Author Topic: ErgoDox back up on MassDrop  (Read 9774 times)
Offline daerid
    • Rossipedia
« on: Wed, 20 November 2013, 17:57:25 »
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: ErgoDox back up on MassDrop
« Reply #1 on: Wed, 20 November 2013, 17:59:05 »
GO GO GO
https://www.massdrop.com/buy/ergodox
GRR! to Ergodox or not to ergodox...Topre or ergodox... I feel like this is the time to decide..
Offline Pacifist
  • on hiatus
« Reply #2 on: Wed, 20 November 2013, 17:59:13 »
Already been posted
Offline Latin00032
« Reply #3 on: Wed, 20 November 2013, 18:20:18 »
Is massdrop down or is something else wrong?
Offline Pacifist
  • on hiatus
« Reply #4 on: Wed, 20 November 2013, 18:24:46 »
Its slow but works
« Reply #5 on: Wed, 20 November 2013, 18:44:58 »
Offline daerid
    • Rossipedia
« Reply #6 on: Wed, 20 November 2013, 19:19:14 »
« Reply #7 on: Wed, 20 November 2013, 19:33:57 »
http://geekhack.org/index.php?topic=51231
That's one hell of a discoverable thread title there
Well I immediately knew what it was...
It called to me....
My precioussss--esss
Offline Pacifist
  • on hiatus
« Reply #8 on: Wed, 20 November 2013, 19:38:19 »
It called to me....
Oh great tp
please tell me if I should get an ergodox
my wallet is empty from other keyboards, ~ $100 left
should I proceed with ergodox or no?
Offline tbc
« Reply #9 on: Wed, 20 November 2013, 19:39:45 »
ya...that was a pretty bad title;  i actually found out from reddit of all places before i found out here.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #10 on: Wed, 20 November 2013, 20:34:44 »
5th round and still using clear glossy acrylic for the top and bottom layers. shame. people are missing out.
edit
DSC_0021.jpg by almightyglod, on Flickr
looks great not clear, matte surface no finger/palm prints
FTW!
« Last Edit: Wed, 20 November 2013, 20:41:32 by Glod »
Offline Linkbane
« Reply #11 on: Wed, 20 November 2013, 20:45:30 »
edit
FTW!
Consider that most people wouldn't buy it if it was any more expensive than it is now. Anyways, who even needs the full hand? What kind of typist rests his hands when he types?
Amateurs.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #12 on: Wed, 20 November 2013, 20:47:10 »
It called to me....
Oh great tp
Of course you should - otherwise you will forever be wondering ;)
I cannot as my finances are depleted (again).
Offline divito
« Reply #13 on: Wed, 20 November 2013, 20:57:55 »
Ergonomic ones :D
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline Linkbane
« Reply #14 on: Wed, 20 November 2013, 21:30:05 »
Ergonomic ones :D
I was actually informed that not resting the hands is a better idea, and that makes a lot of sense, because you aren't placing your weight on your wrists. I never get any pain in my wrists from floating, which I used to get while resting, and I can also move my fingers much more easily.
There's no reason that resting your wrist should be good, because then you're applying more strain on your hand than just the keypresses.
Offline divito
« Reply #15 on: Wed, 20 November 2013, 21:35:27 »
Hmm, strange. I've never had RSI issues or anything of the sort, but just trying it out now, there's far more tension in my wrist when they're not resting. Actually typing like that is far more strenuous than just using my fingers to type while my wrists are on my tray.
(edit) - Could also be because of my arm rests from my chair are taking a good chunk of the weight off my wrists. Working without an arm rest would be a nightmare methinks.
« Last Edit: Wed, 20 November 2013, 21:38:05 by divito »
Offline Linkbane
« Reply #16 on: Wed, 20 November 2013, 22:24:06 »
I have something akin to RSI; whenever I type at my normal pace (over 120) for long periods, my fingers themselves feel swollen and heavy. These days' I've been practicing a little less because of that. When typing for comfort, I like to use the rests on my chairs for my elbows, but it does slow me down by anchoring me. My right arm moves a decent bid to the bottom row on Dvorak, and therefore I keep my right thumb off the spacebar to free it up. My left hand can be doing pretty much whatever, as it pretty much doesn't move.
Perhaps it's because I try to put my weight on my arms when I type, by always keeping my arms up. I keep my board at a good height, though, so it's never tiring.
I agree that when I'm not going at my maximum speed, resting is preferable. Still not sure if it's better for the wrist or not, though. Never had any problems myself either way.
