Author Topic: Cutting metal  (Read 3862 times)
Cutting metal
« on: Sat, 30 November 2013, 12:08:10 »
Using a drill press with a dremel bit attached. to cut aluminum.
(yes) I am wearing paintball mask.
Do I use high rpm or low rpm..
Offline Photoelectric
Re: Cutting metal
« Reply #1 on: Sat, 30 November 2013, 12:11:45 »
Start low and if you have variable RPM settings, go higher to whatever feels right.  I used higher RPM for steel computer cases, but I think aluminum is soft enough for slower RPM.  Also make a groove on the surface with your dremel saw along the cutting line first--it will make guiding the circular saw much easier when you actually cut.
Re: Cutting metal
« Reply #2 on: Sat, 30 November 2013, 12:18:05 »
I would add some decent gloves along with the mask.
Re: Cutting metal
« Reply #3 on: Sat, 30 November 2013, 12:21:25 »
Oh yeah, definitely.  I use cheap transparent plastic goggle/glasses from HomeDepot.   Sparks will fly all over the place, and at least with steel, there's lots of metal dust and some larger pieces.
Offline eth0s
  • Peace & Love
Re: Cutting metal
« Reply #4 on: Sat, 30 November 2013, 12:25:10 »
Using a little machine oil at the cutting point can cut down on sparks and metal bits flying around, also keeps surface cooler.  But it can make a greasy mess if you're not careful.
Offline swill
  • builder & enabler
    • swillkb.com
Re: Cutting metal
« Reply #5 on: Sat, 30 November 2013, 12:48:04 »
I was planning to try with a grinder. I don't have a drill press. Anyone do this with a grinder?  Hints?
Offline tipo33
  • "Ski"
Re: Cutting metal
« Reply #6 on: Sat, 30 November 2013, 13:12:34 »
I have cut into a Lian-Li with a Dremmel, it's easy.  It certainly depends on the thickness and quality of the aluminium.
KM4COL    R.I.P.  SmallFry
Re: Cutting metal
« Reply #7 on: Sat, 30 November 2013, 13:13:22 »
Um...
I'm pretty sure that Drill press guidelines specifically says DO NOT WEAR GLOVES..lol
Re: Cutting metal
« Reply #8 on: Sat, 30 November 2013, 13:14:29 »
Grinder is good.. but not for small parts..
Grinder can cut something bigger than itself..
I'm using a drill press so that I can hold the small part, while passing it through the cutter.
Offline YoungMichael88
  • HHKB Wannabe
Re: Cutting metal
« Reply #9 on: Sat, 30 November 2013, 13:31:26 »
Um...
I would avoid loose fitting gloves for sure. Mechanics gloves should be fine as long as you're really careful.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
Re: Cutting metal
« Reply #10 on: Sat, 30 November 2013, 14:37:44 »
no gloves.
use alumatap http://www.amazon.com/Ounce-AlumTap-Cutting-Winbro-Each/dp/B002R84X6U
RPM will depend on cutter radius and material.
"Obviously, windows are central to Windows. But what is a window?"
Offline TheSoulhunter
  • ~ BOOO ~
Re: Cutting metal
« Reply #11 on: Sat, 30 November 2013, 15:34:05 »
If your setup is stable and you use TC bits you won't need cooling/lubrication or lowered RPM for aluminium,
just keep an eye on the feed rate as TC tends to break easily when applying too much pressure.
If you use HSS bits, lower the RPM and apply cooling/lubrication...
A Ghost From The Past
  • ~ BOOO ~
Re: Cutting metal
« Reply #12 on: Sat, 30 November 2013, 15:39:15 »
Just noticed that part:
Sounds like a good way to ruin your workpiece, hands or the cutting bit...
Consider mounting the workpiece into a fixture/vice to move it on the table.
Re: Cutting metal
« Reply #13 on: Sat, 30 November 2013, 16:40:35 »
this is "not" precision I'm after.. I gotta make small pieces.. FAST...
Re: Cutting metal
« Reply #14 on: Sat, 30 November 2013, 16:55:23 »
Drill presses aren't made for lateral forces. What you really want is a router in some kind of stand, I.e. a mill.
Might work well for something small and fast, though.
Remember, let the machine's rotation do the work, don't force it sideways.
Re: Cutting metal
« Reply #15 on: Sat, 30 November 2013, 17:03:40 »
I shall refrain from using the force.
Offline Badwrench
  • ummmm.....I forgot
Re: Cutting metal
« Reply #16 on: Sat, 30 November 2013, 17:53:19 »
Um...
This!  No gloves with a drill press.  Guy at work lost his middle finger (tore off at the first knuckle) when he went to brush away the metal curls at the drill point.  Circular grinder - use some leather gloves, face protection, and earplugs.  Dremmel- light gloves, safety glasses, and ear protection.  I am always surprised how loud my Dremmel is.
