Author Topic: Best and Brighest LEDs for Poker 2  (Read 2253 times)
Offline stancato9
« on: Fri, 08 November 2013, 17:25:04 »
Can someone direct me to the best / brightest white LEDs for my Poker 2 mod. I see the rectangle ones are super popular but I'd like a second opinion. Thanks!
Poker 2 - MX Red
Offline stancato9
Re: Best and Brighest LEDs for Poker 2
« Reply #1 on: Fri, 08 November 2013, 17:30:14 »
Poker 2 - MX Red
Offline MKULTRA
  • telling it how it is
« Reply #2 on: Fri, 08 November 2013, 17:31:14 »
Whatever you get make sure you have the right resistors.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #3 on: Fri, 08 November 2013, 17:35:49 »
you can get whatever cheap leds you want, but if you want the best and the brightest, you will be hard pressed to beat a cree.
Im not going to do all the leg work for you, but here, have a poke around
http://www.mouser.com/Cree-Inc/Optoelectronics/LED-Lighting/LED-Emitters/_/N-8usfd?P=1yzs6io&Keyword=led&FS=True
just as an fyi, the highpower crees are probably way too much for a keyboard. unless you want it to glow like the sun i guess.
"Obviously, windows are central to Windows. But what is a window?"
Offline stancato9
« Reply #4 on: Fri, 08 November 2013, 17:38:40 »
Thanks for the link, but those look a little overkill for me :p
Poker 2 - MX Red
Offline stancato9
« Reply #5 on: Fri, 08 November 2013, 17:40:08 »
I thought with the Poker 2 you didn't have to add resistors? I could be wrong though.
Poker 2 - MX Red
Offline Photoelectric
« Reply #6 on: Fri, 08 November 2013, 17:47:51 »
Just look for "2x3x4 color name LED" on eBay.  Most of those should be fine.
