Author Topic: What's Bothering You? (The thread about what is bothering you.)  (Read 7897357 times)
0 Members and 13 Guests are viewing this topic.
Re: What's Bothering You? (The thread about what is bothering you.)
« Reply #23950 on: Sun, 18 February 2018, 10:55:00 »
Got a piezo buzzer, supposedly 3-36v.  Motherboard pins of course aren't breadboard pin compatible so had to hold SIP sockets soldered to the buzzer on the pins.  Result?  No beeps.  Stuck it on 5v from a Teensy and I can just about make out a high frequency whine, which won't be audible over the pump let alone a fan...  Liking the resistor idea!
This is exciting..  you're one step closer to buying a new computer.. !!
Although, maybe want to wait till they fix that meltdown thing..
« Reply #23951 on: Sun, 18 February 2018, 12:13:42 »
Reseated the cpu - no change.  Flashed the latest beta bios - no change.  Flashed back to stable bios - haven't seen anything on the screen since, GPU or not.
I do have beeps (flashes) now though, two of them.  That's 'parity error' so the RAM is dead?  Take out one stick - no change.  Swap to the other one - no change.  Put both in channel 2 - no change.
Put RAM in another computer, boots up just fine... Now to wait a couple of hours for memtest to confirm the RAM is not damaged, then I can put the RAM from this slow machine into the 'broken' one and see what happens.
What a waste of a day.
I was without this computer for most of last year, had to use an i3 3xxx.  Was really looking forward to having some speed but before I know it it starts acting up again...
Last upgrade was depressing and no way I'm buying broken hardware, I'll just have to find a new hobby.  Or maybe a 16 hour a day job.
« Reply #23952 on: Sun, 18 February 2018, 12:25:19 »
Hrrrrmmm..
weird stuff.. did you put the bios reset jumper back in the right position after reset ?  or is it a push button model
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #23953 on: Sun, 18 February 2018, 12:36:13 »
oi
« Reply #23954 on: Sun, 18 February 2018, 16:18:13 »
Hrrrrmmm..
It's a jumper and it's back where it should be.
3.5 hours later the RAM has tested fine at nearly it's rated speed so looks like the motherboard, just like last time.
« Reply #23955 on: Sun, 18 February 2018, 16:22:13 »
Hrrrrmmm..
which motherboard
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #23956 on: Sun, 18 February 2018, 16:25:42 »
Hrrrrmmm..
Sad news. Hate to see that happen to an otherwise useable PC :(
« Reply #23957 on: Sun, 18 February 2018, 16:51:18 »
which motherboard
Asrock Z97M Formula OC
It's bad when it's an old trusty friend but I wouldn't be exaggerating if I said I doubt I used this board for 50 hours since I bought it.  This was the second board for the CPU after I blamed the first for not working well, but maybe it was the CPU all along...
Offline Kavik
« Reply #23958 on: Mon, 19 February 2018, 01:13:20 »
I desoldered my Magicforce numpad because I didn't really care for the Gateron Blacks in it and because I was curious to try out Gateron Greens. I think I like the greens even less than the blacks, so it was all for naught, but I don't care enough to desolder again. Maybe they just suck because it has a plastic plate.
At least, I got some practice desoldering and some exposure to desoldering in-switch LEDs (a minor PITA).
« Reply #23959 on: Mon, 19 February 2018, 05:23:00 »
New day, new error - 6 'beeps' which means keyboard error.  Needless to say I have a selection of keyboards but it doesn't like any of them!
Message sent to a guy who does replacement bios chips on eBay, the first and last money I'm throwing at the problem.
« Reply #23960 on: Mon, 19 February 2018, 05:59:20 »
Ur labor exceeds replacement board cost at this point..
« Reply #23961 on: Mon, 19 February 2018, 06:29:13 »
If you can find a board that's Broadwell compatible out of the box - I struggled in 2016 and no-one's made any since then.  And that's assuming it is the motherboard not a delayed objection to my delidding the CPU...  To replace both you're looking at about 36 hours at my last payrate, I'm not there yet.
« Reply #23962 on: Mon, 19 February 2018, 06:46:33 »
 still can't report threads/posts using tapatalk...... :eek:
« Reply #23963 on: Mon, 19 February 2018, 12:32:43 »
Well with the 5775c, you don't need z97..
anything'll do at this point..
Delid is kewl..   "Effort"
« Reply #23964 on: Mon, 19 February 2018, 14:20:54 »
Delid, watercool then run at stock clocks?  I guess it will still be slightly quicker than the old i3 :)) Thanks for pointing out an obvious option I'd not considered!
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #23965 on: Mon, 19 February 2018, 14:48:29 »
What to do when sad?
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #23967 on: Mon, 19 February 2018, 15:23:55 »
Shoppppping !!!
No.
Go lift weights or exercise in some way.
Offline Signature
  • master of puppers
  • snoozing
« Reply #23968 on: Mon, 19 February 2018, 15:27:23 »
Offline naveed
« Reply #23969 on: Wed, 21 February 2018, 14:30:42 »
The trend of laptop keyboards losing keys like Page Up/Down, Insert, Delete, Home and End.
