Author Topic: WASDKeyboard Red  (Read 2906 times)
Offline uzoc
WASDKeyboard Red
« on: Fri, 08 November 2013, 15:01:04 »
I love WASDKeyboards Red color.
Does anyone know what the color it is?
Tried the keyboard color chooser: http://lab.cubiq.org/kbcc/#RR,WFK,WFK,NN
I see geekhack likes it also (it's the color in the favicon).
Also any other sources for this color probably side printed?
Re: WASDKeyboard Red
« Reply #1 on: Fri, 08 November 2013, 16:51:43 »
You can only get engraved or laser-burned keys from WASD Keyboards. No white legends, and no side-printing.
I don't have any colour samples from Signature Plastics to compare with ..
If you want to have side-printed caps, have you considered putting stickers or water-slide decals on them yourself?
Offline uzoc
« Reply #2 on: Fri, 08 November 2013, 17:48:33 »
I am familiar with keytop stickers (and use them on some keyboards).
But "stickers or water-slide decals"... do you know of any sources?
Offline vun
  • Just one more thing
« Reply #3 on: Fri, 08 November 2013, 18:27:36 »
I know water decals are often used in model building, I'd suggest checking nearby hobby shops or see if you find anything online.
Offline uzoc
« Reply #4 on: Fri, 08 November 2013, 18:42:26 »
Also, any other sources for this color probably side printed?
« Reply #5 on: Fri, 08 November 2013, 20:32:25 »
You can get the "gold keyboard stickers"   and then CUT THEM OUT with an xacto..  time intensive but looks very cool, because it has a 3d look when you put it on the side of the keycaps.
« Reply #6 on: Fri, 08 November 2013, 23:52:14 »
Unless they've changed the colour since I got my Sampler Kit, the WASD red is a bit pinkier than, say, SP red.
WASD red is in the middle:
43228-0
(Yes, Rowdy tinkers with red keycaps too, just not quite as much as yellow.)
Offline uzoc
« Reply #7 on: Sat, 09 November 2013, 07:58:15 »
Thanks for the comparison pic!
