Author Topic: Deck Hassium up at MechKB  (Read 17059 times)
Offline dante
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Deck Hassium up at MechKB
« Reply #1 on: Thu, 05 September 2013, 18:13:49 »
Definitely the last keyboard I would ever need/ want :D
Offline Danule
« Reply #2 on: Thu, 05 September 2013, 18:22:42 »
if they use sculpted keys they it might be nice, other than that font.
45g Brown Brown Blue
Offline PointyFox
« Reply #3 on: Thu, 05 September 2013, 18:30:14 »
What's with the prices on mechanical keyboards?  Sure a lot of people are stupid, but enough to run a business off of?
Offline MechKB
    • MechKB
« Reply #4 on: Thu, 05 September 2013, 19:20:05 »
Hello all, noticed some traffic coming from here, thought we'd make an account to answer questions :)
Just to note, we are an Australian operation. By (Australian) law our publicly displayed prices must include a 10% Goods and Services Tax. On top of this, the current exchange rate is from Australian Dollar to US Dollar is ~1.12 AUD to USD. Granted it's still not 'cheap' but may help put prices into perspective.
Deck Hassiums use true doubleshot PBT key caps. We carried out our own experiments on the matter here: http://mechkb.tumblr.com/post/59664045773/our-stock-of-deck-hassiums-are-genuine-pbt-doubleshot, which I believe was linked in another thread. I believe they are the only manufacturers on the market currently mass producing Doubleshot PBT backlight compatible key caps, so in that respect they do command a price premium... 'unconventional' font notwithstanding. :P
Offline dante
« Reply #5 on: Thu, 05 September 2013, 19:23:55 »
MechKB:
Deck never gave a straight answer on whether the original Legend/82 was even assembled in the US.  Where are these new keyboards made?
Any idea when the Francium will make it to your site?
Can you explain the naming of these boards?
Offline MechKB
    • MechKB
« Reply #6 on: Thu, 05 September 2013, 19:36:40 »
MechKB:
It's remarkably hard to find the "made in" information for Deck. The Hassium boxes and the reverse of the Hassium itself coyly states: "Designed in the USA". I would hazard a guess that if it was actually made in the US, it would say so. I'll see if I can chase this piece of information up in a bit, but just as fair warning, I may be gagged by management from revealing this. If I had to guess now, I would say the are made either in Taiwan or in China.
Franciums will not be making it to our site as there are no new production runs of the Francium. That doesn't mean that there won't be a TKL from Deck. I definitely not allowed to say more then this  :-X
EDIT: I should clarify on the Franciums, there aren't any new production runs of the Francium in their present function set.
« Last Edit: Thu, 05 September 2013, 19:38:28 by MechKB »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #7 on: Fri, 06 September 2013, 00:24:28 »
TG3 (which is Deck) has a very wide range of keyboard offerings so I'd rate it very likely that they use multiple sources for parts and final assembly. For example, AFAIK the only facility doing double-shot PBT is in Taiwan, but they might be having the PCBs or controllers made in China or Malaysia.
You'd probably have to look at the customs papertrail for a given shipment to determine where the final assembly was done for a specific model. Now, that said, TG3 does as a point of order and for a fact, do a substantial amount of manufacturing in the United States proper and has for 7+ years. The Deck has always been made in Kenosha, WI. (AMC gearheads unite!) TG3 has facilities in China and Hong Kong as well. It wouldn't make a great deal of sense for them to just dump the Kenosha line - it's a 45K sqft facility! - even with discontinuing the Deck, but that doesn't mean it's making the Hassium necessarily.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline MechKB
    • MechKB
« Reply #8 on: Fri, 06 September 2013, 00:54:15 »
<snip>
Our Deck Hassiums are shipped out of HK :)
<snip>
Sorry Dante, forgot to answer your last question. Hassium and Francium are both elements on the periodic table with the numbers 108 and 87 respectively. I guess you can figure out the rest from there :)
Offline jonathanyu
« Reply #9 on: Fri, 06 September 2013, 01:35:36 »
Is this pbt double shot? Hope that there are pbt double shot that in cherry legend
Offline MechKB
    • MechKB
« Reply #10 on: Fri, 06 September 2013, 01:39:49 »
Yes it is :) Refer to our paint thinner test here: http://mechkb.tumblr.com/post/59664045773/our-stock-of-deck-hassiums-are-genuine-pbt-doubleshot
There's also links to hi-res pictures of the key caps.
