Author Topic: Water in kb  (Read 3232 times)
Offline Shikarikato
Water in kb
« on: Sun, 22 December 2013, 02:25:53 »
I got water in my kb. What do? Onscreen kb sucks a lot. Should I just wait for it to dry?
Re: Water in kb
« Reply #1 on: Sun, 22 December 2013, 02:51:56 »
put it in a warm area.. not HOT area, too close to the radiator might warp the plastic.
Offline PointyFox
Re: Water in kb
« Reply #2 on: Sun, 22 December 2013, 03:03:58 »
I would take it apart, use an air blower to blow some of the water out, separate the plastic parts from the electronics, then stick the electronic parts in an oven at a low temperature, like maybe 120F.
Also if I had something like 3M Novec, I'd use it to displace the water and it would be dry in no time  ^-^
« Last Edit: Sun, 22 December 2013, 03:09:18 by PointyFox »
Offline terran5992
  • One With The Cup Rubber
Re: Water in kb
« Reply #3 on: Sun, 22 December 2013, 03:20:27 »
Unplug it wait for a few days and plug it back in again
Offline cinnamoncider
  • Thorpies are snappy
  • No clack; no life.
Re: Water in kb
« Reply #4 on: Sun, 22 December 2013, 03:36:50 »
You could remove the keycaps and wash it already, and wait for the soaked board to dry.
I haven't experienced spilling any liquid on my mkb; try not to eat/drink in front of your PC  ;)
Offline TacticalCoder
Re: Water in kb
« Reply #5 on: Sun, 22 December 2013, 03:37:27 »
This.
Dried a laptop's keyboard using an hair dryer once and put it too close to the keyboard. Most of the keys suddenly started melting... Had to buy a replacement keyboard (thankfully it was surprisingly cheap and easy to find). Good memories ; )
Re: Water in kb
« Reply #6 on: Sun, 22 December 2013, 03:51:07 »
You could also try putting it in a bag with dry rice - the rice will help absorb the moisture.
Re: Water in kb
« Reply #7 on: Sun, 22 December 2013, 04:37:55 »
It will also attract Asians to fix your board :))
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Water in kb
« Reply #8 on: Sun, 22 December 2013, 10:54:07 »
Buy a bag of rice. Then put the board in there. Next put it somewhere warm.
Re: Water in kb
« Reply #9 on: Sun, 22 December 2013, 12:11:23 »
warm surrounding is good enough.. no need to waste food ...  poh'fy'vheyes
Offline C5Allroad
Re: Water in kb
« Reply #10 on: Sun, 22 December 2013, 14:29:30 »
Well rice attracts asians....
Offline Lu_e
Re: Water in kb
« Reply #11 on: Sun, 22 December 2013, 14:57:33 »
Flipped one upside down and put in on top of a radiator heater on low. Was more of a precaution though, just a few big drips got on it. How long you leave it there depends on how much water you got on it... if I knocked a full glass of water directly on the keyboard I would wait at least a week. Even longer without a direct heat source.
Just say NO to ABS keycaps
Re: Water in kb
« Reply #12 on: Sun, 22 December 2013, 15:00:59 »
if it got "into" the switch.. it might take a month to dry.. luckily the switch doesn't really care if there's a little water in it..
Offline fourzeropooh
Re: Water in kb
« Reply #13 on: Sun, 22 December 2013, 16:27:16 »
How much water did you spill on it?
Re: Water in kb
« Reply #14 on: Sun, 22 December 2013, 19:56:29 »
What kind of switch?
What kind of water?
Offline tuxsavvy
  • 白HHKBの魔法使い
Re: Water in kb
« Reply #15 on: Mon, 23 December 2013, 05:07:05 »
Funny to see how Asians' staple food is the rice which is also seen everywhere else as a ways of drying some poor soaked (in water or a mix containting water) electronic component up. It is also a poor man's way of drying things.
If I were to put my water logged keyboard in a bag full of flour - would that attract Caucasians to fix my board instead?  :p
Jokes aside, silica gel is the best thing to soak up moisture. Also putting the exposed electronic component in an airtight container would further be ideal as that would prevent any rust growing on the electronic. Getting a large enough bag of silica gel is often hard let alone being able to afford for a large bag full of it in the first place.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Re: Water in kb
« Reply #16 on: Mon, 23 December 2013, 15:56:07 »
It's maybe a day and a half later - what has transpired?
Is the keyboard still working?
