10:46:05 »
Some of my pics are older, never did bother to take newer pics since I've quit the speedy rig game....more into keyboards these days. Anyway, main rig -
LGA2011 i7 3960X @4.5ghz
Corsair H100 + 2x Corsair Performance SP fans
Asus Rampage IV Extreme
4x 4GB Corsair Dominator Platinum 2133mhz
3x HD7970 CFX
120GB Corsair ForceGT SSD (OS)
2TB + 2x 1TB WDC Black (Storage)
Seasonic X-1250 PSU
Tt Level 10GT Black chassis
Topre RF 103UB-55G/yellow PBT key caps + Keycool 84 LED Black + Roccat Kone XTD
64bit Win7 HP SP1
(pic below was when I had only 2 sticks of Dom Plat, was waiting for seller to restock)
This was with the Corsair Lightbar mod
2nd rig:
AMD FX8350 @4,5ghz
CM Hyper 412 Slim + 120mm Corsair SP Performance fan
Asus Crosshair V Formula
4x 4GB RipJawsX 2133mhz
2x GTX670 SLi
120GB ForceGT SSD (OS)
1TB WDC Black + 1.5TB WDC Green + 500GB WDC Blue
Corsair HX1050 PSU
Corsair Obsidian 650D
HHKB Pro 2 White + Leopold FC660M Clear + Logitech G9
64bit Win7 Pro SP1
3rd Rig:
LGA775 C2Q X9650 @3.7ghz
TRUE 120 + Corsair SP Performance fan
Asus Maximus II Formula
2x 2GB KHX PC2 8500
Sapphire HD6990 + MSI HD6970 Lightning CFX
120GB Force 3 SSD (OS)
1TB WDC Black + 2x 500GB WDC Blue (Storage)
SilverStone OP1000 PSU
NZXT Phantom 410 Red
Topre Type Heaven/blue PBT key caps + CM Storm Xornet
64bit Win7 HP SP1
(Older pic, this was when I'd just acquire the HD6970 Lightning, was testing stability and such)
« Last Edit: Sat, 14 September 2013, 10:48:04 by PadawanGeek »
« Reply #38 on: Sat, 14 September 2013, 20:04:56 »
I USE IDE CABLES. MOST OF MY MOTHERBOARDS COME WITH 4 IDE PORTS, WHICH I USUALLY HOOK UP 1 CD DRIVE, 1 ZIP DRIVE, AND 2 HARD DISKS WITH.
« Reply #39 on: Sun, 15 September 2013, 03:50:57 »
Only trolls use Zip drives.  They are evil.  Click of death and all that.  I have Zip drives in my QuickSilver Macs.  So there.
Offline Reomero
  • Manual breather
« Reply #40 on: Sun, 15 September 2013, 05:23:24 »
Nothing special:
  • EVGA GTX660 SC
  • Gigabyte G1.Sniper M3 (got this second-hand pretty cheap, and the above-average onboard audio is a nice bonus)
  • Intel i5 3570K @ 4.5Ghz (@1.19V)
  • CM Hyper 212 EVO
  • Corsair LP 2x4GB 1600
  • Samsung 840 250GB
  • WD Blue 1TB x2
  • Antec HCG-520
  • Silverstone TJ08-E
  • SteelSeries Sensei + Glothiathus Control
  • Leopold FC700R (graphite + blank white PBT w/ ghetto modded spacebar)
« Reply #41 on: Sun, 15 September 2013, 05:48:56 »
All these people with dustless PC's. How do you keep it that way, mine looks dustier than a mummy's butthole after just a week or so.
Offline badcop
« Reply #42 on: Sun, 15 September 2013, 06:17:18 »
Get some filters and a can of air. Blow it out every couple of weeks.
Offline Masterchief79
« Reply #43 on: Sun, 15 September 2013, 06:29:58 »
My main PC:
i7-3770K@4,7GHz@1,26V
Gigabyte Z77X-UD3H
8GB AData DDR3 2200MHz
XFX HD7970@1300/1600@1,25V
~2TB HDDs + 64GB Crucial SSD on Windows 8
1350W Enermax Max Revo PSU (actually my benching PSU I now have in use 24/7 there and it's a little overkill^^)
Fiio E10 Headphone Amplifier with Sennheiser HD600 headphones
CPU and GPU watercooled by Mora 2 Pro 1080 radiator
Second system I'm currently building at my parents house (it's a little project just for fun, building a now very cheap PC with 3-4 old, former Highend hardware, I will keep it below 300€ in TOTAL including all parts and watercooling):
i7 950
Asus Rampage 2 Extreme
6GB Corsair Dominator GT 2000MHz CL7 (MNH-E Hyper Chips)
(still looking for GFX, maybe GTX260 I have laying around till I find a decent GTX480 SLI or something)
700W Seasonic PSU
+ some parts I have laying around, like HDDs, but nothing special there.
