Author Topic: I broke my QFR  (Read 2575 times)
Offline Dany
I broke my QFR
« on: Fri, 29 November 2013, 07:25:38 »
I was opening my keyboard when I pull to hard the PCB, then disaster...
I'm not able to solder these pins anymore, any solution?
« Last Edit: Fri, 29 November 2013, 07:31:40 by Dany »
CM QuickFire Rapid with Black - 40A-R O-ring
Offline phoenix1234
Re: I broke my QFR
« Reply #1 on: Fri, 29 November 2013, 07:46:54 »
I think you can try to fix the trace by using this solution
source:
http://forums.evga.com/tm.aspx?m=185066
I like linear switches
Re: I broke my QFR
« Reply #2 on: Fri, 29 November 2013, 16:43:38 »
That's extremely neatly done!  (This is in reference to the fix in reply 1, btw.)
You could try some conductive ink to run the broken traces up to the pin holes, but you'd have to get the pins to stay in place - usually they'd be held in with the solder.
So something like ^ that might be the only way to go.
Re: I broke my QFR
« Reply #3 on: Fri, 29 November 2013, 17:35:14 »
I did this exact thing from openeing my QFR too many times. I ended up soldering jumpers to nearby vias. Just follow the traces, power and ground are nearby, and the data pins are closer to the controller. I can dig up a picture I took if you need.
Online Findecanor
Re: I broke my QFR
« Reply #4 on: Fri, 29 November 2013, 17:47:12 »
Follow the traces and solder individual wires to other solder pads on the respective traces.
To get better solder joints you could remove some solder from a pad with a solder wick and hook the wire around the existing pin.
Offline terran5992
  • One With The Cup Rubber
Re: I broke my QFR
« Reply #5 on: Fri, 29 November 2013, 19:08:56 »
Whats the problem with it?
Re: I broke my QFR
« Reply #6 on: Fri, 29 November 2013, 19:20:23 »
Obliterated the pads for the USB connector.  You shouldn't be seeing the PCB.
The easiest fix is to bridge the traces with a wire, but you'll need a smaller gauge wire for that.
Re: I broke my QFR
« Reply #7 on: Fri, 29 November 2013, 19:57:32 »
I think I used the wire out of a USB cable I destroyed to make the ergoDOX.
My perpetual issue is never having any hook up wire.
Offline zoolzoo
Re: I broke my QFR
« Reply #8 on: Fri, 29 November 2013, 21:19:17 »
How is this easy to do just by opening up the case?
Id like to know because Im modding a QFR for the first time for somebody this weekend.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Re: I broke my QFR
« Reply #9 on: Fri, 29 November 2013, 22:03:02 »
Shouldn't be that east, because CM sell replacement case tops that you can replace yourself without voiding warranty, and they wouldn't do that if it was so easy to break something just by opening the case.
Re: I broke my QFR
« Reply #10 on: Sat, 30 November 2013, 04:57:36 »
This isn't broken at all.. a little sand paper, and ur good to go!!!!
Offline Dany
Re: I broke my QFR
« Reply #11 on: Sat, 30 November 2013, 16:11:58 »
Tomorrow I will try to fix it, thanks for suggestions
Re: I broke my QFR
« Reply #12 on: Sat, 30 November 2013, 20:09:07 »
Just be careful when you are unplugging the internal USB cable. Cooler master also changed their construction at some point, making the internal cable detachable from both ends. My (very early) QFR is soldered on one side and disconnectable from the other.
I think I included tips in my QFR disassembly instructions (with pictures) I wrote up. Ironically, this is when I broke it.
Offline zoolzoo
Re: I broke my QFR
« Reply #13 on: Sat, 30 November 2013, 20:19:09 »
Yah, I noticed the connector when I opened the case and understood exactly what the OP did. Nice little surprise in there from CM/Costar. Thanks.
