Author Topic: Good place to buy replacement "translucent" kepcaps?  (Read 3313 times)
Offline Doppelganger
  • Ducky DK9008G2 Pro, PBT dye subs - Cherry Browns
« on: Fri, 15 November 2013, 12:13:37 »
I just picked up a new board and would like to experiment with some ABS WASD keys for the backlighting. I've seen solid replacement ones everywhere, but were can I find see-through keys for the LED's to shine through the letter print?  I don't need a whole set, just WASD  :)
- There's never enough time to do all the nothing you want
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: Good place to buy replacement "translucent" kepcaps?
« Reply #1 on: Fri, 15 November 2013, 12:56:28 »
http://www.pimpmykeyboard.com/marketplace.php
you can choose the row and make a wasd set.
« Reply #2 on: Fri, 15 November 2013, 17:17:22 »
That looks like a great place for keyboard customization, thank you for the link  :)  I could see going a little wild with the keyboard thing with all of these options lol
Offline divito
« Reply #3 on: Fri, 15 November 2013, 17:18:55 »
Poor guy, lol.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
« Reply #5 on: Fri, 15 November 2013, 22:45:35 »
Nice, more options! Quick question about these replacement keys - I was changing out the WASD keycaps to the red ones for my backlit keys (Ducky with Cherry Browns) and they were pretty hard to press onto the board. I really had to give it some pressure to get them all the way on. I felt like I was going to damage it! Is that a concern, or is that completely normal? Could I damage something changing out key caps pressing to hard?
« Reply #6 on: Sat, 16 November 2013, 01:51:00 »
Some are too loose to get on, some are too tight.
Just be careful when you try to take them off.
VERY CAREFUL!
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #9 on: Tue, 19 November 2013, 22:25:08 »
they're honestly quite over rated...
very good for a "show case" board.. but it becomes DISGUSTING if you actually use it..
« Reply #10 on: Tue, 19 November 2013, 22:59:50 »
There's a full set on Signature Plastic's site in addition to their pimpmykeyboard site.
Offline terran5992
  • One With The Cup Rubber
« Reply #11 on: Tue, 19 November 2013, 23:41:06 »
Geek_feng sells a KBC set
