Author Topic: Where can I find cheap caps with Korean legends?  (Read 3504 times)
Offline Candyflip
« on: Sun, 10 November 2013, 05:06:55 »
Anyone know where can I find a cheap set can be tkl, either way needs to ship to EU and reasonable price?
Edit: doesn't matter if pbt or abs
Re: Where can I find cheap caps with Korean legends?
« Reply #1 on: Sun, 10 November 2013, 06:26:17 »
You sure you "need" korean legends? or is it just a fun-fun thing..
I believe the vendio store "qtan" has access..
Offline longweight
  • philanthropist
« Reply #2 on: Sun, 10 November 2013, 06:37:33 »
What has that got to do with anything?
« Reply #3 on: Sun, 10 November 2013, 06:53:06 »
because the closest "thick pbt" set is $90, and that's only the 37 key.. it seems excessive unless you really "need" it..
And I recall korean is alphabet based.. so it should be quite easily touch typed.
Offline Candyflip
« Reply #4 on: Sun, 10 November 2013, 08:09:24 »
well I don't need expensive pbt, just a cheap abs MX compatible set to get used to touch typing.
« Reply #5 on: Sun, 10 November 2013, 08:11:33 »
buy the stickers then... when you max out your corean touch typing skill tree.. pell them off.. and look Pr0 using blank caps
Offline Candyflip
« Reply #6 on: Sun, 10 November 2013, 08:20:34 »
That might be it, can you link any of these I can't seem to findn any  :confused:
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Sun, 10 November 2013, 21:11:21 »
Look for LG Cherry G80-8929LPBKO on used market, especially taobao can often find them for very cheap under $35.
« Last Edit: Sun, 10 November 2013, 21:15:27 by IvanIvanovich »
