Author Topic: Windows7 N Issues  (Read 2279 times)
Offline Fragil1ty
  • Abre los ojos.
Windows7 N Issues
« on: Sat, 19 October 2013, 08:12:44 »
So I recently reformatted my computer, maybe a little over a week or so ago and I hadn't got around to installing any updates or whatever, so I thought, it's time to do so.
I went ahead and downloaded the Media package for Windows 7 N as that's the version that I have and Windows Media Player is not included, I don't use it but apparently it needs to be installed for certain games to run which makes absolutely no sense to me, but heh, it is what it is.
So I went ahead and installed all of the updates and what not and my main C:/ drive is that of a 120GB SSD drive and prior to this, I had a good amount of space left because all that was installed on said C:/ drive was Adobe Master Collection and Microsoft Office, so I had about a good 60-75GB spare.
I installed all the updates that were available to myself at that time and then I proceeded to install this media package, it started to hang and not install like previously before and before long it stated that I had no space left on my HDD which I thought was incredibly weird as it had plenty prior to this.
I seem to have found the culprit as to where all of my space has gone and vanished from.
But to cut a long story short.
1. What the hell has happened to my SSD.
2. Is there any option to fix this issue short of re-installing the entire OS again.
3. fml
你搞砸了
Re: Windows7 N Issues
« Reply #1 on: Sat, 19 October 2013, 08:14:38 »
have you cleaned out all restore points?
try running a disk cleanup on your C: drive
start type in box disk cleanup, it'll pop up showing if there's things you can remove
Offline Fragil1ty
  • Abre los ojos.
« Reply #2 on: Sat, 19 October 2013, 08:18:02 »
Just did this, nice suggestion btw, it didn't really cross my mind. But erm, it only cleaned ouit  800mb of space, better than nothing though.
你搞砸了
« Reply #3 on: Sat, 19 October 2013, 09:00:30 »
Maybe try this
http://www.uderzo.it/main_products/space_sniffer/
It gives you a graphical represenation of what's taking up space, you can find out what part of the windows folder is so huge, my windows folder is only ~26Gb for reference
« Reply #4 on: Sat, 19 October 2013, 10:13:11 »
3. fml
WTF?
That's a picture of a FOLDER named  C?
go to my computers and right click on the Drive Icon.. and click properties... all your 120gb should be there...
« Reply #5 on: Sat, 19 October 2013, 10:18:13 »
3. fml
WTF?
It says Windows....right in the box....
« Reply #6 on: Sat, 19 October 2013, 10:24:50 »
3. fml
WTF?
yea.. that's a FOLDER named windows.. not the Drive..
Offline Fragil1ty
  • Abre los ojos.
« Reply #7 on: Sat, 19 October 2013, 10:25:01 »
3. fml
WTF?
I'm going to ignore this stupidity.
Maybe try this
I actually got this referred to me also by a friend, I launched it and inside I found 3 text files.
One was 32gb, one was 28gb and one was 3gb. Deleted them all and all is well.
Thank you very much for your help. :)
你搞砸了
« Reply #8 on: Sat, 19 October 2013, 10:26:34 »
idk bout you.. My "DRIVE" looks like this...
You're looking at a folder... the WINDOWS folder under your C:\ Drive....
So your space didnt' disappear... It was "used up" You probably have some malware or warez installer that generated those huge txt files..
Offline Fragil1ty
  • Abre los ojos.
« Reply #9 on: Sat, 19 October 2013, 10:58:08 »
Right I'm going to address this because you're obviously VERY confused.
The 'space' WAS NOT used up what so ever and if you read my previous post that I posted prior to this one, I had 3 files, "One was 32gb, one was 28gb and one was 3gb" that I found using the program provided here called "Space Sniffer".
I have no malwhere or ad-aware/warez etc, It was generated during my Windows updates.
And I provided you a screenshot of my Windows folder because that what was all the space was being used up. C:\Windows
I hope this clears up any confusion, lol.
你搞砸了
