Author Topic: How to properly press backspace and right shift key?  (Read 30449 times)
Offline Neo.X
« on: Tue, 03 September 2013, 15:39:13 »
After buying so many keyboards, I just realized that I can't even type properly.  :(
When I press the backspace and right shift, I bent my right hand wrist and that hurts the wrist after typing for while.  :(
Any suggestion for the proper way to press those keys?
Thanks in advance.
All those keyboards will be lost in time....
Offline eth0s
  • Peace & Love
Re: How to properly press backspace and right shift key?
« Reply #1 on: Tue, 03 September 2013, 15:46:47 »
Thanks in advance.
Well, you are supposed to be using just your right pinky finger to press R. Shift key and the Backspace key.
The alternative, if you have small hands is twist your wrist as you are doing, or to pivot your whole arm from the shoulder, removing your right hand from the home row, and using you ring finger or middle finger.  This is not optimal, as it causes more fatigue and slower typing, but might be your best solution.
Offline tbc
« Reply #2 on: Wed, 04 September 2013, 00:04:44 »
turn caps lock into backspace ;) will blow your mind :)
Offline ComradeSniper
  • HHKB Pro
« Reply #3 on: Wed, 04 September 2013, 00:14:32 »
I like this idea a lot. Would be a bit difficult to get used to but I think it would be super nice in the long run.
Offline Tony
« Reply #4 on: Wed, 04 September 2013, 00:50:11 »
Exactly. As a Colemak user, I appreciate this additional Backspace.
For shifts, you have to alternate your hand, i.e. press left shift when you need the right uppercase KEYS, and vice versa.
« Last Edit: Wed, 04 September 2013, 00:52:06 by Tony »
« Reply #5 on: Wed, 04 September 2013, 01:27:56 »
Noooooooooooooooooooooooooooooooooooooooooo...
ok...
On standard staggered qwerty keyboard do the following
turn "  ;  "  colon/semicolon-key into right shift
turn capslock into right-ctrl
turn ] key into back space along with \ key..  so you have 2 backspace keys that you can rock for double speed backspacing.
Offline daerid
    • Rossipedia
« Reply #6 on: Wed, 04 September 2013, 08:29:40 »
 :)) You never cease to amaze TP.
Personally, my pinky isn't long enough to reach backspace without moving my wrists, so I just hit it with my right ring finger. R Shift is pinky all th way
Offline Neo.X
« Reply #7 on: Wed, 04 September 2013, 08:37:12 »
I am in the same situation, I use ring finger to press the backspace. But in order to do this, I have to twist/bent my wrist and that's the hurt comes from.
I think I will try map the caplock to backspace to see how it goes.
Thanks all for the help.
« Reply #8 on: Wed, 04 September 2013, 09:06:42 »
I'm telling you the brackets [ ]  and forward-slash \  use all 3 keys for backspace..
The reason you want to use \ is because it's easier to find since it's at the end.
the reason you want to use []  is because it's closer to your ring finger, and you can backspace right away without having to lift you hands, and just use your ring finger...
you can move the [] to the bottom where right-ctrl and right-alt is.. since those are seldom used...
Offline Glenn315
  • Hey
« Reply #9 on: Wed, 04 September 2013, 09:39:09 »
A lot of people prefer capslock as an alternate to shift, but I still use both of my pinky's to press both backspace and shift.
Offline Neo.X
« Reply #10 on: Wed, 04 September 2013, 09:56:22 »
Using [] as the backspace actually makes more sense since I am used to use my right hand for backspace. I will give it a try, thanks
Offline jonathanyu
« Reply #11 on: Wed, 04 September 2013, 20:28:31 »
My situation is similar to you. I have a small hand, I can't use my pinky finger or ring finger to press to backspace. So I use my middle finger to press the backspace. I think one possible solution is change "/" to backspace .
Offline goobus
  • HHKB Elite
« Reply #12 on: Wed, 04 September 2013, 21:44:03 »
So how will you type question marks??
Offline jonathanyu
« Reply #13 on: Wed, 04 September 2013, 21:48:07 »
oh, my bed. I mean "\". I switch "\" and backspace
« Reply #14 on: Wed, 04 September 2013, 21:49:55 »
change  backspace to question mark...
There are so many uncommonly used keys that you can switch around...
think outside the box.. in this case, the layout that's been give to you.
People look at a keyboard, and they often don't think it's possible to rearrange it, because they see it as a fixed thing.
This is not true...  windows key remapper tool
