Author Topic: Where can i find replacement keycaps for the 3 hole stabilizer keys?  (Read 4059 times)
Offline ValerieV
The new Poker and some other keyboards use the 3 hole keycap stabilizers and i love them because they are so easy to change up with. However, i was wondering where i can find replacement keycaps for those. Elitekeyboards doesn't, as they only sell the old stabilizer keycaps. Thanks so much.
Offline PointyFox
Re: Where can i find replacement keycaps for the 3 hole stabilizer keys?
« Reply #1 on: Sun, 10 November 2013, 10:12:35 »
The keycaps are the same.  The stabilized ones have stabilizer inserts which can be pulled out of the two side holes, leaving 3 holes.
Offline ValerieV
« Reply #2 on: Sun, 10 November 2013, 10:49:24 »
So than the Caps Lock key would fit on my Poker as it would a Filco? Thanks.
Online tp4tissue
« Reply #3 on: Sun, 10 November 2013, 11:02:15 »
as long as the holes are spaced the same they'd fit..
the spacebar on leopold has holes in different spacing vs a filco.
the caps lock key is usually centered today, but it "could" be different, but not likely.
Offline ValerieV
« Reply #4 on: Sun, 10 November 2013, 11:37:28 »
Okay thanks. I bought the mx reds keycaps from elite keyboards. i am a little nervous about replacing the spacebar on the poker because that, i think, has the metal stabilizer and it may be difficult for me to do. The size of the spacebar seems to match the replacement one. Thanks.
« Reply #5 on: Sun, 10 November 2013, 14:00:18 »
The first time is always the worst.  As long as you go slowly and carefully, you should be fine.
One trick is to remove both Alt keys, then gently lever the space bar up from both sides, moving it very gently from side to side.
Offline ValerieV
« Reply #6 on: Sun, 10 November 2013, 14:37:28 »
I will try but i have done it once before and it took me a few days to get it right. I don't know if i can do it again but i am going to try.  :thumb:
Online tp4tissue
« Reply #7 on: Sun, 10 November 2013, 15:29:54 »
days?  if it's sloosh-ee, the plastic space bar is probably slightly warped..  follow the standard warp procedure to fix that.
and poker is standard space bar.. it should all fit.
Offline iAmAhab
  • Established member
« Reply #8 on: Sun, 10 November 2013, 15:55:25 »
Offline ValerieV
« Reply #9 on: Sun, 10 November 2013, 16:51:31 »
No i had trouble getting one side in the plastic wire holder without the other side coming out. It took me several attempts to finally get it. It made a funny sound until i fixed it just right.
Offline ValerieV
« Reply #10 on: Sun, 10 November 2013, 18:35:12 »
So i took off the space bar and to my pleasant surprise i found that the space bar on the Poker doesn't use that long wire. I am attaching a photo. Do you think the new spacebar would work with this? Thanks!
Offline ValerieV
« Reply #11 on: Sun, 10 November 2013, 18:35:48 »
Sorry it posted upside down but do you see what i am talking about? Thanks.
« Reply #12 on: Sun, 10 November 2013, 20:59:47 »
Cherry stabilisers - even easier to remove/replace keycaps :)
Offline terran5992
  • One With The Cup Rubber
