Author Topic: Matrix to staggered  (Read 4975 times)
Offline jmchargue
Matrix to staggered
« on: Fri, 06 December 2013, 15:37:40 »
Is it really true that once you type on a matrix keyboard, you can't go back to staggered? I want to go matrix for the ergonomics, but I still want to be able to type on a laptop...
Offline Linkbane
Re: Matrix to staggered
« Reply #1 on: Fri, 06 December 2013, 16:11:27 »
There is literally the exact same topic posted in less than a day before this.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline yasuo
  • spanengan puyeng newbie
« Reply #2 on: Fri, 06 December 2013, 23:26:15 »
Symmetrical staggered i think can be solution,but make own :rolleyes:
Logitech MK220 Colemak DH
Offline Oobly
« Reply #3 on: Sat, 07 December 2013, 06:35:23 »
It's not that you CAN'T type on a staggered any more, just that you don't want to. Vertically staggered columns are even better than matrix, though. I keep saying this about different aspects of changing boards / layouts, but the more different it is, the easier it is to retain your old skills on a normal board.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline jmchargue
« Reply #4 on: Sat, 07 December 2013, 13:51:19 »
Alright, I can work with that.
Is the Ergodox considered vertically staggered? I mean, I can see that it is a little, but is it enough to really not be considered matrix?
Offline daerid
    • Rossipedia
« Reply #5 on: Sat, 07 December 2013, 19:20:00 »
Yes, the ErgoDox is vertically staggered, and no I wouldn't consider it a matrix board. I find myself still able to type on staggered boards, but like Oobly said above, I really don't like it when I do.
« Reply #6 on: Sun, 08 December 2013, 14:54:14 »
You can go back and forth without much issue... There are some inconsistencies.. but it's not like you will forget...
As yourself, because you've learned to drive a car, have you forgotten how to ride a bicycle?
When you learned to use a Mac, did you forget how to use windows?
Offline jmchargue
« Reply #7 on: Sun, 08 December 2013, 15:01:31 »
Haha, this is a great analogy, because while I didn't really forget how to use windows, I have very little patience for it. Alright, pretty set on (attempting to) trade my HHP2 for an Ergodox.
« Reply #8 on: Sun, 08 December 2013, 22:52:59 »
Offline spremino
« Reply #9 on: Tue, 24 December 2013, 06:55:56 »
Like some musicians can play more than one instrument, likewise I guess that you could type one more than one kind of keyboard.
From what I have read, the bigger the difference between tools, the easier is to keep muscle memory, because there is less risk of muscle confusion.
EDIT: Made text clearer.
« Last Edit: Tue, 24 December 2013, 10:18:39 by spremino »
A long space bar... what a waste of space!
Offline yasuo
« Reply #10 on: Tue, 24 December 2013, 08:43:39 »
From what I have read, the bigger the difference between layouts, the easier is to keep muscle memory, because there is less risk of muscle confusion.
For the layout i think true :)
for  staggered i not sure, traditional qwerty quite bother for me :) my left hand like poor :)
« Last Edit: Wed, 29 January 2014, 00:33:47 by yasuo »
Offline spremino
« Reply #11 on: Tue, 24 December 2013, 10:22:44 »
for  staggered i not sure, traditional qwerty quite bother for me :) my left hand like death :)
When I wrote "layout", I meant the way the keys are placed (that is: Maltron versus staggered keyboard) not the characters (that is Qwerty versus Dvorak).
I have edited my comment to make things clearer.
Offline yasuo
« Reply #12 on: Tue, 24 December 2013, 10:41:29 »
yeah i know if made instruments staggered :)) any 4 halves:old asymmetric qwerty,symmetric,matrix,columnar :)
