Author Topic: Do you touch-type function keys?  (Read 11158 times)
Offline spremino
« on: Tue, 03 December 2013, 12:19:52 »
Do you touch-type function keys? I don't.
If you don't or find it awkward, and if function keys were placed like these:
would you find them easier to type (or as easy as on a 60%)?
« Last Edit: Tue, 03 December 2013, 15:00:52 by spremino »
A long space bar... what a waste of space!
Re: Do you touch-type function keys?
« Reply #1 on: Tue, 03 December 2013, 12:20:36 »
I touch all the keys I type on.
Offline 1pq
  • Hipster Doofus
« Reply #2 on: Tue, 03 December 2013, 12:24:16 »
I can sort of fake touch-typing F1-F5, but I'm not really very good at it. I use them so little that it doesn't really matter.
Any ones that you'll use often, even if isolated, you'll probably memorize by feel soon enough.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline spremino
« Reply #3 on: Tue, 03 December 2013, 12:27:19 »
I agree. For me it's F10.
« Reply #4 on: Tue, 03 December 2013, 12:33:09 »
I can on an Egdx....  I can't do the same on staggered qwerty because many are too far to travel with precision.. You can hit them once in a while, even most of the time.. but the consistency is not nearly as good as on the Egdx.
Offline SonOfSonOfSpock
« Reply #5 on: Tue, 03 December 2013, 14:28:04 »
I look about half the time. Usually when I'm using function keys its for something that is a little slower like software debugging as oppose to something faster like normal typing.
Offline spremino
« Reply #6 on: Tue, 03 December 2013, 14:29:08 »
Touch-typing means typing without looking at the keys.
« Reply #7 on: Tue, 03 December 2013, 14:32:21 »
I definitely do not.  They require too much hand movement to use muscle memory.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Tue, 03 December 2013, 14:47:08 »
Only on 60%... Fn Function keys FTW!
Offline Candyflip
« Reply #9 on: Tue, 03 December 2013, 14:55:05 »
I do but only to f6 + f10, starcraft players know why  :p
Offline spremino
« Reply #10 on: Tue, 03 December 2013, 14:56:13 »
If function keys were placed like these:
would you guys find them easier to type (or as easy as on a 60%)?
« Last Edit: Tue, 03 December 2013, 14:59:36 by spremino »
Offline 0100010
  • Not Sure
« Reply #11 on: Tue, 03 December 2013, 16:57:49 »
Touch type every key, they are all blank.
Offline Linkbane
« Reply #12 on: Tue, 03 December 2013, 17:00:20 »
I don't use many function keys, but I can touch type F5 and F6 easily (reload and URL select). Many 10FF resets.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #13 on: Tue, 03 December 2013, 17:03:55 »
I find it hard to touch them. Well F5 is easy( thank you battlefield and planetside). But past that is really hard to memorize, but I think it can be done.
I will focus on my touch typing speed though, which is barely 40.... But hey practice makes better, right?
« Reply #14 on: Tue, 03 December 2013, 17:10:11 »
Yes.
F1 = help, F7 and F8 are step into/over, F9 is run, F12 is switch form/code view in the IDE I use nearly every day.
I like the gaps between groups of function keys, and tend to become lost without them.
Offline spremino
« Reply #15 on: Tue, 03 December 2013, 17:22:55 »
I agree. I wonder why they were placed that far in the first place. The current placement on Filco keyboards makes much more sense.
But in the keyboard shown in the image above, each function key is above its corresponding number key, thus finding them should be easy. Would bigger characters on each key would? Alternating colors for each group of four (as it is often done)?
Offline C5Allroad
« Reply #16 on: Tue, 03 December 2013, 17:29:05 »
That board looks really easy to use muscle memory. I would really love a 60% as my next board.
« Reply #17 on: Tue, 03 December 2013, 17:30:23 »
Yes, yes I do touch type function keys.
Offline spremino
« Reply #18 on: Tue, 03 December 2013, 17:32:34 »
That's not a 60%. Actually, that's the most minimalistic layout that I would go for, albeit the modifier keys on the bottom row could be placed better.
Offline osi
« Reply #19 on: Tue, 03 December 2013, 17:33:59 »
+1
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #20 on: Tue, 03 December 2013, 17:58:39 »
"Obviously, windows are central to Windows. But what is a window?"
Offline AuRinBei
« Reply #21 on: Tue, 03 December 2013, 18:06:31 »
I can hit F5 and F9 like a mother****er....
87u || Poker 2
« Reply #22 on: Tue, 03 December 2013, 19:13:00 »
Except that on a standard keyboard, with which I am much more familiar, F1 is above 2, F5 is between 6 and 7, and F9 is above -_.
Offline BlackWidowMan777
« Reply #23 on: Tue, 03 December 2013, 19:49:02 »
Quote: "But in the keyboard shown in the image above, each function key is above its corresponding number key, thus finding them should be easy."
I like the idea of having function keys lined up with its corresponding number key, but when they're too close then I'm gonna be hitting a lotta numbers when reaching for function keys, especially when cold entering passwords that, say, begin with a '6'.