« Reply #23970 on: Thu, 22 February 2018, 22:27:43 »
BEE SCAMMED ME
« Reply #23971 on: Thu, 22 February 2018, 22:37:28 »
I never have time for video games anymore.
BEE SCAMMED ME
DID YOU EXPECT ANYTHING DIFFERENT?
« Reply #23972 on: Thu, 22 February 2018, 22:58:50 »
BEE SCAMMED ME
// Gasp..
// Drama of the century unfolds..
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #23973 on: Thu, 22 February 2018, 23:55:18 »
My favourite six keys on a board. Okay five, not including Insert.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #23974 on: Fri, 23 February 2018, 04:26:37 »
Same.
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #23975 on: Fri, 23 February 2018, 08:25:41 »
BEE SCAMMED ME
// Gasp..
I can't beelieve it. Sifo's been honeypotted
« Reply #23976 on: Fri, 23 February 2018, 11:09:15 »
// Gasp..
I told ya'll to be careful round them females..  They are raised to be crafty
Offline sncbraxsc2
« Reply #23977 on: Fri, 23 February 2018, 12:15:26 »
// Gasp..
I will not conform!!!  :mad:
For the lips of a strange woman drop as an honeycomb, and her mouth is smoother than oil
But her end is bitter as wormwood, sharp as a two-edged sword.
« Reply #23978 on: Fri, 23 February 2018, 12:29:49 »
Religion..
// Der's ur problem..
Offline sncbraxsc2
« Reply #23979 on: Fri, 23 February 2018, 12:40:12 »
Religion..
You better had washed your hands!
Eh, its a problem of my past but it isn't as if absolutely NO good comes from it. Some morals at least..
I just thought the verse was mildly relevant
« Reply #23980 on: Fri, 23 February 2018, 12:53:36 »
Religion is overall good and well intention-ed,   But then the capitalists got their hands on it.. annnnd it was all down hill from there.
The riff-raff people IN religion is the problem.. Not Religion itself..
Offline sncbraxsc2
« Reply #23981 on: Fri, 23 February 2018, 13:16:16 »
I can definitely agree with that. These mega churches springing up all over the place... Sad that so many are looking for something to believe in - anything apart from their self!...
Now my biggest issue in refuting religion is the lack of knowledge about how life came from non-life. That is something that bothers me
« Reply #23982 on: Fri, 23 February 2018, 13:30:47 »
Futurama handled this the best.. Season 6, e 9, A Clockwork Origin
Creationism vs Evolution does not fundamentally conflict..
So, again, where's the problem..  PEOPLE < these guys > ruin everything.
Offline sncbraxsc2
« Reply #23983 on: Fri, 23 February 2018, 13:37:31 »
I'll watch that tonight.
Isn't the answer to it all just.. Alienss...? like Elon Musk?
« Reply #23984 on: Fri, 23 February 2018, 13:44:57 »
Worry greatly about the Musk..
He's as close to the second coming of jesus we're going to get..
And he's become really puddgy, and we know he's not on 100% veggie.. He's approaching a dangerous age where diabetus/heart disease creep up..   ontop of the 2000% elevated cancer risk from meat products.. sigh....
« Reply #23985 on: Fri, 23 February 2018, 14:28:31 »
It didn't come from magic, that's for sure.
There is no problem with religion as long as it doesn't poke its nose where it doesn't belong, such as into science or politics.
https://www.nbcnews.com/mach/science/universe-conscious-ncna772956
https://www.quora.com/Is-the-Universe-the-sentient-repository-of-all-intelligence-and-the-creator-of-a-physical-illusion-that-each-of-sense-as-a-body
https://www.amazon.com/Embryos-Galaxies-Sentient-Beings-Universe/dp/1556434197
- D Trump 2026-10-24
« Reply #23986 on: Fri, 23 February 2018, 14:41:26 »
Fohat reads but does not think..
Your links tout, Universal consciousness/connectedness, that would INCLUDE all human politics and human sciences which occur in that universe.
Therefore from the <Human perspective> what does not belong, is the certainty that something may or may not belong,  Rather than any one thing truly belonging , because such a relationship can not be known from bottom up frame analysis.
Certainty may exist in the Universe, but it's not knowable to the humans that attempt to perceive it.
Offline sncbraxsc2
« Reply #23987 on: Fri, 23 February 2018, 15:03:23 »
Thanks for the material and perspective.
Yes, at least, I'm pretty sure its not magic xD Accio life! I know its a fallacy to fill a gap with a similarly unsound argument of creation even if it does not fundamentally conflict with certain ideas of creation. I am unfortunately familiar with the Christian perspective of this lack of conflict only.
Therefore from the <Human perspective> what does not belong, is the the certainty that something may or may not belong,  Rather than any one thing truly belonging , because such a relationship can not be known from bottom up frame analysis.
What do you think truly belongs, TP?
