Author Topic: Thoughts on the Corsair K65?  (Read 3792 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Tue, 19 November 2013, 19:34:44 »
How does the K65 look to you guys? It looks like a board that would be a pain to mod the switches on.
Re: Thoughts on the Corsair K65?
« Reply #1 on: Tue, 19 November 2013, 19:45:08 »
If YOU like it... to hell with what anyone else thinks..
Except TP4...  TP4 thinks you should get an Eeeeeee... You should listen to TP4
Anyway.. The k65 seems much improved.. I haven't heard any firmware complaints (sticky-key).. so lets go on faith that they fixed their matrix-ing problem with the "Hacked Kro system" on their boards.
Other than that.. the volume rocker is SOLID...  in all other ways it performs identically to ANY keyboard..
Aesthetics... it's aight...  you'd have some trouble with the bottom row, but I think it'd be fine if you had a few shorter keys..  the space bar... mmm you can cut and putty your own if it comes down to perfect match..
Offline C5Allroad
« Reply #2 on: Tue, 19 November 2013, 20:03:16 »
I don't really know why I left my K90.... I really like the keycaps on it. Miss reds too. I might one of them lol.
Offline tbc
« Reply #3 on: Tue, 19 November 2013, 20:08:32 »
no leds, messed up bottom row, reds only, is TKL instead of 75%.
it's a no brainer bad-buy for ME; ALL of those independently are dealbreakers (i'm not into soldering to replace the switches)(well, TKL would be okay if it didn't have all the other defects).
benefits are:  detachable cord, GREAT aesthetic, media keys
« Reply #4 on: Tue, 19 November 2013, 20:08:42 »
at this point you should get the new version cuz of the full mechanical..
Offline C5Allroad
« Reply #5 on: Tue, 19 November 2013, 20:12:01 »
Yeah... I need money now lol. Or maybe I will buy a shine 3 TKL.....
« Reply #6 on: Tue, 19 November 2013, 20:12:33 »
or an eeeeeee
Offline C5Allroad
« Reply #7 on: Tue, 19 November 2013, 20:16:06 »
Noob question... What is an eeeeeeeee?
Offline Dreamre
    • kbdlife
« Reply #8 on: Tue, 19 November 2013, 20:48:01 »
Tp4's fav...the ergodox!
Offline C5Allroad
« Reply #10 on: Tue, 19 November 2013, 20:54:00 »
I need to know where you get these emoticons! Or something similar....
« Reply #11 on: Tue, 19 November 2013, 21:11:02 »
http://65.111.241.205/index.php?topic=47398.0
Here be the xml file for the emoticonverter.. I've attached the newest more complete version to this post. vvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
You need toolbar autohide, to put it conveniently on the bottom of ur screen..
it will look like THIS... when you click open the menu, from the bottom bar    45002-0
But with the NEW-xml file I attached, it should have all the Onion-Cat emoticons as well as the Tuzki Rabbit
Offline Dreamre
    • kbdlife
« Reply #12 on: Tue, 19 November 2013, 22:39:10 »
it will look like THIS... when you click open the menu, from the bottom bar    (Attachment Link)
That is awesome! Thanks!
« Reply #13 on: Tue, 19 November 2013, 22:58:54 »
I wouldn't buy a Corsair keyboard.  They're expensive for the quality and they have nonstandard modifier sizes which causes headaches if you want to upgrade to higher quality keycaps.
Corsair sells some nice products, but I wouldn't buy any of their peripherals.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #14 on: Tue, 19 November 2013, 23:17:36 »
I like my k95 a lot. But for the features on the k65, I would probably rather just about any other board than the corsair.
"Obviously, windows are central to Windows. But what is a window?"
Offline Mikey Mo
« Reply #15 on: Tue, 19 November 2013, 23:48:01 »
l think it is not good..how about cm storm?
Offline CorsairJames
  • * Commercial Vendor
  • Corsair Technical Marketing HID Specialist
    • Corsair Technical Resources
« Reply #16 on: Wed, 20 November 2013, 16:24:49 »
@Mikey: Why do you think its not good?
@everyone else, thanks for your feedback!