Offline Tony
« Reply #24 on: Tue, 03 December 2013, 19:54:12 »
F5 for sure.
Should we have two numbs on F4 and F5 too?
« Reply #25 on: Tue, 03 December 2013, 22:44:24 »
Function keys are an abomination. Command-alphanumeric with a sane mapping is better, easier to remember.
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
« Reply #26 on: Thu, 05 December 2013, 11:28:51 »
Yes, but only if they are spaced out in groups of 4 -- which is why all of our keyboards are.  :-)
Offline AKmalamute
  • HHKB Scrub
« Reply #27 on: Thu, 05 December 2013, 11:46:32 »
HHKB-lite2, Dvorak user
Offline TacticalCoder
« Reply #28 on: Thu, 05 December 2013, 12:35:28 »
I used to back when I was using Model M's (which have their own function keys). Now I'm on a HHKB and the location of the 'fn' modifier makes it impossible to touch-type at least one the function key and very, very hard, to touch type all the ones you'd need to touch type with your right hand.
But I don't care much for I remapped the software I'm regularly using so that my fingers need to travel less than before and that means much less love for the function keys  :)
(mainly Linux / awesome WM / Emacs / IntelliJ Idea: they're all highly configurable so it's not hard to find free and convenients shortcuts to use instead of those requiring function keys)
« Reply #29 on: Fri, 06 December 2013, 03:40:23 »
This is good!
I used to use Apple aluminium keyboard, and the function keys are not spaced apart.
Offline spremino
« Reply #30 on: Fri, 06 December 2013, 09:27:15 »
Or they aren't spaced out, but are grouped by colour in groups of four, I guess.
Offline daerid
    • Rossipedia
« Reply #31 on: Fri, 06 December 2013, 13:11:04 »
I've been touch typing F keys for at least 7 years now.
Kinda have to on the ErgoDox....
Offline Aer Fixus
  • And now, back to lurking...
« Reply #32 on: Fri, 06 December 2013, 13:45:57 »
+1
++; //C++ jokes in a keyboard thread for the win?
+=0; //I can only do the ones that matter. I just don't use the others very often and they aren't part of my muscle memory.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline Mr. C
« Reply #33 on: Fri, 06 December 2013, 23:34:04 »
No, I have to lift a little off home row. It would take some long fingers to touch type the top row.
« Reply #34 on: Fri, 06 December 2013, 23:45:50 »
If you used 1 keyboard all the time you could conceivably touch type function keys but if you rotate between different boards and the placement of the function keys vary (horizontally and vertically) then touch typing is gonna be hard depending on how fast a learner you are. I'm not so fast, and that's why I need backlight so I don't have to feel around for printscreen, f5, f11, etc.
Offline mooswa
« Reply #35 on: Fri, 06 December 2013, 23:53:46 »
I don't touch type neither function nor cursor keys.  That's why I want 60% keyboard so much!
Offline Linkbane
« Reply #36 on: Sat, 07 December 2013, 02:03:07 »
If you do touch type function and cursor keys, why would you want a 60%?
Offline yasuo
  • spanengan puyeng newbie
« Reply #37 on: Sat, 07 December 2013, 02:07:04 »
how important is the function?
prefer combination with numberic like 60%board or separate?
« Last Edit: Sat, 07 December 2013, 06:42:36 by yasuo »
Logitech MK220 Colemak DH
Offline Candyflip
« Reply #38 on: Sat, 07 December 2013, 06:32:15 »
He does not*, maybe you type fast but slow down on the reading :p
Offline BucklingSpring
« Reply #39 on: Sat, 07 December 2013, 09:38:48 »
For all those TT the Functions keys - Your rock!
Do you break typing position while you do it?
I mean keeping the index on J's nipple and stretching the pinky to F12 is a FAR FAR FAR away stretch for me.
Boards I own, click ->
Offline osi
« Reply #40 on: Sat, 07 December 2013, 09:46:17 »
When I go for the functions, usually my wrist raises and rotates to accommodate for where I am going. Some shoulder work involved too.
Generally I keep something planted on F or J for the easy transition back.
Offline Photoelectric
« Reply #41 on: Sat, 07 December 2013, 09:48:21 »
No, mostly because I don't do anything that requires their frequent use.  Lack of practice = not having a good feel for where they are without looking.
Offline Grim Fandango
« Reply #42 on: Sat, 07 December 2013, 21:17:40 »
I have not often used function keys on any other keyboard other than that of my previous laptop. I did touch type the function keys and knew all the common combinations. You kind of have to if you want to make a smaller keyboard work.
Offline berserkfan
« Reply #43 on: Sat, 07 December 2013, 21:44:03 »
On my Cherry MX boards I literally do a different-touch mod for some function keys. By using a different kind of keycap that feels different, I can identify the key without looking down. This helps me locate.
It's not a pretty solution, but it works and will do until somebody figures out how to add little bumps or homing bars to their function keys.
