Author Topic: Videos of how to do LED mod?  (Read 3102 times)
Offline Chase5delta
  • Keyboardoholic
« on: Sun, 08 September 2013, 00:46:17 »
I want to add LED's to my poker but I am not exactly sure how to, is there a good quality video showing how to properly do it? Thanks.
Filco MJ2 TKL (Mx Blues) Keycool 84 (Mx Reds)
Offline PointyFox
Re: Videos of how to do LED mod?
« Reply #1 on: Sun, 08 September 2013, 00:52:52 »
Not sure, but I assume you're talking about the Poker 2.  There are 2 pre-soldered holes for each lead from the LED for each switch.  They're the close together ones.  One hole is circular, and one is square.  The square hole is for the longer lead of the LED.  Desolder those holes, stick the LEDs through, solder them, then snip the extra lead sticking out.
« Reply #2 on: Sun, 08 September 2013, 00:53:59 »
hahahahahaha.. u crazy.
Just sell what you got, and buy it..
Offline PointyFox
« Reply #3 on: Sun, 08 September 2013, 00:56:39 »
You could send it to me and I'll solder them if you pay shipping both ways + $15 for time and materials, if you don't feel like doing it yourself or finding a pre-LEDed one to buy.
Offline Chase5delta
  • Keyboardoholic
« Reply #4 on: Sun, 08 September 2013, 00:59:27 »
PM'd for more info :D
Offline PointyFox
« Reply #5 on: Sun, 08 September 2013, 01:04:11 »
Gotta make sure you have the right kind of LEDs.  I think the forward voltage should be around 3.0-3.2v.  I tried LEDs from a TG3 keyboard and they didn't work.  Not sure what their voltage was.
Here's a pic of my Poker 2 with LEDs (I only put them under the white keys, excluding space bar) :
Offline naokira
  • The King in the North
« Reply #6 on: Sun, 08 September 2013, 01:22:01 »
Hey, can you use the led brightness up and down with this?
FaceW in LZ-CE
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Sun, 08 September 2013, 06:00:30 »
*deleted
« Last Edit: Sun, 08 September 2013, 06:02:20 by terran5992 »
Offline terran5992
« Reply #8 on: Sun, 08 September 2013, 06:01:50 »
I don't think so, unless you hook up an led controller
[/quote]