CPU, Mainboard, graphics cards and even RAM will all be watercooled. Parts are all there and just need to be assembled in a few days.
« Last Edit: Sun, 15 September 2013, 06:35:50 by Masterchief79 »
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
« Reply #44 on: Sun, 15 September 2013, 06:32:14 »
Oops, quote instead of Modify, please delete this^^
« Last Edit: Sun, 15 September 2013, 06:36:21 by Masterchief79 »
Offline daerid
    • Rossipedia
« Reply #45 on: Sun, 15 September 2013, 11:08:31 »
My work rig's got the 3970X in it and 48GB of RAM, but the vid card's only a 3gb 660ti (it is for work after all). Don't remember exactly what the mobo is, but the case is the white Corsair 600T.
Only pic I have:
« Last Edit: Sun, 15 September 2013, 11:10:08 by daerid »
Offline Dubsgalore
« Reply #46 on: Sun, 15 September 2013, 11:33:57 »
i5 3570k
Hyper 212 plus CPU cooler
GA-z77x-ud3h
8gb ddr3 1600
1tb 7200 rpm
Gigabyte 7950 3gb
Phantom 410
500w atx12v (rip, rip)
win 8 (**** ye)
Asus ve228H 21.5" 1080 - actually looking for a portrait monitor to go on the left side of my main monitor..not sure where to start
Deathadder 2013
QCK+ mousepad
Offline kaotikb
« Reply #47 on: Sun, 15 September 2013, 19:40:15 »
I built a new system two months ago.
Intel i7 4770k
Swiftech H320 cpu water cooler
16Gb Corsair low profile ram
Gigabyte z87x-ud3h motherboard
Evga Gtx 770 SuperClocked with ACX cooler
Intel 150gb ssd drive
CoolerMaster HAF-X case
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline MTManiac
« Reply #48 on: Mon, 16 September 2013, 10:44:15 »
Radeon HD6850
4 GB DDR2 RAM.....
I have a 6600 sitting at 3.2 with 8GB RAM and a 7870
There's nothing I can't run, it even runs crysis, just not on max settings but is there a machine that can???
I agree, the only thing I am missing is usb 3.0 but I don't really miss is since I upgraded my hard drives to samsung 840 pros
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #49 on: Mon, 16 September 2013, 11:07:37 »
Pretty dated, gonna upgrade GFX next month...
_____________________________________________________________
Case: Lian Li PC-343B [Modded] / Lian Li BZ-U07B Multi-Panel USB 3.0 / 5x Lian Li EX-332B HDD-Rack / 8x Noctua NF-P12 120mm @ 900 RPM
PSU: Corsair AX750
CPU: Intel Core i7-2600 / Noctua NH-U12P SE2 [2x 120mm @ 900 RPM]
RAM: 2x 8GB Corsair Vengeance / DDR3 / 1600MHz
Mobo: ASUS P8P67 PRO S1155 ATX
HDDs: 7x 2TB WD Caviar Black + 2x 2TB WD Caviar Green + 2x 3TB WD Red
Video: Gainward GeForce GTX570 Phantom GDDR5
Displays: EIZO HD2442W / 24" / 1920x1200 + Dell U2412M / 24" / 1920x1200
DAC: Teac UD-H01
Power Amp: Yamaha AX10
Headphone Amp: Teac HA-501
Parametric EQ: Kenwood GE 1001
Speakers: 2x NuBox 381 + nuBox AW-441 Subwoofer
Cans: Denon AH-D2000 (RIP) / Sony MDR7506 (RIP) / Beyerdynamic DT 770 Pro 250 / Beyerdynamic DT 770 Pro 80 / Beyerdynamic DT 880 Pro 250 / Ultrasone Pro 900 / Ultrasone HFI-580 / ...
DVD/Blu-Ray: LG CH10LS20
Mouse: Logitech G9x / Razer Deathadder BE
Keyboard: HHKB2, KBC Poker [Ergo-Clear Cherry MX switches, Engraved KBC PBT Keyscaps, Neon Green Aluminium Casing]
Tablet: Wacom Intuos 4 Medium
Gamepad: Sony Dual Shock 2 Controller
Arcade Stick: Mad Catz Super Street Fighter IV FightStick Tournament Edition (Dictator Artwork, Custom Plexi, Red Buttons/Balltop)
UPS: APC Backup-UPS Pro 900
Printer: Canon Pixma iP5300
NET: 16MBit DSL
OS: Microsoft Windows 7 Ultimate 64bit
« Last Edit: Mon, 16 September 2013, 11:40:13 by TheSoulhunter »
A Ghost From The Past
