Author Topic: Help me make up my mind before i go crazy..  (Read 15177 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Sun, 15 December 2013, 13:47:13 »
Well so far i have a few options on what keyboard i should go with and here is what i have.
Ergodox With some aftermarket keycaps. Sadly i would have to wait another 1-2 months for another massdrop.
Filco Tenkeyless with the same as the poker 2.
Poker 2 with After market key caps and a aluminium case and plate.
HHKB pro 2/ Realforce 55g.
So this is what i can't make up my mind about. I haven't tried out any of the above and i really can't make up my mind.
I can't buy more than one of these options for right now and i just want to get a nice keyboard and use it.
I'm afraid of getting the ergodox with the limited keycap options and odd layout.
I just need some opinions so i can quit thinking about it and i can just go ahead and buy some things.
Offline BGD
Re: Help me make up my mind before i go crazy..
« Reply #1 on: Sun, 15 December 2013, 13:54:37 »
Do you have a tight budget? Or can you basically get what you want?
Offline Air tree
« Reply #2 on: Sun, 15 December 2013, 13:56:29 »
I can get what i want but i can't get more than 1 keyboard at the moment.
« Reply #3 on: Sun, 15 December 2013, 13:57:49 »
Gotta say alu filco
It's just such an awesome sound
Offline BGD
« Reply #4 on: Sun, 15 December 2013, 13:58:57 »
If I could choose any of those, I'd definitely go with a HHKB (probably what a lot will tell you as well). :)
« Reply #5 on: Sun, 15 December 2013, 13:59:30 »
HHKB then Realforce 55 or  vice versa
Offline Air tree
« Reply #6 on: Sun, 15 December 2013, 13:59:57 »
That was my 1st option before, but Tp4 infected my mind with thoughts of the Ergodox.. And from there i went crazy.
« Last Edit: Sun, 15 December 2013, 14:02:43 by Air tree »
« Reply #7 on: Sun, 15 December 2013, 14:01:01 »
That was my 1st option before but Tp4 infected my mind with thoughts with the Ergodox.. And from there i went crazy.
Offline Pacifist
  • on hiatus
« Reply #8 on: Sun, 15 December 2013, 14:07:37 »
if your hands hurt from typing, ergodox
otherwise do you want compact or no? if compact and you want mx, go for poker. if topre, hhkb. if you just put it on your desk and you have room mx go for filco(filco really good, esp with plate) and 55g realforce if you want topre
« Reply #9 on: Sun, 15 December 2013, 14:17:34 »
^ Perfect explanation.  :thumb:
Offline nullstring
« Reply #10 on: Sun, 15 December 2013, 14:20:10 »
I would recommend you get a cheaper option like RK9000 or CM QFR.
When you have a better feel for what you want, you can purchase a more expensive option.
Just my 2 cents.
« Reply #11 on: Sun, 15 December 2013, 14:25:09 »
Just my 2 cents.
I did that and I regretted getting a Rosewill 9000 so bad. It was nice! But just not even close to my HHKB. But it was worth the experience, I guess I wished I got a Poker X or II instead of that though.
But yeah my HHKB is way nicer.
« Reply #12 on: Sun, 15 December 2013, 14:51:34 »
Technically....  You can get get 2x quickfires.. and it can be tweaked to mimic the Egdx.. but obviously it'll be a bit clunky.
Offline osi
« Reply #13 on: Sun, 15 December 2013, 15:16:40 »
Just my 2 cents.
I second this route. You'll start out with multiple boards then could just sell or trade what you don't like.
Offline Air tree
« Reply #14 on: Sun, 15 December 2013, 15:32:05 »
Just my 2 cents.
Hmm, I could just go with the Poker 2 at first. Then Wait until the CM topre with Cherry mx switch comes out.
Then i could try that.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #15 on: Sun, 15 December 2013, 15:40:03 »
SSK  :eek:
« Reply #16 on: Sun, 15 December 2013, 15:57:52 »
Just my 2 cents.