Offline plainbriny
« Reply #17 on: Thu, 21 November 2013, 01:39:13 »
I just assembled an ErgoDox from local sources...  :eek:
Well, at least I can choose my case color (matte acrylic)  ;D
Also, I use plastic screws instead of metal ones, no worry for rusting  ;D
45233-0
Unfortunately, I have put the I/O expander in the wrong way, so I only got functional right part  :'(
Working on desoldering the IC. Hopefully I don't need to use the spare PCB and other parts...
« Last Edit: Thu, 21 November 2013, 01:40:46 by plainbriny »
Offline terran5992
  • One With The Cup Rubber
« Reply #18 on: Thu, 21 November 2013, 01:46:41 »
The plastic screws matches the case really well
« Reply #19 on: Thu, 21 November 2013, 03:21:18 »
Welcome to Geekhack!
Fantastic job you've done - hopefully you can get the other half working too :)
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #20 on: Thu, 21 November 2013, 06:59:22 »
Not to mention I still haven't got my one from 4th round... I think the one I'm organising will be done quicker even though I just ordered stuff recently...
« Reply #21 on: Thu, 21 November 2013, 07:07:09 »
well.. I'm certain if an Egdx buy is the "Only" one you organize, it'd be faster than massdrop. Since, they have other things to do on top.
Offline kod
« Reply #22 on: Thu, 21 November 2013, 10:28:53 »
It's very considerate of them to start another massdrop and taking people's money... before even delivering the keyboards from the last order.
At this rate, I'll be surprised if I get mine before the new year.
Offline Glod
    • YouTube Channel
« Reply #23 on: Thu, 21 November 2013, 10:30:03 »
so round 4 never arrived to people yet and they started up another one?
well that sucks.
Offline czarek
    • FalbaTech
« Reply #24 on: Thu, 21 November 2013, 15:27:54 »
Not really I placed order for 40 PCBs and I already have materials for 20 cases which will be cut after I get the PCBs, so it's certainly not the one Ergodox, and I hope I'll help some impatient people like me :)
Offline davkol
  •  Post Editing Timeout
« Reply #25 on: Sat, 23 November 2013, 14:39:37 »
I wish they made it possible to buy only certain parts as in the first/second one.
Speaking of that, is it possible to get only 1.5x and 2x PBT keycaps somewhere?
Offline Linkbane
« Reply #26 on: Sat, 23 November 2013, 15:57:54 »
ille
Offline terran5992
« Reply #27 on: Sat, 23 November 2013, 21:05:58 »
I guess you can get some from group buy extras
Offline Larken
« Reply #28 on: Sun, 24 November 2013, 01:52:18 »
You can get those at SP, at 1usd per cap. Colors and profile is limited to what they have on hand atm.
| Ergodox #1 | Ergodox #2 |
Offline babyface
« Reply #29 on: Wed, 27 November 2013, 02:14:39 »
Is anyone here able to assemble/proxy it for me for a reasonable price?
Where do you get the idea that an LZ-GH is basically a filco??
« Reply #30 on: Wed, 27 November 2013, 03:22:02 »
honestly,, just go abs and buy the 2x-size num-pad enterkey from wasd keyboards.. .. if you're gonna get anything OTHER than black.. then there's ZERO difference between pbt and abs... because shine doesn't look bad on "bright color" caps..
It really only matters if you got BLACK caps.
Offline davkol
« Reply #31 on: Wed, 27 November 2013, 05:15:39 »
sticky
Offline plainbriny
« Reply #32 on: Sat, 30 November 2013, 17:09:15 »
Thanks, I found some anodized aluminum M3 screws with variety of colors, which may be fun for further customizing the ErgoDox...
(Warning: Chinese auction page)
http://search.ruten.com.tw/search/ulist00.php?s=sincerely607&k=m3+25mm&c=0
Offline plainbriny
« Reply #33 on: Sat, 30 November 2013, 17:14:01 »
Thank you!!
And I finally make my left hand side working. After trying solder-wick, solder sucker, flux, and hot air gun... a really painful process, but it is working now!!
Next step: optimizing the layout
Offline daerid
    • Rossipedia
« Reply #34 on: Sun, 01 December 2013, 10:49:48 »
I went to my local hardware store for some M3 cap nuts ("acorn"). They were $1.70 a pop, what the hell.
Offline davkol
« Reply #35 on: Sun, 01 December 2013, 11:04:48 »
wholesale, 28 nuts for €2.4, most expensive ones around
Offline daerid
    • Rossipedia
« Reply #36 on: Sun, 01 December 2013, 11:06:50 »
I just ended up nabbing a 25 pack off Amazon for like $4
