Author Topic: Aluminium case electric cons  (Read 4162 times)
Offline tns
« on: Tue, 24 December 2013, 07:29:08 »
Hello GHers!
I got a YotS, and sometimes the case give me some "electric stream" it's not always the case, I was wondering if
it was the case of all aluminium cases,
or
is it because the YotS wasn't that greatly anodised/anodized
or is it because of something else?
how to avoid that or what are your advices?
 ;) Merrx Xmas
« Last Edit: Tue, 24 December 2013, 07:33:09 by tns »
Offline zoolzoo
Re: Aluminium case electric cons
« Reply #1 on: Tue, 24 December 2013, 07:35:32 »
Hello GHers!
or
 ;) Merrx Xmas
by electronic stream do you mean that it is shocking you?
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline tns
« Reply #2 on: Tue, 24 December 2013, 07:37:53 »
Hello GHers!
or
 ;) Merrx Xmas
it's not a static electricity shock
it's like I'm having continus electricity on my hand or fingers
Offline neunelfer
  • HHKB Pro
« Reply #3 on: Tue, 24 December 2013, 07:39:33 »
Like a tingly feeling? I used to get that sometimes when I had my original iPhone (Al back) plugged in.
Offline tns
« Reply #4 on: Tue, 24 December 2013, 08:07:03 »
so you're saying the reason is mainly from the power supply of my computer?
Offline neunelfer
  • HHKB Pro
« Reply #5 on: Tue, 24 December 2013, 08:19:51 »
I'm not really sure why exactly it happens, but yes, that would be my guess. It only happened when it was plugged in to the charger.
Offline zoolzoo
« Reply #6 on: Tue, 24 December 2013, 13:49:19 »
I think its the power draw coming from your imagination :]
« Reply #7 on: Tue, 24 December 2013, 13:51:03 »
no dude..
This actually does happen with usb devices that are improperly grounded.
OP, you can try spraying the inside of the case with some rubber stuff, the kind that peels off if necessary..
double check the stuff ur spraying isn't corrosive.
« Reply #8 on: Tue, 24 December 2013, 15:35:09 »
no dude..
+1
Did this to a buddy's YOTS who had the same problem.
Seriously, make sure that it's not the corrosive stuff.
Offline fourzeropooh
« Reply #9 on: Tue, 24 December 2013, 15:36:27 »
no dude..
+1
Did you spray your buddy's YOTS with corrosive stuff?
« Reply #10 on: Tue, 24 December 2013, 15:38:50 »
no dude..
+1
Nope, I checked first.
« Reply #11 on: Tue, 24 December 2013, 17:02:22 »
no dude..
+1
I made the corrosive mistake once with rubber cement.. Ruined a 4600Ti...
Luckily, lifetime warrantee..
Offline BucklingSpring
« Reply #12 on: Tue, 24 December 2013, 18:11:30 »
So you claimed the warrantee for your own mistake. You're a bad kitty.
Boards I own, click ->
Offline zoolzoo
« Reply #13 on: Wed, 25 December 2013, 08:51:56 »
no dude..
Yah but, where on a keyboard with a alum case would this problem stem from? Talking specifically about his application...honestly asking.
Offline tns
« Reply #14 on: Wed, 25 December 2013, 11:14:21 »
no dude..
wah is there anything else?
« Reply #15 on: Wed, 25 December 2013, 12:37:42 »
I was 13/14 at the time.. I didn't understand ownership or warranty.. I just knew it said lifetime.. So I called them, and mailed it.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #16 on: Wed, 25 December 2013, 12:53:50 »
Check with a multimeter?
A Ghost From The Past
Offline ZeodoHokill
« Reply #17 on: Wed, 25 December 2013, 22:47:36 »
Maybe you can disconnect the USB and see if the feeling still exist
« Reply #18 on: Wed, 25 December 2013, 23:20:56 »
no dude..
any place that has power touching the case is usually enough..
because the case is designed to be "grounded" by touching certain parts of the keyboard..
So it's always half the loop.
