Author Topic: Looking for a Keyboard  (Read 2011 times)
Offline acidtrip69
« on: Sun, 20 October 2013, 16:42:39 »
Ok, I'm looking for this keyboard. Does anyone know were to get one other then this place because they are sold out there. Also if anyone knows if someone is selling theres ? It has to be the same spacial edition with cheery mx clears.
http://www.banggood.com/Keycool-87-White-Mechanical-Gaming-Keyboard-Cherry-MX-Clear-Switch-p-89115.html
« Last Edit: Sun, 20 October 2013, 16:51:06 by acidtrip69 »
Re: Looking for a Keyboard
« Reply #1 on: Sun, 20 October 2013, 16:53:39 »
Are you desperately seeking MX Clear?
You may want to consider MX Blue, as far as tactility goes.. Blue "feel similar" to clears..
And most of the time.. "Stock Clears (non-modded)"  as opposed to ErgoClears are way too heavy..
MX blue is still the king of tactility.
Offline acidtrip69
« Reply #2 on: Sun, 20 October 2013, 16:57:50 »
I all ready have keyboard with mx blues ^_^ its a Ducky dk90008G2 pro with ptb with dye sub legends ^_^
« Reply #3 on: Sun, 20 October 2013, 17:07:15 »
ppssssssh.... You're done... MX clear is a bit.... over hyped...
And for the majority of the users, they type with the "resting wrist" technique, which isn't compatible with stock clears..
That's a whole 3-4 hours worth of soldering to swap a whole tkl in Ergo-clears
Offline acidtrip69
« Reply #4 on: Sun, 20 October 2013, 17:16:18 »
I'm asking to were to find the keyboard I'm looking for. I'm NOT asking you for your ****ING opinion on the switches. If your not going to help GTFO. sorry i had to be mean about it, but your are not helping here.
« Last Edit: Sun, 20 October 2013, 17:29:39 by acidtrip69 »
« Reply #5 on: Sun, 20 October 2013, 18:05:22 »
Wow, ur awfully rude..
well, taobao if you want an exact mx clear keyboard "NOW"..
otherwise, there's the Deck with Clears for $200
« Reply #6 on: Sun, 20 October 2013, 18:14:27 »
qtan (a vendor here) sells KeyCool, but doesn't seem to have any of this particular one in stock.
You might post in his vendor forum.
Or check his online store.
Offline Linkbane
« Reply #7 on: Sun, 20 October 2013, 18:16:56 »
TS/OP please calm yourself, he's giving some advice. He's not telling you that you shouldn't get Clears, he's just advising that they might be rather underwhelming when you do get them.
Anyways, nobody else was posting between the time tp posted his stuff and you raging at him, so you're obviously not losing any information because nobody has posted anything until rowdy did afterward,
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline acidtrip69
« Reply #8 on: Tue, 22 October 2013, 22:17:01 »
does anyone else know were i can get one ?
