Author Topic: Stiffer Blues?  (Read 4438 times)
Offline 1pq
  • Hipster Doofus
Stiffer Blues?
« on: Fri, 22 November 2013, 20:47:05 »
I like my MX Blue board, but it just feels too light, especially after continued usage. I believe it is lighter than most, but I was wondering if anyone has every put heavier springs in a blue switch. Not something as heavy as a green spring, but something in the middle. I imagine this would be better for typing.
Or maybe what I'm searching for are stock clears...too bad there's a shortage at the moment.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline jinxedx84
Re: Stiffer Blues?
« Reply #1 on: Fri, 22 November 2013, 20:50:44 »
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline 1pq
  • Hipster Doofus
Re: Stiffer Blues?
« Reply #2 on: Fri, 22 November 2013, 20:58:49 »
Thanks! Will I need to use a solder/desoldering iron to take apart the switches and replace the springs? My keyboard is plate mounted, I believe (Das Keyboard).
Offline jinxedx84
Re: Stiffer Blues?
« Reply #3 on: Fri, 22 November 2013, 21:03:41 »
probably need others to chime in on this, because i have blues and wanted to put 67g limited springs in, but my soldering skill are quite terrible. Now i have read you pop the top on the switch off to get to the spring with out desoldering it. but i have find a "absolute" answer about it. It seem PCB mounted switches it possible to take the switch top off, and i have seen people in videos with plate mounted switches do it.
Offline moogle
_
« Reply #4 on: Fri, 22 November 2013, 21:09:46 »
_
« Last Edit: Fri, 18 August 2017, 05:35:36 by moogle »
Offline terran5992
  • One With The Cup Rubber
Re: Stiffer Blues?
« Reply #5 on: Fri, 22 November 2013, 21:21:02 »
Yes, you will have to desolder the switches to change the springs in your das keyboard.
Yep. But doing so will void our warranty
Offline 1pq
  • Hipster Doofus
Re: Stiffer Blues?
« Reply #6 on: Fri, 22 November 2013, 21:49:44 »
Like that would stop anyone on GH  :p
Offline terran5992
Re: Stiffer Blues?
« Reply #7 on: Fri, 22 November 2013, 21:54:30 »
Haha True enough :D
Re: Stiffer Blues?
« Reply #8 on: Fri, 22 November 2013, 22:13:05 »
This is very time consuming...  what if it turns out you don't like it...  Do over... HOURS++
Offline ithinkimkorean
Re: Stiffer Blues?
« Reply #9 on: Fri, 22 November 2013, 22:13:40 »
If you have plate mounted and it's not a phantom-like plate, you need to desolder.
PCB mounted does not need to be desoldered.
Offline terran5992
Re: Stiffer Blues?
« Reply #10 on: Fri, 22 November 2013, 22:20:39 »
Building custom keyboards are the same thing. It's a gamble that you may not like it. But people still do it anyways
Offline Pacifist
  • on hiatus
Re: Stiffer Blues?
« Reply #11 on: Fri, 22 November 2013, 22:26:55 »
Its not just phantom-like plates. Its any plate with the cutouts to let the hinges on the switch cover to come out
Offline alosec
Re: Stiffer Blues?
« Reply #12 on: Fri, 22 November 2013, 22:28:07 »
correct me if I'm wrong, but I thought mx greens were stiffer blues? or do they have a different switch design?
Offline Pacifist
  • on hiatus
Re: Stiffer Blues?
« Reply #13 on: Fri, 22 November 2013, 22:29:14 »
read the op, he doesn't want greens
Offline 1pq
  • Hipster Doofus
Re: Stiffer Blues?
« Reply #14 on: Fri, 22 November 2013, 22:31:18 »
As I mentioned in the original post, from what I've heard, greens seem too heavy. I'd like something in between blues and greens as far as force.
Offline moogle
_
« Reply #15 on: Fri, 22 November 2013, 22:33:36 »
_
« Last Edit: Fri, 18 August 2017, 05:36:06 by moogle »
Offline Lycoth
Re: Stiffer Blues?
« Reply #16 on: Fri, 22 November 2013, 22:38:31 »
Agreed with this. I was originally planning on changing the switches on my Ducky Shine 2 from Browns to Whites, until I found out we're getting Shine 3 with MX Greens in the UK. But that's the only thing stopping me.
Re: Stiffer Blues?
« Reply #17 on: Sat, 23 November 2013, 03:17:47 »
Depends on which DAS keyboard. The DAS II, for example is a rebranded cherry, and as such is PCB mounted (And won't need desoldering)
