Author Topic: Ergo-White switches?  (Read 1948 times)
Offline Linkbane
« on: Wed, 20 November 2013, 12:46:43 »
I was wondering about MX White switches, after taking a look at Ducky's things.
Has anyone ever modded Whites with light springs (brown/red/blue) or Clear springs? I'm not sure if Clear springs are the same as black, because I know of Panda switches, but otherwise does anyone have experience with lighter White switches?
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Re: Ergo-White switches?
« Reply #1 on: Wed, 20 November 2013, 12:48:00 »
There was a relatively recent discussion about them here in this thread.
« Reply #2 on: Wed, 20 November 2013, 12:56:11 »
Also fair warning, many vendors, ducky included, will advertise a 'milk' switch and it ends up being clears most of the time instead of actual whites.
« Reply #3 on: Wed, 20 November 2013, 13:04:18 »
I made up 100 of my whites with 62g springs, they are very nice, especially if you don't mind hysteresis. I'll be putting them into either my skeldon or my lightsaver.
Whites tend to be a little variable as far as sound, so if you make your own, sort them by click.
« Reply #4 on: Wed, 20 November 2013, 13:22:38 »
sorting could be difficult. the spring tension affects the click..
So I think sorting aught to be done after spring replacement, because if you sorted before hand, the swapped springs would change sonic distributions.
« Reply #5 on: Wed, 20 November 2013, 13:29:43 »
Yes, this is specifically what I recommend. Once you've replaced the springs, sort the switches and install based on your preference (I will have louder ones off the main typing area.
Offline Linkbane
« Reply #6 on: Wed, 20 November 2013, 14:58:10 »
I remembered that, probably should have gone back.
But apparently it does muffle the click more than I thought it would, so it wouldn't be what I was hoping for.
Thanks for the responses, everyone.
