Author Topic: Some Mandarin help please? (HPE 87 Mk2)  (Read 1494 times)
Offline dante
« on: Sat, 09 November 2013, 23:00:34 »
http://item.taobao.com/item.htm?spm=a230r.1.14.342.g1TLtE&id=14736354761
Can someone translate if this is a revision?  I also see "POM" listed - is this the replacement for the ABS caps?
Thanks  ;D
Offline Larken
Re: Some Mandarin help please? (HPE 87 Mk2)
« Reply #1 on: Sat, 09 November 2013, 23:32:57 »
it says laser engraved pom for the caps.
| Ergodox #1 | Ergodox #2 |
« Reply #2 on: Sun, 10 November 2013, 15:44:18 »
from the pictures... even if it's pom engraved, it's still white goop in-filled.. which means the white part will turn grey over time.. or yellowy gray...   so... the POM really isn't the issue here.. yes it may be slightly better than abs, but in this case... the laser engrave is still not durable in terms of looking sharp..
