Author Topic: Bios Uefi Cmstorm quickfire TK  (Read 3893 times)
Offline spunnik
« on: Sat, 23 November 2013, 14:15:08 »
I finally bought cm storm quickfire TK with cherry MX brown FANTASTIC I'm trying for 2 weeks now is great, but I have a problem I can not get into the bios I have a P8P67 DELUXE when I turn on the pc just a light that stays on, the Num lock however, the buttons do not go and I can not get into the bios ....i try switch USB - PS2 port.
Offline Linkbane
Re: Bios Uefi Cmstorm quickfire TK
« Reply #1 on: Sat, 23 November 2013, 14:21:43 »
Wait, does that mean that you already tried switching into PS/2?
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline spunnik
« Reply #2 on: Sat, 23 November 2013, 14:25:28 »
yes, but don't work
Offline spunnik
« Reply #3 on: Sat, 23 November 2013, 17:51:41 »
anyone?
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #4 on: Sat, 23 November 2013, 18:12:05 »
Have you tried a keyboard that has PS/2 plug natively? I mean the ones that you don't have to go through some adapter.
Upon simple googling at you motherboard model I read that it is an Asus brand. To me, I have had nothing but issues with Asus motherboards, specifically at their PS/2 ports failing to detect keyboard properly. I do not recall if I had a USB keyboard at the time but if you happen to have a keyboard with PS/2 plug and that does not work then it could be a sign you are facing the same set of issue that I once have had. I recall two Asus motherboards that I had with the exact same issue. Also the keyboard was working fine elsewhere just not on the Asus motherboard for some reason.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #5 on: Sat, 23 November 2013, 18:19:58 »
i agree asus has issues with ps/2
But, I can't get away from their intuitive OC experience... With most other boards I have had to fight the bios much more.. this is from p67 on...
Offline terran5992
  • One With The Cup Rubber
« Reply #6 on: Sat, 23 November 2013, 20:58:29 »
Oh ive had a problem with my quickfire TK before . I had to use a separate keyboard just to change settings in the bios