We spoke with Deck regarding their font when the Hassiums first landed. Our feedback was that changing the tooling to print a new font for Double-shot PBT was cost prohibitive and they were very reluctant to do it :(
Offline skuko
« Reply #11 on: Fri, 06 September 2013, 01:46:19 »
dat font....*cringe*
« Reply #12 on: Fri, 06 September 2013, 01:59:15 »
Well... the good news is.. more pbt..
Bad news,  It's still not an ergodox... FAIL.....
Offline Obakemono
« Reply #13 on: Fri, 06 September 2013, 03:53:50 »
Hey, those PBT double-shot backlit keycaps sound interesting, any chance of buying just the keyset??  :p
Offline dante
« Reply #14 on: Fri, 06 September 2013, 10:14:07 »
There are always TG3's on ebay for good prices.  If the font bothers you and the profile is the same you could at least swap most of the alpha keys.
Offline rootwyrm
    • My Website!
« Reply #15 on: Fri, 06 September 2013, 12:30:04 »
Then I'd wager they're built at the HK facility rather than Kenosha. (Not totally surprising.) As long as the build quality's up to par, though, really doesn't matter too much where they're made.
Offline Danule
« Reply #16 on: Fri, 06 September 2013, 12:59:49 »
are they keys flat or contoured on this new keyboard?
Offline Topre
« Reply #17 on: Fri, 06 September 2013, 15:04:51 »
Contoured.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #18 on: Fri, 06 September 2013, 15:23:49 »
Now we're at 2/2 of all the double shot PBT available with ugly fonts.  We're doomed.......
Offline Lu_e
« Reply #19 on: Fri, 06 September 2013, 16:11:58 »
Contoured.
How can you be sure? their old keyboard were all the same profile... which would be flat.
& why is there 4 of, basically, the same picture of the keyboard? Really makes me wanna buy, that with the fact its not even on Decks website...
Just say NO to ABS keycaps
Offline Topre
« Reply #20 on: Fri, 06 September 2013, 16:20:31 »
Contoured.
Because they changed their molds? These double shot keycaps are not the same as the old Deck keycaps. From the pictures that MechKB posted of the paint thinner test, most of the keycaps were from different rows and they were clearly different sized. Unless if my eyes are playing tricks on me, then I highly doubt it's flat.
It actually is on Deck's website, but it's not available for ordering right now. The pictures that Deck has also shows the difference in profile of each row of keycaps.
Offline Danule
« Reply #21 on: Fri, 06 September 2013, 17:09:17 »
If i were to ever get a backlit id probably go with this. Looks quite nice. I also like how this and the wasd desings are looking more and more like filco.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #22 on: Fri, 06 September 2013, 18:06:16 »
Why is that font so ugly though x.x
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline MechKB
    • MechKB
« Reply #23 on: Sat, 07 September 2013, 01:37:26 »
I think contoured, definitely not flat.
Contoured.
There's four pictures at the same angle because we took the pictures ourselves and all the front-on images were out of focus. If it bothers you that much, I'll ask the guy in the office who takes photos to take some more photos on Monday, we probably should anyhow. Is there any other angles that you or anyone else would like to request? :P
We might do a full teardown and take more photos. Deck told us that the Hassiums have been in production for a little while so we were under the impression that people knew about the Hassium already but based on our current feedback here and elsewhere on the internet, it seems the first run of Hassiums went into Korea and the board itself is still mostly an unknown in the English speaking world. So I think a teardown might be profitable in that sense... We might need a bit of time to work on this though.
Offline Hyde
« Reply #24 on: Sat, 07 September 2013, 16:47:41 »
Crayon scribble font is Deck's trademark since forever.
Offline MechKB
    • MechKB
« Reply #25 on: Tue, 10 September 2013, 00:05:31 »
Ok, we updated the product images a bit and done a teardown which you can find here: http://imgur.com/a/o8szw . Feedback + request for different angles, etc. Please let me know. Sorry for the slight necro.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #26 on: Sun, 06 October 2013, 17:04:19 »
Thx for the info.  need to identify
Offline Danule
« Reply #27 on: Sun, 06 October 2013, 18:09:15 »
that PCB looks very nice.
