Author Topic: MX Blues with Red Springs?  (Read 3966 times)
Offline Linkbane
« on: Sun, 29 September 2013, 13:23:54 »
So I really like the feel of Blues, and their pressure, and I don't need them to be lower at all. But I wonder, has anyone tried putting in lighter springs (MX Red or non-Cherry) into blues, and how did it feel? I can imagine something being really light and tactile, which I might like. Any experience with modded blues? There are always ghetto greens (already have greens), but it seems like there's very little modding done to Blues.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline JPG
  • Model F is my new passion!
Re: MX Blues with Red Springs?
« Reply #1 on: Sun, 29 September 2013, 13:24:46 »
Blues and reds have same spring. But there are some softer spring (customs) like 55g
Offline Linkbane
« Reply #2 on: Sun, 29 September 2013, 13:30:23 »
If I am not drastically mistaken, the Blue uses 50g and the Red uses 45g, both of which are softer than 55g.
« Reply #3 on: Sun, 29 September 2013, 13:31:16 »
Theyre the same spring. The stem in the Blue switch is two parts and causes the Blue switch to have a slightly heavier actuation.
Offline Linkbane
« Reply #4 on: Sun, 29 September 2013, 13:33:02 »
Ah, I see then. Would the function of the stem cause a lighter spring to not have much of an effect, or have there been experiments with  this?
Offline ComradeSniper
  • HHKB Pro
« Reply #5 on: Sun, 29 September 2013, 13:44:05 »
Korean custom spring weight is measured at bottom out rather than at actuation like Cherry springs, so 55g Korean springs are ever so slightly lighter than MX Blue/Brown/Red springs.
To me it feels like lighter springs lessen the tactility and the click of MX Blues.
« Last Edit: Sun, 29 September 2013, 13:45:44 by ComradeSniper »
Offline Linkbane
« Reply #6 on: Sun, 29 September 2013, 14:44:34 »
Hrm, I'm so uninformed. I was thinking that because the Greens have as much tactility (or only a bit more) than Blues, that a lighter spring would retain it. If it doesn't then that would invalidate why I was thinking of it. Thanks for the info everyone!
« Reply #7 on: Sun, 29 September 2013, 14:48:28 »
Green and blues have the same stem and slider. The spring is what makes it different.
Offline PointyFox
« Reply #8 on: Sun, 29 September 2013, 14:48:50 »
The spring force is responsible for the click, and slightly for the tactility.
Offline laffindude
« Reply #9 on: Mon, 30 September 2013, 23:27:50 »
Incorrect. The slider is forced down by one of the contact leaves. You can get the click without a spring inside the switch.
« Reply #10 on: Mon, 30 September 2013, 23:30:28 »
I can confirm spring is not needed for a click.
« Reply #11 on: Mon, 30 September 2013, 23:37:45 »
this thread hurts my head q-q
i love you all
  • HHKB Pro
« Reply #12 on: Tue, 01 October 2013, 01:08:39 »
I'm trying to figure out why lighter springs would make the click any less noticeable, because it doesn't seem like springs should have anything to do with the click, but I am certain that they do one way or another.
Does the amount of resistance from the spring end up forcing the leaf in the switch down harder? I am totally guessing at this point.
« Last Edit: Tue, 01 October 2013, 01:11:07 by ComradeSniper »
Offline terran5992
  • One With The Cup Rubber
« Reply #13 on: Tue, 01 October 2013, 03:42:02 »
I belive that they are the same weight. Get panda blues, blue stems with black springs
« Reply #14 on: Tue, 01 October 2013, 06:44:03 »
blue stems with black springs are ghetto greens :P
Offline phx
« Reply #15 on: Tue, 01 October 2013, 08:51:51 »
I have a set of 45g springs on the way from Originative, was thinking about swapping it into my browns since I prefer lighter switches.
will also try it on some blue switches
Offline Linkbane
« Reply #16 on: Tue, 01 October 2013, 11:16:54 »
Cool, tell me how the feel of the blues are?  :D
« Reply #17 on: Tue, 01 October 2013, 11:19:42 »
best blue spring? 65g korean.  :-*
« Reply #18 on: Tue, 01 October 2013, 11:26:11 »
That's awfully close to the OEM spring, isn't it?  Hardly seems worth it.
« Reply #19 on: Tue, 01 October 2013, 12:12:34 »
it makes a difference in the long run.
You lose 5g
Offline Linkbane
« Reply #20 on: Tue, 01 October 2013, 12:30:40 »
You lose 5g
Wow, I'm sure he didn't realize that. Thanks!
OT: Of course it makes a difference, it's just minor and seems hardly worth swapping an entire switch out for.
Offline phx
« Reply #21 on: Tue, 01 October 2013, 13:09:01 »
meh I recently swapped 55g into my Brown.
the difference is not noticeable. 55g is slightly heavier
hence the reason of buying 45g springs.