Yes get a Poker 2 if youre going MX.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #17 on: Sun, 15 December 2013, 16:21:08 »
I would go Poker. I loved my Poker X until I replaced it with GH60. 60% MX is great.
« Reply #18 on: Sun, 15 December 2013, 17:21:39 »
Is this your first board? go Filco
Are you a keyboard hipster who likes to live on the edge? go Ergodox
Do you have extra money you don't know what to do with? go HHKB
Will you be bringing your board with you places? go Poker(but not without buying her dinner first) or HHKB
Do you plan on doing some modding? go Filco or Poker
Do you game or code often and want a dedicated arrow cluster? go Filco
Small desk? go Poker or HHKB
Offline Pacifist
  • on hiatus
« Reply #19 on: Sun, 15 December 2013, 17:27:02 »
+1
Offline ahmadmzak
« Reply #20 on: Sun, 15 December 2013, 20:08:53 »
You just have to decide if you want a 60% or TKL. Then I would say try both the topre and cherry mx to see yourself which you like more.
60% : HHKB and Poker 2
TKL : Filco and Realforce
I would say get the topre first since its more expensive and you have the money right now. Later you might feel like getting a new keyb but budget might be tight.
I currently own a Poker 2 only. I am getting HHKB Pro 2 very soon.
Offline Tony
« Reply #21 on: Sun, 15 December 2013, 20:24:24 »
It is clear that you are already crazy; keyboards are only the closest culprit you have found to blame your craziness for.
You will buy all of them sooner or later, so any keyboard is good for a start. Save your indecision for another, more important occasion.
« Last Edit: Sun, 15 December 2013, 20:27:19 by Tony »
Offline eth0s
  • Peace & Love
« Reply #22 on: Sun, 15 December 2013, 20:30:40 »
oh lord.  Plz don't listen to tp4.  Just get the HHKB Pro 2.  You will be very happy.  And in 2-3 months, if you still have a hankering for the ergodox, you can get that too.  You still have to assemble the ergodox yourself, right?  So that could take you another month, if you're like me and don't get to things right away.  So just get a great keyboard right away.  You will be very happy with the HHKB Pro 2.  Just remember the layout is a bit different.   So you will have to adjust.  But if you have more than 65 IQ points, it's not too hard.   I have only 64, and I did it.
« Reply #23 on: Sun, 15 December 2013, 20:47:51 »
This is exactly the type of BS the topre fanbois love to post..
The only reasons that eth0s even posted this is because one, he's obsessed with h8n' on Tp4,
and 2, he wants you to buy a topre because HE HAS ONE.... you see, he doesn't have enough justification for it through himself, the keyboard does not speak for itself.. Therefore, he has to go on the internet, and find accomplices to affirm just how much "NOT A WASTE OF MONEY" the topre board really was...
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #24 on: Sun, 15 December 2013, 20:48:54 »
Get the HHKB. If you don't like sell it here on classifieds. I'm sure you will be able to sell it very quickly, if you're having doubts whether or not to buy the ergodox.
« Reply #25 on: Sun, 15 December 2013, 20:51:40 »
Sure, if you don't like it, pass the problem onto someone else...
Offline eth0s
  • Peace & Love
« Reply #26 on: Sun, 15 December 2013, 20:55:36 »
Hmm, well I may not be a smart man, but I'm not afraid to waste money.  If I spend it, I don't regret it.  Life is too short.
As to why I recommended a Topre, now, there is another possible explanation, which is that I really do like Topre, and the HHKB Pro 2, and that  they really are as great as I say they are.  I have four Topre keyboards, and I'm planning to buy another one soon.  And I don't really care if anybody else likes them or not.  It matters not a wit to me what the rest of the world does.  Go buy another ergodox, I could care less.  But if somebody asks for my advice, I give it:  buy a Topre keyboard, and be done with it.
