Author Topic: Pulling the trigger :Leopold FC660M or Keycool 84 ?  (Read 3639 times)
Offline dvjz.gh
« on: Tue, 03 December 2013, 12:36:19 »
Help me  ;)
Leopold with clears or keycool 84 with blacks ?
For now i've only a qfrs with blues and a super poker 2 with browns : they feel so lonely  ;D
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Pulling the trigger :Leopold FC660M or Keycool 84 ?
« Reply #1 on: Tue, 03 December 2013, 12:37:46 »
Leo with clears. Nice build quality
Offline Pacifist
  • on hiatus
« Reply #2 on: Tue, 03 December 2013, 12:40:23 »
I own a keycool, they're pretty solid, but the leo is better
Offline ideus
  • Björkö.
« Reply #3 on: Tue, 03 December 2013, 12:43:47 »
The Leopold is very robust. Nice built and the finish of the plastic housing is outstanding. I have the charcoal and it looks awesome with cherry blacks.
Offline reziak
  • Topre/60% Enthusiast
« Reply #5 on: Tue, 03 December 2013, 12:49:15 »
I haven't seen a Keycool 84 in person, but the Leo is fantastic! The build quality is great, the layout is phenomenal. My only gripe with it is that the legends show wear quickly and as far as I know it's still hard to find a replacement spacebar if you change the keycaps.
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline ideus
  • Björkö.
« Reply #6 on: Tue, 03 December 2013, 12:54:46 »
To replace the space bar of the Leopold there are only a couple of colors either black or white. The black can be taken out of a cheap set
http://www.banggood.com/POM-84-Set-Blank-Key-Caps-Black-Keycaps-For-Cherry-MX-Keyboard-p-84082.html
And the white can be purchased out of QTan store that has awesome service.
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/leopold/pbt-white-space-bar-for-mx-che/lid=36564777
Offline 1pq
  • Hipster Doofus
« Reply #7 on: Tue, 03 December 2013, 13:19:21 »
Where did you find the leo with clears? I can't find any clear boards in stock anywhere.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline ideus
  • Björkö.
« Reply #8 on: Tue, 03 December 2013, 13:20:51 »
Try this link
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/leopold-fc660m-mechanical-keyb/lid=35722930
You can choose the switch and the color of the keyboard case that may be black, charcoal or white.
Offline dvjz.gh
« Reply #9 on: Tue, 03 December 2013, 13:47:54 »
Qtan sells it . I've bought my poker there , he's a good guy  :thumb:
Offline reziak
« Reply #10 on: Tue, 03 December 2013, 13:52:53 »
Fantastic! Leo all the way then  :thumb:
Offline ideus
  • Björkö.
« Reply #11 on: Tue, 03 December 2013, 14:04:11 »
The link bellow is Qtan's store at vendio.
Try this link
Offline dvjz.gh
« Reply #12 on: Tue, 03 December 2013, 15:58:12 »
What's the problem with spacebar ? It needs longer or shorter tha the oders keyboards ?
Offline ideus
  • Björkö.
« Reply #13 on: Tue, 03 December 2013, 16:07:51 »
The Leopold's space bar has its sockets in different position than standard. The switch stem is centered. Thus, a standard space bar does not fit it. Only keycool 84 and its own Leopold's.
See this thread
