Author Topic: Klipsch S4i In-Ear Headphones - $35 + $5 Flat Rate Shipping  (Read 2597 times)
Offline missalaire
  • Great Finder of Great Finds
« on: Sat, 23 November 2013, 14:23:37 »
Woot.com has Klipsch Image S4i Rugged In-Ear Headphones with In-Line 3-Button Mic & Remote (blue, orange, red or yellow) for $34.99. Shipping is a flat-rate $5 for up to quantity of 3.
http://www.woot.com/offers/klipsch-s4i-rugged-in-ear-headphones-6?utm_campaign=Commission+Junction+-+10860750&utm_source=Commission+Junction+Publisher+-+1225267&utm_medium=affiliate+-+Product+Catalog
Total shipped cost
1 for $40
2 for $75
3 for $110
Offline MarkPharaoh
Re: Klipsch S4i In-Ear Headphones - $35 + $5 Flat Rate Shipping
« Reply #1 on: Sat, 23 November 2013, 16:04:43 »
Sick price, I've owned two of the regular S4 and S4i, a little bass heavy, but for $40 they're an absolute steal.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
« Reply #2 on: Sat, 23 November 2013, 19:10:20 »
now s4i is trrs.. does that mean it doesn't work for regular trs devices?
« Reply #3 on: Sat, 23 November 2013, 23:21:24 »
For all TRRS 3.5mm plugs and all TRS 3.5mm jacks I know of, the third connection will either be grounded or not connected. Either will allow the rest of the device to work normally.
So if you plug it into the TRS jack on the front of your computer you will be able to listen to music as normal, but not use the mic.
« Reply #4 on: Sun, 24 November 2013, 02:11:03 »
I've ask because a guest at my house killed my old sound card by using a trrs headset it shorted out the output..
Offline terran5992
  • One With The Cup Rubber
« Reply #5 on: Sun, 24 November 2013, 03:24:59 »
gone
Offline le_doosh
« Reply #6 on: Sun, 24 November 2013, 14:04:33 »
Hated these headphones with a passion
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #7 on: Sun, 24 November 2013, 16:10:53 »
Aw man... would've liked to have tried these. I've heard good things.
Why??? Maybe your answer will make me feel better for missing it :D But I really am curious. I recently bought KOSS KSC75's though recently for use in bed.
Offline le_doosh
« Reply #8 on: Tue, 26 November 2013, 14:49:31 »
I couldn't stand the noise the cable made when you were walking. It was unbearable after a few days of walking to campus. The black rubber piece under the earphone itself, where the cable attaches, needs to be longer to give the cable more "support" and prevent it from moving as much when you walk. Also, they didn't seem to fit in my ears as snug as other in-ear's, regardless of what size tip pieces I used.
I had to send this back after 2-3 days of use. Bought a pair of  Shure SE-215 IEMs and haven't looked back.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #9 on: Tue, 26 November 2013, 16:22:03 »
Yeah, I've heard great things about the Shure SE-215's. Thanks for the heads up on cable noise though :D