Offline terran5992
  • One With The Cup Rubber
« Reply #27 on: Sun, 15 December 2013, 22:31:14 »
Or you know spend all of your money on clacks
Offline Emospence
« Reply #28 on: Mon, 16 December 2013, 03:16:52 »
55g realforce. Yeah baybeh
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline adhoc
« Reply #29 on: Mon, 16 December 2013, 03:33:37 »
Well I went with a HHKBP2. If I will not like switches (but will like the layout) I'll go for a Poker II. If I will not like the layout (but will love the switches) I'll probably go with a Realforce TKL + extra realforce numpad (so kb is left of mouse, numpad is right of mouse). If I will not like either the layout or switches I'll stick to my POM Cherry Blue, which I am currently in love with.
I went back and forth and realised that HHKBP2 is a really good option as starting grounds; I think there's a very good chance you will absolutely love it and if you won't, you've basically seen everything - the most exotic (still mass available) switches with the most exotic layout. From there you can go either way as per what bothers you with the keyboard and you know exactly what you want from your next one.
The initial investment is big, sure, but from here on out you should know exactly what you want (even if you don't like the keyboard) - this probably saves more time and money in the long run than buying cheap keyboards and finding bothersome problems with each.
« Last Edit: Mon, 16 December 2013, 03:35:33 by adhoc »
« Reply #30 on: Mon, 16 December 2013, 03:47:52 »
An excellent approach!
The only downside is the initial cost, for a HHKB, but then if you are prepared to pay that much then you will be prepared for it.
Offline adhoc
« Reply #31 on: Mon, 16 December 2013, 03:56:16 »
The only problem now is the wait...jesus, it's inbound to Europe from LA right now, go my little keyboard, FLY to me! :D
Offline Oobly
« Reply #32 on: Mon, 16 December 2013, 04:20:39 »
Hi Air Tree, Any decision made yet?
For what it's worth, I'd recommend waiting until the Nexus (Acidfire's advanced updated version of the ErgoDox with angled thumb clusters) is available and get one of those with blank keys.
That's the most ergonomic option and since it's programmable you can also use a more ergonomic character layout.
If you don't want to go that extreme, then I'd recommend a Poker 2 with MX Browns for the following reasons:
1. Stock keycaps. They're PBT.
2. Aftermarket keycaps... there are tons of options for aftermarket caps which fit, and let's face it: You're on GH, you're going to switch keycaps at some point.
2. You can find out if the 60% layout works for you or not and whether or not you like the MX switches.
3. The Browns are a good starter switch, good for gaming and typing.
4. The switches can be modded in many ways including swapping stems and springs to turn them into different switches, so you can make the board feel how you want if you don't like the stock feel.
The problems with getting a HHKBP2 as a starter board are:
1. (Very) Limited keycap options. And getting even more limited since it looks like Topre will stop producing aftermarket sets.
2. (Very) High cost.
3. You still won't know what MX switches feel like (although you'll have the reverse problem with the Poker, not know what Topre feels like).
4. You can't change the feeling of the switches if you don't like them or want to try something else.
« Last Edit: Mon, 16 December 2013, 04:27:57 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #33 on: Mon, 16 December 2013, 04:53:05 »
Two points highlighted in bold I don't quite agree fully.
The high cost is partly true if you source it from maybe elitekeyboards.com. If you source it direct from Japan you forfeit any warranties but it works out cheaper. If you love HHKB Pro series but cannot afford Pro2 then there is always Pro JP to look at which apparently on Japanese seller sites, they retail the Pro JP much cheaper than Pro2 (the same said case is not the same with Type-S unfortunately). Last but not least one can almost always source a second hand HHKB Pro for sale if they are tight on the budget.
Not saying that one cannot find Poker II second hands as well if need be but at least for HHKB Pro there are some more options available should they be on a budget.