Offline sncbraxsc2
« Reply #23988 on: Fri, 23 February 2018, 15:05:35 »
And I know you know this because you do not have the <<Human Perspective>>
« Reply #23989 on: Fri, 23 February 2018, 15:24:09 »
Well, we MAY HAVE certainty, which is the same as uncertainty..  That is all we are ever capable of, when we are ourselves the smaller object perceiving a larger one.
Offline sncbraxsc2
« Reply #23990 on: Fri, 23 February 2018, 16:10:50 »
Ty, makes sense.
Sounds a lot like those nihilistic beliefs people have that one can create their own destiny. I can agree with it in an activist or self-improvement sense but not much more
If you don't mind my asking your thoughts on where creation and evolution don't conflict, I am curious... Even if the gist comes in the form of a link  :thumb:
Offline Carcharocles
    • The Deathscape Mythos
« Reply #23991 on: Fri, 23 February 2018, 16:46:49 »
Discharged a little more than four hours ago from a liver biopsy (nothing serious, a confirmation for a study I'm taking part in). Immediately called Logisticare (medicaid transport service) and spend about two hours waiting for a driver who kept telling us "I'll be there in 30 minutes."
Finally got into my ride... at which point he spent another hour picking up other people and dropping them off. Okay, fine, it's not a taxi service, right? Well, despite knowing I'm having surgery, I have to open a heavy ass sliding door myself (he has a switch in the front seat that opens them automatically), and then he hits every curb, pit, pothole and speed bump along the way.
Then we get stuck on the highway, at which point he briefly went off the road.
I finally got home 30 minutes or so ago.
Did I mention every time he turned or corrected he did so with a sudden, sharp jerk? My insides feel like jello now.
T1000 , Firmware ver. Doge.
Most deadly of them all.
« Reply #23992 on: Fri, 23 February 2018, 17:11:37 »
What was the liver biopsy for, what are they looking for ?
« Reply #23993 on: Fri, 23 February 2018, 17:36:14 »
Confirmation that I have cirrhosis from NASH (nonalcoholic steateohepatitis). I've already been diagnosed with it, but this is to be sure that it's not something genetic instead (I'll be taking part in a study soon for a medication that is thought to decrease fatty cells in the liver as well as cirrhosis).
« Reply #23994 on: Sat, 24 February 2018, 16:24:38 »
Dumb Uber and Lyft drivers who don't have enough brain cells to rub together to use just a sliver of common sense. Just because the GPS shows you where to go does not mean it's always correct. This dumb ***** drove past 3 highway exits 2 entire towns north of my destination just to loop around and head all the way south again on surface streets. When I asked why she drove me 10 mins out of the way she said "That's what the GPS told me to do."
You ignorant time-wasting ****. All you had to do was think about it for 1 second and say, "Wait, maybe I should take ANY of these other exits first."
tldr: stupid people putting all their trust into technology without using a shred of common sense.
« Reply #23995 on: Sat, 24 February 2018, 16:28:21 »
do you get charged extra for that ?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #23996 on: Sat, 24 February 2018, 17:24:50 »
Damn Uber and Lyft passengers who don't have enough brain cells to rub together to use just a sliver of common sense. Just because you know every square inch of the place you are going does not mean your driver does. As a driver, I follow my GPS because sometimes I have no idea where your destination is. The GPS often takes you the fastest or shortest route, so maybe you could save 1-2 minutes going another way but typically there's little savings anyways. If you require your driver to know every possible route without GPS, hail a taxi.
Offline sncbraxsc2
« Reply #23997 on: Mon, 26 February 2018, 10:56:15 »
I hope the studies you are taking part in will be helpful to you or ease some of the issues you deal with. That driver (as well as so many others on the road) was really inconsiderate. I hope there's a system where you can leave some type of review about it.
lol'd
I mean, coulda had a word, y'know? Like, "Hey, you missed the quickest exit back there, you should take this one and let the GPS re-adjust the route.
Offline rich1051414
« Reply #23998 on: Mon, 26 February 2018, 15:46:27 »
I switched to AMD after my 4790k and it's overheating issues because of the TIM... I refuse to use another intel processor until they start soldering the lid on again. Garbage. They are a ticking time bomb with TIM, once it drys and stops conducting heat well. With that processor, I also used 3 different motherboards because they all kept malfunctioning, mostly on the data bus, where sata ports would start dying, along with USB ports. Time will tell if I suffer similar problems on Ryzen, but so far, I have had none of the issues that plagued my haswell systems(though initially there were a few issues that were fixed in bios updates).
« Reply #23999 on: Tue, 27 February 2018, 02:22:17 »
^ I never used two boards with a CPU until they added the weedy 'pins' in the socket rather than proper straight ones on the CPU, coincidence?  Not sure, but my next build will be AMD once they've fixed the bugs and then if I bother.
I'm bothered by the all too familiar emptiness - not quite suicidal nihilism as I still put the feelings of others first so have no choice but to got on, but as I don't know what I want I don't have the distracted amusement that passes for pleasure in the present while chasing, nor the satisfaction of achieving to look forward to.  All there is is meaningless existence spotted with emotional requests for support which I cannot respond to in an appropriate way, which makes me feel subhuman.
