Author Topic: Pcper testing of rk-9000  (Read 1899 times)
Offline bondonin
« on: Tue, 26 November 2013, 21:07:04 »
http://www.pcper.com/reviews/General-Tech/Rosewill-Second-Generation-Mechanical-Keyboard-Review-RK-9000-RK-9000BR-RK-90-4
In the link above the new version of the rk-9000 seems to perform poorly in the accuracy test. Is the test too unfair and unrepresentative of real world use or is it something to keep in mind about the rk-9000?
Re: Pcper testing of rk-9000
« Reply #1 on: Tue, 26 November 2013, 21:42:39 »
I've never seen a review go that in-depth, however I have some doubts about their methods...
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Tue, 26 November 2013, 21:44:09 »
I seriously have never heard of this type of keyboard testing before.
Take it with a grain of salt
RK-9000 is not that bad of a board
« Reply #3 on: Tue, 26 November 2013, 21:55:44 »
This is pure  Quackery.... *********
using a straight edge does NOT guarantee actuating the keys simultaneously.
the keycaps are not perfectly molded..... the mounting plate is not perfectly flat, the pcb traces have minor differences in length...
The computer polling is also Never perfectly spaced..
add in User error..  using one's hand as testing equipment... biases for left and right preference...
Fffffffffffff........................................
Offline bondonin
« Reply #4 on: Tue, 26 November 2013, 22:03:43 »
The way I read it, they weren't trying to press the keys down simultaneously but try to depress a bunch of keys in sequence very quickly using the edge of a card. Its odd that the old version did better in the testing.
Even if the test is too hard for real world usage, its surprising that the Razer did alot better than the rk-9000 v2.
« Reply #5 on: Tue, 26 November 2013, 22:07:02 »
the test done is too unscientific...