As for changing the feeling of the switches. Not quite true for the reasons that you can get either harder or softer rubber for HHKB. However, it also means that you have to harvest from a Realforce (for instance) keyboard which would mean that you need to fork out more money than say for example buying Cherry MX switches and applying them. Apart from that there aren't really that much other mods that are available for changing the feel of the Topre in general to be frank.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #34 on: Mon, 16 December 2013, 05:15:06 »
'REGIBALD, PREPARE THE JIZZATORIUM. A NEW CADET SHALL BE JOINING THE COMMUNITY JERK TONIGHT.'
'MMMM, LAY OUT MY SANDPAPER GLOVES WOULD YOU OLD CHAP? DADDY'S BEEN EXTRA NAUGHTY THIS WEEK.'
Offline adhoc
« Reply #35 on: Mon, 16 December 2013, 05:28:20 »
As others have already told you this before, your condescending attitude towards some users is completely uncalled for. You're also ASSuming and you know what they say about ASSumptions, right?
Thank you, "Regibald".
« Reply #36 on: Mon, 16 December 2013, 05:40:20 »
'REGIBALD, PREPARE THE FURNACE. WE HAVE ANOTHER LETTER OF COMPLAINT. LET US SORT IT UNDER, UMMMMMM, FUEL FOR FIRE AND WARMTH. HMMM, EXCELLENT.'
Offline adhoc
« Reply #37 on: Mon, 16 December 2013, 05:55:14 »
You are very funny. Not sure to whom, but I guess SOMEBODY must find you funny, otherwise you probably wouldn't keep this up for 30 years.
« Reply #38 on: Mon, 16 December 2013, 06:06:47 »
I love that you know so much about me. If you can convince more people I'm real, maybe I'll turn into a real boy. It would be a Christmas miracle!
« Reply #39 on: Mon, 16 December 2013, 07:21:22 »
Why not wait until after you go crazy to make up your mind?
Then you can change it with impunity.
- D Trump 2026-10-24
Offline Air tree
« Reply #40 on: Mon, 16 December 2013, 08:55:28 »
I think i have decided to get a poker 2 with cherry mx reds, and if i don't like reds it's browns because i can't stand the clicky sound of blues.
And from there i will be waiting until we here news of the CM topre board or just the Topre with Mx stem's in general.
In any case if i like the poker 2 i will probably end up buying a set of keycaps and maybe a aluminium case and plate in any case (Ha pun!)
Offline C5Allroad
« Reply #41 on: Mon, 16 December 2013, 09:02:43 »
Another mans trash is a another mans treasure.
« Reply #42 on: Mon, 16 December 2013, 09:59:21 »
Eh...?  Better choice than Topre!! slightly less than our hero and savior yes (Nicholas Cage = Egdx)
Offline Linkbane
« Reply #43 on: Mon, 16 December 2013, 13:45:33 »
That was the most terribly stupid pun I've ever heard, and made me go from willing to brush off your exhibited uncalled-for anger into laughing at your inability to understand a joke.
And I really wish I could see that new CM TKL board, but I'm at school and the filter..
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #44 on: Mon, 16 December 2013, 13:52:47 »
So hope this is an actual joke that kinda fell flat and not srs.
Offline Air tree
« Reply #45 on: Mon, 16 December 2013, 16:23:06 »
Oh god, The poker 2 with the upgrades i want (Classic Beige keycaps +Aluminium plate and case) Comes out to 365$..
Offline Pacifist
  • on hiatus
« Reply #46 on: Mon, 16 December 2013, 16:23:57 »
of course. aluminium isn't cheap
Offline domoaligato
« Reply #47 on: Mon, 16 December 2013, 16:25:54 »
and at that price you might as well go with a korean custom for a little moar. welcome to wallethack. the rabbit hole never ends...
Offline Pacifist
  • on hiatus
« Reply #48 on: Mon, 16 December 2013, 16:28:39 »
just go buy john's kmac 1 for $300 and save some monet
Offline Air tree
« Reply #49 on: Mon, 16 December 2013, 16:30:04 »
What is the benefit of a korean custom anyways?
Once i get a job i'm only going to be making 8300$ due to restricted working hours because of my age...My wallet is already hurting. Halp me!
