Author Topic: How do I fix my Ducky's mushy spacebar and LEDs?  (Read 2288 times)
Offline openminded
« on: Wed, 20 November 2013, 17:37:09 »
So I just got my new Ducky (Non-Shine) keyboard with Red switches and I love it.
Unforunately, the spacebar is way too mushy and the Caps Lock and Num Lock LEDs are far too bright.
How would I fix the mushy spacebar to make it feel more tactile and disable the LEDS on those keys?
Thank you for reading.
Offline Photoelectric
Re: How do I fix my Ducky's mushy spacebar and LEDs?
« Reply #1 on: Wed, 20 November 2013, 17:43:55 »
You can try using a black permanent marker over the LEDs to dim them.  Mushy spacebar... not sure you can solve that easily.  Some people consider Cherry stabilizers mushy--is that what yours uses?  If so, you'd have to do some desoldering to swtich to Costar stabilizers.
Offline Reomero
  • Manual breather
« Reply #2 on: Wed, 20 November 2013, 17:59:19 »
If the stabilizers underneath the spacebar are the Cherry ones, that's probably why you think it's mushy as Photoelectric pointed out. I am aware of a mod to the stabilizers which makes them less "mushy" though, but I can't remember the thread/post.
« Reply #3 on: Wed, 20 November 2013, 18:21:17 »
Oh, that could be clipping the Cherry stabilizers.  Could search for that.
Offline openminded
« Reply #4 on: Wed, 20 November 2013, 19:05:11 »
Clipping? As in slicing open the actual wire?
« Reply #5 on: Wed, 20 November 2013, 19:06:08 »
I mean search the forum for clipping Cherry stabilizers.  There are threads for it--I'm not sure as I've never done it before.
« Reply #6 on: Wed, 20 November 2013, 19:35:34 »
lube + clip stabilizer nub..   I think it's probably also possible to just Sand the sides of the nub down a bit..
