Author Topic: Themes  (Read 2304 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Themes
« on: Sun, 08 December 2013, 14:02:34 »
It would be cool to change to colors of themes. Like with Austere, I think it would look really cool if it was green or blue. Even the default one would look cool with different colors. What do you guys think?
Re: Themes
« Reply #1 on: Sun, 08 December 2013, 14:13:13 »
My firefox is set to make all websites look like this..
Offline keymaster
  • Topre Revolution Theorist
Re: Themes
« Reply #2 on: Sun, 08 December 2013, 14:32:13 »
Could you share the method/extension by which you achieved this?
Re: Themes
« Reply #3 on: Sun, 08 December 2013, 14:38:24 »
mmm.....
I use color toggle plugin for FF to replace color..
Grey on Black background
Disable background images in FF..
You also need my desktop theme which will replace all the LINES with grey on black
File attached..  this probably only works for windows 7
Offline n0rdlad
Re: Themes
« Reply #4 on: Sun, 08 December 2013, 14:41:17 »
I could never go back to explorer after using mozilla :) great features!
- Filco MJ2 104 MX Brown -
Offline C5Allroad
Re: Themes
« Reply #5 on: Sun, 08 December 2013, 14:42:42 »
I would use fox. But I really like having my tabs on my phone and computer. Also my bookmarks.
Re: Themes
« Reply #6 on: Sun, 08 December 2013, 14:42:55 »
adblock....
Re: Themes
« Reply #7 on: Sun, 08 December 2013, 14:43:36 »
you can import bookmarks into firefox..  i'm not sure what you mean by tabs..
firefox android has tabs and firefox default has tabs..
Offline C5Allroad
Re: Themes
« Reply #8 on: Sun, 08 December 2013, 14:56:19 »
I'm still on IOS... What I mean is that if I have the Keyboard section open on my computer, I can get the same tabs on my phone also.
Offline keymaster
Re: Themes
« Reply #9 on: Sun, 08 December 2013, 15:09:37 »
mmm.....
Thanks for the theme file. However, I'm having trouble enabling the old Windows theme (not the Win7 glossy theme) with your theme file. Do you know where I can force this change?
